th350 converter? - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 06-21-2013, 03:01 PM   #1 (permalink)
Member # 72992
Send a message via Yahoo to poor boy pulling
th350 converter?
so going to be running a th350 behind my 6.0L in my buggy, i have the early long crank 6.0 which is the same as a SBC so i dont need the special spacer or flexplate. but the problem im running into is the stock flexplate is a 11.500 bolt center which is really hard to find a stall converter in and AA doesnt make a flat flexplate to run a 10.750 pattern. so my question is the only converter i can find that is reasonably priced is a hughes that is 2k stall. is that going to be enough with 5.13s, 2.6 D300 and 43" tires? everyone seems to tell me i need around 2400 stall not to push threw my brakes as well as get the engine up in the power band. any ideas?
OUTCAST CRAWLERS
Douglas Auto Machine
D.A.M offroad lights
Are you welding with a cake decorator?
poor boy pulling is offline   Reply With Quote Quick reply to this message
Old 06-21-2013, 10:41 PM   #2 (permalink)
JCT
Member # 162423
Oval the holes on the flex plate and buy a Hughes 2-2200 stall converter! You will be good to go !
JCT is offline   Reply With Quote Quick reply to this message
Old 06-21-2013, 11:16 PM   #3 (permalink)
Member # 72992
that was the one i had in mind but i wasnt sure that was going to be enough stall
OUTCAST CRAWLERS
Old 06-21-2013, 11:22 PM   #4 (permalink)
homeboy's Avatar
Member # 186874
has to oval mine and run a 2400-2600 converter behind my 6.0. very happy with it just get the most efficient and largest trans oil cooler you can. mine doesn't like high range to for too long.
homeboy is offline   Reply With Quote Quick reply to this message
Old 06-21-2013, 11:24 PM   #5 (permalink)
Member # 72992
whos converter and how much?
OUTCAST CRAWLERS
Old 06-22-2013, 05:44 AM   #6 (permalink)
civicmindedex79's Avatar
Member # 116609
I am running a 10" PTC with about 2800 stall. We probably ride a little different here in the east but defiantly happy with it. If you call Lane at PTC he can get you the correct bolt pattern convertor. I am about 90% sure.
Performance Torque Converter- (256) 383-6868 - Central Time Zone
civicmindedex79 is offline   Reply With Quote Quick reply to this message
Old 06-24-2013, 10:41 AM   #7 (permalink)
Member # 72992
so pretty sure im just going to go with the 2k stall as i can get it locally and am running out of time and money. depending on my brakes etc am i going to have a problem pushing threw the brakes?
OUTCAST CRAWLERS
Old 06-24-2013, 06:52 PM   #8 (permalink)
homeboy's Avatar
Member # 186874
a buddy runs a 2000 stall behind his 6.0 and doesn't complaint of driving through brakes.
I was looking at buying a TCS converter and they said they would cut it open and change the stall.
edit: my converter is a b&m holeshot
Old 06-24-2013, 08:48 PM   #9 (permalink)
crashinaz's Avatar
Member # 4669
Just keep in mind that talking stall speed only is going to be a roll of the dice with the converter not performing as you'd wish more times than not. Talk stator with your builder and how you want it to behave when it comes up on the converter. Trust me on this one.
crashinaz is offline   Reply With Quote Quick reply to this message
Old 06-25-2013, 01:16 PM   #10 (permalink)
Member # 85796
D&P converters in sac can build any stall into any size converter, PDQ converters can do same thing in south sac call Tracy 916 870 6543
Tell him joe from red-d sent you
BIGJOEDUCKSLAYER is offline   Reply With Quote Quick reply to this message
Old 06-25-2013, 01:59 PM   #11 (permalink)
DOUG38S's Avatar
Member # 17107
Send a message via AIM to DOUG38S
ive been running a 2500 hughes behind my L33 for the last 5 years.
BIGELOW MOTORSPORTS EST. 2003
DOUG38S is offline   Reply With Quote Quick reply to this message
Old 06-25-2013, 02:01 PM   #12 (permalink)
Member # 72992
yeah i called D&P and they were price just about like everyone else. i gonna just go with the 2k and see how it goes
OUTCAST CRAWLERS
