Bigfoot ZF Axles - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 07-13-2013, 07:07 PM   #1 (permalink)
Member # 334698
Bigfoot ZF Axles
I am thinking about upgrading axles on a Jeep Unlimited. I always thought it was cool how the original Bigfoot used military axles. Ultimately, I wanted to use something similar. It looked like the new Bigfoot trucks are using ZF Axles. Do you think it is even possible to use the same ZF axles as Bigfoot for this project or should I stick to the Dynatrac Pro Rocks? Thank you in advance for your responses?
Classic 59 is offline   Reply With Quote Quick reply to this message
Old 07-13-2013, 07:24 PM   #2 (permalink)
Member # 50177
You should totally do it. They are a awesome axle upgrade. There is a guy on this board that makes brackets to install them in jeeps, I think his name is dieselmh, just send him a PM and ask about them
Toyota Link Suspension Systems, Weld On Beadlocks, Custom Fabrication, and More
________________________________________________
05 GMC 2500HD d-max, 87 4runner, X chassis rock buggy
my buggy build
am4x4 is offline   Reply With Quote Quick reply to this message
Old 07-13-2013, 07:48 PM   #3 (permalink)
Member # 94400
Delete this thread and go here and ask.
Newbie General 4x4 Discussion - Pirate4x4.Com : 4x4 and Off-Road Forum
92 Fj80 6bt, 1tons wife mobile
70 Fj40 1ton v8 241/205 42's
03 CTD toe rig
Texas Trail Buggy
what's it like to own a buggy........i'd say it's like getting a blow job on a roller coaster
slobuild57 is offline   Reply With Quote Quick reply to this message
Old 07-13-2013, 07:49 PM   #4 (permalink)
Member # 111580
This, get ahold of him, he will set you up with everything needed at incredible prices ( he basically give this shit away!)
dragrcr65 is offline   Reply With Quote Quick reply to this message
Old 07-13-2013, 07:56 PM   #5 (permalink)
Corey Young's Avatar
Member # 21622
The gear ratio is about 22:1 so unless you are running 66 inch or bigger tires your top speed will be about 35 mph. I have a couple sets of ZF 345b if you are in the market.
Old 07-13-2013, 08:31 PM   #6 (permalink)
bjordan's Avatar
Member # 143323
Those axles are passenger side drop so you have to cross to front driveshaft to the other side. Make sure you lengthen your drive shaft to accommodate the new length. Good luck.
Get a sitter and take her somewhere nice. Obviously "nice" is reliant on budget, as my nice might be crawfish and draft shiner at a dive bar followed by rough backseat sex parked behind Gander Mountain- whereas your nice will probably differ from that.
bjordan is offline   Reply With Quote Quick reply to this message
Old 07-13-2013, 09:27 PM   #7 (permalink)
Member # 50177
Dude! Are you new! If you lift it high enough for the oil pan to clear the driveshaft it can cross over no problem, everyone knows that
If he wants to set it up low he can just swap the steering knuckles side to side and flip the axle to get the diff on the correct side.
my buggy build
Old 07-13-2013, 10:18 PM   #8 (permalink)
Member # 144157
The only problem I see is that I don't think you will be able to machine out your dick cepek dc-2s to fit over the planetaries
Jeepsquatch is offline   Reply With Quote Quick reply to this message
Old 07-18-2013, 09:24 PM   #9 (permalink)
Member # 334698
Thank you for all of your responses. How much do you think the ZF axles cost that are exactly like the ones on Bigfoot?
Old 07-18-2013, 09:44 PM   #10 (permalink)
Member # 10736
The smaller 345 axles are used in airport tugs. Bigfoot uses the large 745 axles I believe.
I would guess 745s are worth 10k a piece. 345s are worth 1k or 2k a piece.
masonmachines is offline   Reply With Quote Quick reply to this message
Old 07-18-2013, 10:01 PM   #11 (permalink)
Member # 21622
The axles are ZF APL735, APL745, and APLB755. Some have wet brakes, some do not. Some have limited slips, some are open. Tom Meents runs modified APL365 axles that hold up just as well.
I have read $15-17,000 new each from John Deere for 700 series. If you could find a couple used ones at a tractor junkyard, I would guess $3-9,000 each depending on the model. Some are centered diff, some are offset.
Why dont you call or email Bob Chandler? http://www.bigfoot4x4.com/home.html
Dan Patrick might know where to find some axles http://www.samson4x4.com/chassispage.htm
This guy knows stuff about monstertruck parts too: http://www.racesourceinc.com/
Old 07-19-2013, 05:54 AM   #12 (permalink)
Member # 130105
You realize how dumb you sound right? Nvm go 765 with 35" Thornbirds.... It'll be badass lol.
"TO BE OLD AND WISE YOU MUST FIRST BE YOUNG AND STUPID"
Midget28 is offline   Reply With Quote Quick reply to this message
Old 07-19-2013, 12:08 PM   #13 (permalink)
Member # 14094
Send a message via AIM to Hvy_Chevy
see if these fit
Antonio Carraro axle Parts/Salvage | CHAPMAN SERVICES TROY , ME
Size does matter.
Leave the Zukes to those who really understand.
Hvy_Chevy is offline   Reply With Quote Quick reply to this message
Old 07-19-2013, 12:09 PM   #14 (permalink)
Member # 14094
diff from a 744
Size does matter.
Old 07-19-2013, 12:54 PM   #15 (permalink)
Member # 15354
Send a message via AIM to iniviate
Originally Posted by Hvy_Chevy View Post
this guy says the bolt right in...
02 S10 - LS1, 4L80, 2.5 tons, 14.9-24 R1's - In Progress.
88 YJ - 350, 1 tons, 40's
iniviate is offline   Reply With Quote Quick reply to this message
Old 07-20-2013, 12:05 AM   #16 (permalink)
lurchseesu's Avatar
Member # 112455
^still ranks as the nicest mudtruck I've ever seen.
lurchseesu is offline   Reply With Quote Quick reply to this message
Old 07-20-2013, 07:38 PM   #17 (permalink)
Member # 10736
$1200
If I lived near by I would buy them and let them sit in my barn.
