Rockwell (non-2.5-ton) Specs? - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 07-08-2003, 09:33 AM   #1 (permalink)
Member # 7247
Send a message via AIM to GO 4LO
Anybody know of any websites that list the specs for the entire line of Rockwell axles? I've got some 3-ton Planetaries that I'm trying to find some details on. Thanks.
Chris
99 TJ on 40's - trailrig
01.5 Dodge 2500 qc sb 4x4 Cummins - towing/dd
96 Dodge 2500 xc lb 4x4 Cummins - sledpulling
93 Dodge W250 rc lb 4x4 Cummins - racing
97 LT1 Firebird - dd
GO 4LO is offline   Reply With Quote Quick reply to this message
Old 07-08-2003, 11:36 AM   #2 (permalink)
Member # 7247
btt
Old 07-08-2003, 01:57 PM   #3 (permalink)
www.patparts.com
patooyee's Avatar
Member # 4821
Can't help you, but I'd like to see pics of those axles if you got them.
J. J.
Old 07-09-2003, 06:20 AM   #4 (permalink)
Member # 7247
See if this works...
Old 07-09-2003, 06:24 AM   #5 (permalink)
Member # 7247
Here's another - those are 36/12.50/15 TSL's, for reference.
Old 07-09-2003, 06:51 AM   #6 (permalink)
JOHNS351C's Avatar
Member # 8282
Chris I couldn't open that file you sent of those axles.
But I can see them now. they look prety cool. See if you can get me the diamiter of the disk and how far the caliper sticks out past the edge of it.
The ram setup is prety unique they should hold up just fine being a planitary.
I dont know if you can use that center mount on top or not.
John
[SIZE=4][COLOR=DarkOrange]Stazworks[/COLOR][/SIZE]
[B]The leader in Custom Double Beadlock wheels[/B]
On SALE NOW [COLOR="DarkOrange"][SIZE="2"][I]20x14's[/I][/SIZE][/COLOR]
Due to NEW tooling we can now build std. 1pc 20x14's, and up to a 20x25's without banding!
[COLOR=DarkOrange]
333-RIMS,(7467) shop number
(715) 333-7250 office
John Staszak-owner
JOHNS351C is offline   Reply With Quote Quick reply to this message
Old 07-09-2003, 07:03 AM   #7 (permalink)
Member # 7247
John, the file was around 4Meg with all four pics in it, so it may have just been too big to go through. A couple other guys had trouble seeing them too.
The bolt pattern is 8 on 15 or 8 on 15.5 (something around there). The discs look to be approximately 19.5" diameter. Travis said he got 20" rims to fit, though (perhaps just by using really low backspacing - I don't know?). Not sure if you could make something to fit or not?
Travis also told me that each of the rams is a two-way Ram, so each axle could actually get by with just one of them.
Chris
Old 07-09-2003, 07:17 AM   #8 (permalink)
JOHNS351C's Avatar
Member # 8282
I will call travis and find out what happened when he tried it.
I would run botrh rams since you have them. Is it possible to make the disk a smaller diamiter and move the caliper in more?
John
[COLOR=DarkOrange]
John Staszak-owner
Old 07-09-2003, 07:23 AM   #9 (permalink)
www.patparts.com
patooyee's Avatar
Member # 4821
What are you planning on putting those into? They look like the ground clearance is a bit low for a 4x4 app.
J. J.
Old 07-09-2003, 07:26 AM   #10 (permalink)
Member # 7247
John,
Travis told me he runs Toyota calipers and made the rims using stock 3-ton Planetary wheel centers on double-beadlock military wheels.
Patooyee, the axles will be going under a stretched TJ with 16.00R20 XL's.
Chris
Old 07-09-2003, 07:38 AM   #11 (permalink)
Member # 7247
John
I'll look at this - it may be possible. The rotor is very thick and is solid so you might be able to trim it?
Chris
Old 07-09-2003, 07:49 AM   #12 (permalink)
JOHNS351C's Avatar
Member # 8282
So that is not a stock brake setup? Travis put that on it using a toyota caliper?
John
[COLOR=DarkOrange]
John Staszak-owner
Old 07-09-2003, 07:51 AM   #13 (permalink)
Member # 7247
Sorry - I wasn't very clear. Travis runs 3-ton Planetaries on one of his buggies. On his, he runs Toyota calipers. Mine still have the stock calipers on them. He said the Toyota stuff saves a lot of weight and works fine for him, due to the dia. of the rotor.
Chris
Old 07-10-2003, 07:13 AM   #14 (permalink)
Member # 7247
Another shot next to a 2.5-ton Rockwell for comparison...
Old 07-10-2003, 09:12 AM   #15 (permalink)
Member # 2046
So, seeing as how the hubs have planetary reduction, what is the final ratio between the diff and the planetaries? Also, what does that sucker weigh?
1987 Dodge Raider - Stock except for 30" tires
340K miles and counting
Toygeek is offline   Reply With Quote Quick reply to this message
Old 07-10-2003, 09:54 AM   #16 (permalink)
Member # 7247
I was told 8.76:1 (4.6x:1 just in diff), ~900 lbs. I'm going to pull apart the Planetaries and check the gearing for myself, though, one of these weekends.
Chris
Old 07-10-2003, 10:17 AM   #17 (permalink)
Member # 7882
900 lbs for ONE axle....you gotta be nuts....that thing literally is a boat anchor....another thing is make sure that it is a standard directional pinion.....make sure the pinion turns the same way to drive your wheels forward...some of those things are screwey....
My life from my phone's perspective.
spencurai is offline   Reply With Quote Quick reply to this message
Old 07-10-2003, 10:31 AM   #18 (permalink)
Member # 13457
GO 4LO, those axles are nice...i brought them to Travis's house for em. They are huge, with those in the bed of my truck, CTD3500, it was ridin low! Good luck and keep us posted.
tradin1 is offline   Reply With Quote Quick reply to this message
Old 07-10-2003, 10:35 AM   #19 (permalink)
Member # 7247
Any chance you know who I might contact then to find more info? Thanks .
Chris
Old 07-10-2003, 11:49 AM   #20 (permalink)
Member # 12967
Send a message via AIM to rEdNEcKwHeE1eR
These axles are with out fiddy trees
[B]
[/B]
Redneck is not a style, fashion, or something that occurs due to location Ė Itís way of life. You canít be one - either You Are or You Arenít.
I AM. ~ SilverZuk
rEdNEcKwHeE1eR is offline   Reply With Quote Quick reply to this message
Old 07-10-2003, 01:46 PM   #21 (permalink)
Member # 13351
Those being ex military axles, shouldn't you be able to get an
Army maintenance manual with all the stats for 'em somewhere? Maybe someone that works in a motor pool at a base somewhere could help...
bb93yj is offline   Reply With Quote Quick reply to this message
Old 07-10-2003, 06:48 PM   #22 (permalink)
steve gerstner's Avatar
Member # 12741
Send a message via Yahoo to steve gerstner
Re: Rockwell (non-2.5-ton) Specs?
Chris
  • The rockwell info. # 800-525-3500, this will get you to the axle div., have all your axle # ready , great poeple. steve differential eng. inc. here's a pic
steve gerstner is offline   Reply With Quote Quick reply to this message
Old 07-11-2003, 05:43 AM   #23 (permalink)
Member # 7247
Thanks, Steve! Is that a 5-ton housing? Looks good to me .
Chris
Old 07-11-2003, 07:12 PM   #24 (permalink)
Member # 12741
This a rockwell axle front 9,000 lbs. from a F800 narrowed for a pickup. steve
