Dana 60/70 Splindle Speedy Sleeve PN Needed - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 07-05-2003, 08:44 PM   #1 (permalink)
Member # 3864
Send a message via AIM to WOLF359
I need the part number for a Dana 60 (or 70, they are the same) Speedy Sleeve for the inner Wheel bearing seal surface on the spindle.
To clarify, I need a Speedy Sleeve for the Spindle where the wheel bearing seal runs.
I have destroyed that surface on my Dana 70, and of course the spindles are integral to the housing.
Anyone?
WOLF359 is offline   Reply With Quote Quick reply to this message
Old 07-05-2003, 10:29 PM   #2 (permalink)
Member # 2928
Just bought some of these for my 14 bolt,man they aint cheap.Listed for $40 each and I got them for $27,still way better and easier than replacing whole houseing. I need some for for 60 also,planning on going by bearing place on monday,will post then if you have not found # yet.
1972 Ford F-250 4x4 Dana 60/14 bolt
4.88s,Detroits,40"Hawgs,rear P.T.O. winch,390c.i.,N.P.435,Dana 24 "Engage brain BEFORE engaging gears"
PTO DAVE is offline   Reply With Quote Quick reply to this message
Old 07-06-2003, 04:48 AM   #3 (permalink)
Member # 3547
I badly need these for my 14b to!
My SKF/CR bok only lists them by dimension, not app.
If you give me the measurement of the diameter of the orig. spindle seal (that you want to cover/sleeve) and the width you want it to be on the spindle, I can pull a part number
BillaVista is offline   Reply With Quote Quick reply to this message
Old 07-06-2003, 09:16 AM   #4 (permalink)
Newb
nvrenuf's Avatar
Member # 10903
The CR brand sleeve for a 14 bolt is #99282, I got mine from Motion Industries. I was also able to get a CR seal by cross referencing the National #, the CR seal was a much better seal - double wall & double lip. Sorry, I don't have the CR seal number.
The guy found the 14 bolt sleeve using the National brand seal part number, I would think this would also work for finding a sleeve for the D70.
John
'91 K5 454, 4spd, Doubler, J76/70HD, 5.86's & 43's
happy..happy..happy....
nvrenuf is offline   Reply With Quote Quick reply to this message
Old 07-06-2003, 10:11 AM   #5 (permalink)
Bushwhacker's Avatar
Member # 9138
Send a message via ICQ to Bushwhacker
Is there a picture of what you are talking about in your 14bolt writeup? Is this something you have to replace when you rebuilt one?
WEROCK Judge
RROCK Legends Competitor
97 TJ buggy,4.0,727,Atlas,D60,14B
Bushwhacker is offline   Reply With Quote Quick reply to this message
Old 07-06-2003, 04:01 PM   #6 (permalink)
Member # 3547
Not yet. In the disc brake writeup there may be a picture showing the badly worn spindle, which is why the sleeve is required. I replaced the hub seals, and it still leaks gear oil out the hubs - which really sucks coz it gets on the rotor, and contaminates the pads and is generally all bad.
Not normally, no, it's not a normal wear item. But after a hard life in a harsh climate/conditions, the spindle corrodes, and the seal also wears a groove in the surface of the spindle. rather than replace the spindle, you can sleeve it with an ultra-thin sleeve to restore the seal surface.
Old 01-29-2011, 08:05 AM   #7 (permalink)
jopickens's Avatar
Member # 126456
Old thread... anyone have part #s to post for the d60 front spindle speedy sleeve?
jopickens is offline   Reply With Quote Quick reply to this message
Old 05-20-2011, 07:59 PM   #8 (permalink)
Member # 108341
i'm still searching but anyone for front spindle of a ford 60?? theres a grove on mine. will it hurt anything?
Stoodty is offline   Reply With Quote Quick reply to this message
Old 05-20-2011, 11:27 PM   #9 (permalink)
Stephen's Avatar
Member # 2092
Try these: http://offroaddesign.com/catalog/14b...raxleparts.htm
The sleeves are not always that reliable, these seals are nice and way cheaper to try. We haven't checked size for a D60 but they're good for the 14 bolt and the gm D70 hubs.
edit, just saw you're looking to fix a front. You should probably consider just buying a new spindle if its that bad, unless we can find a cool seal that fits. New pricing varies but they're about $130.
can you change the seal depth to miss the grooves?
Stephen Watson
Alpha Base in the quest for fullsize GM offroad world domination.
6 years of KOH/U4 racing
10 Ultimate Adventures
Official Canoeligan
Stephen is offline   Reply With Quote Quick reply to this message
Old 05-21-2011, 07:48 AM   #10 (permalink)
Member # 108341
the groove is right in the middle of the seal surface and all the way around. i'm almost sure i'll need a new spindle. i was just trying to save some cash.
Old 05-21-2011, 09:54 AM   #11 (permalink)
gutt_72's Avatar
Member # 36265
I was amped to see a a post from Wolf359 back up, I thought maybe he finally finished his buggy. Alas, just a necro-post.
pull your flatbill down over your ears, pull your black socks up, and the whole world goes BRAAAAPPPP!!!!!!!!
gutt_72 is offline   Reply With Quote Quick reply to this message
