co2 regulators - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 07-28-2003, 10:48 PM   #1 (permalink)
Member # 18684
co2 regulators
I am making a powertank clone to air up tires and run air tools and need a co2 regulator, is there anything special I need to get? Do I really need an adjustable one or should I get a fixed one? We have several tanks so I don't think i need the tank pressure guage. I have heard it is useless anyways. What pressure should I get for the fixed one? Thanks for the help!
LUBA is offline   Reply With Quote Quick reply to this message
Old 07-28-2003, 10:52 PM   #2 (permalink)
Member # 2892
Send a message via AIM to Pavement Pounder83 Send a message via Yahoo to Pavement Pounder83
i got a 90psi set regulator mainly cuz i am running an arb. if u plan on runnin air tools u prolly want to go higher.
Drew
Drew Reynolds
[SIZE="4"][COLOR="Red"]ECV 7-11[/COLOR][/SIZE]
1991 Toyota Ex Cab
All Stock
1993 Xr650L
[COLOR="Red"]
[/COLOR]
Isautia[88:54] Delta World, Town: PBB Broski
Pavement Pounder83 is offline   Reply With Quote Quick reply to this message
Old 07-28-2003, 11:04 PM   #3 (permalink)
Member # 18684
Yeah but how high is too high? I am planning on airing up 35" tires and running a 1/2" impact mainly. I have seen fixed regulators at 100, 120, 140, 150?????
Old 07-28-2003, 11:38 PM   #4 (permalink)
SeaBass44's Avatar
Member # 40
Drew
Air tools are not ment to be run higher then 85-95psi
# 530.532.4529
TTC 2010 1989 BRONCO
-Awesome web development for your business.
SeaBass44 is offline   Reply With Quote Quick reply to this message
Old 07-29-2003, 12:01 AM   #5 (permalink)
DiscoDino's Avatar
Member # 15296
If they work in the 85-90 range, can't we just use the ARB compressor then?
'83 D130: 54" TTCs or 42.5" Boggers, OEM RW2.5s, Stazworks, LQ4, Atlas, dual M8274-50s, mid-mounted 9.5xp-s, dual 16" ORIs, PRP seats, etc...
'91 D110: 36" Iroks, R380, 2wd conv, underdrive, ARBs, 30 spl front, Sal D60 rear, caged, Fox remote reservoirs, M8274-50, and P&P exo-cage, etc...
DiscoDino is offline   Reply With Quote Quick reply to this message
Old 07-29-2003, 12:03 AM   #6 (permalink)
Haole's Avatar
Member # 5859
not enough air flow to run a tool off an ARB compressor.
Ka 'aina uluwehi, ko kakou
kuleana.
- The lush life-giving land, our personal responsibility.
- Darlington County Chapter
Haole is online now   Reply With Quote Quick reply to this message
Old 07-29-2003, 12:58 AM   #7 (permalink)
SeaBass44's Avatar
Member # 40
Volume, air tools need aprox 4cfm, and the arb will not pump anywhere near 1/2 that My home 3 hp 11 gal tank can't keep up with air tools, it's a lil shy of 4cfm at 90psi
# 530.532.4529
Old 07-29-2003, 03:17 AM   #8 (permalink)
Member # 3455
Send a message via ICQ to MoonDog
I have a 100psi fixed pressure regulator on my co2 tank. It seems to drop to 85~90 psi when the air really starts to flow, and I haven't had any problems running my impact gun on it. $27, call around to some welding supply places near you.
'84 Toyota HooptieRunner
MoonDog is online now   Reply With Quote Quick reply to this message
Old 07-29-2003, 05:37 AM   #9 (permalink)
indulf's Avatar
Member # 6156
i use a 120psi fixed regulator on my tank.
it drops to almost exactly 90psi when Im running tools on it.
i got it here:
http://www.williamsballoons.com/co2_regulators.htm
got the 150male with a 120psi spring. cost 40 bucks.
got the tank from some online aquarium supply place, dont remember the name.
here's a good source for bottle brackets:
http://www.lhrservices.com/fire_figh...r_brackets.htm
"whatever doesn't kill me postpones the inevitable"
92 xj, 01 xj, 09 kawasaki versys
indulf is offline   Reply With Quote Quick reply to this message
Old 07-29-2003, 08:21 AM   #10 (permalink)
Member # 5488
another source for regulators and all CO2 stuff...
www.cramerdecker.com
150 PSI regulator with permanent O ring, $21.00
They also have aluminum tanks, brackets, etc.
Tony TLCA #5049
Thieves suck.
TRT2 is offline   Reply With Quote Quick reply to this message
Old 07-29-2003, 09:16 AM   #11 (permalink)
DriveTime's Avatar
Member # 16582
If you're looking for a cheap tank, go to any fire extenguisher place and ask if they have any old SCBA bottles.
'81 Chevy - 350/TH400/T-136-27/Rockwells/16.00R20 Michelin XZLs/Wheel brakes
DriveTime is offline   Reply With Quote Quick reply to this message
