Flaring metal fuel lines....for rubber hose - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 09-20-2003, 04:57 AM   #1 (permalink)
Member # 19579
I'm fully aware of a flaring tool that flares metal lines to accept compression fittings.
(similar to this)
http://www.stu-offroad.com/misc/images/ft-0.jpg
I'm not looking for information about these.
But is there a flaring tool that will put *barb* like flares on metal tubing to accept rubber hose?
Reason I'm asking - On a my Jeep, the fuel filter has a plastic casing with a plastic barbed end that mates up to rubber fuel line (a hose clamp holds the rubber line). This rubber fuel line also mates up to the hard line on the frame rail. I haven't had this apart - but I can only assume there is some type of barb at the end of the hard line which prevents the hose from sliding off after adding a hose clamp.
Wondering if I can cut off a few inches of hard line (easily) for more clearance piece of mind (relocating the fuel filter).
Izzy II: Lifted, locked, and ready to rock!!
Janster is offline   Reply With Quote Quick reply to this message
Old 09-20-2003, 08:21 AM   #2 (permalink)
The Piratenite
camo's Avatar
Member # 4
Send a message via Yahoo to camo
yes there is a tool.
call these guys http://www.irvansmith.com/
thay have a tool that will put a little ripple in the hard line to hold the hose on.
think of a aluminum radiator inlet that has the little raised ring on the tube.
Millennials, making hippies look tough since 1980
camo is offline   Reply With Quote Quick reply to this message
Old 09-20-2003, 08:25 AM   #3 (permalink)
Member # 7163
I don't know why you'd bother. I have a high pressure EFI line clamped onto a 'flat' hardline and it works fine. I double clamped it with 180 degree offset EFI clamps, just in case.
Bryan
Oxjockey is offline   Reply With Quote Quick reply to this message
Old 09-20-2003, 08:53 AM   #4 (permalink)
Member # 18936
Bryan
I have seen these fail all to often. At least flare the end of it so it doesnt come shooting off at the worst possible time. When it comes to gas i dont mess around. I value my life and my rigs way to much!
geepincj7 is offline   Reply With Quote Quick reply to this message
Old 09-20-2003, 09:21 AM   #5 (permalink)
Member # 6529
I just use a regular flaring tool. Instead of flaring the end first, I just put the double flare adapter in right away and make a "bubble" on the end of the tube.
zags is offline   Reply With Quote Quick reply to this message
Old 09-20-2003, 12:31 PM   #6 (permalink)
Member # 13786
Why not flare the end with a 'nut' on it then install a barbed hose fitting?
KWTMECH is offline   Reply With Quote Quick reply to this message
Old 09-20-2003, 04:46 PM   #7 (permalink)
Member # 19579
There is no nut.....
There are no compression fittings on the fuel filter - just straight hard line and rubber hose.
Old 09-20-2003, 05:32 PM   #8 (permalink)
Member # 4783
Just use a combo ferrule type compression fitting with NPT threads on the other end and then use a NPT/barbed fitting for the rubber line. Might be a whole $5 in parts.
Pin Head is offline   Reply With Quote Quick reply to this message
Old 09-20-2003, 05:58 PM   #9 (permalink)
Member # 1557
We use these these daily in an aircraft mod shop.
Kind of pricey but will last and give you perfect tube beads
http://www.aircraft-tool.com/shop/de...ODUCT_ID=AP145
rich
Buggified 77 cruiser.....
03 CTD 3500 HO 6sp QC dually
MetalMender is offline   Reply With Quote Quick reply to this message
Old 09-20-2003, 06:06 PM   #10 (permalink)
Member # 14364
This works great. Just stop after the bubble is formed don't go as far as you would for a flare.
bobdog is offline   Reply With Quote Quick reply to this message
Old 09-20-2003, 06:07 PM   #11 (permalink)
Member # 5110
I'm with zags on using a double flairing tool and just doing the first step...
But these are about as cheep as it gets for anything larger
http://www.holley.com/HiOctn/ProdLin.../TubeBead.html
Link to thread on my calculator http://www.pirate4x4.com/forum/showthread.php?t=204893
Triaged is offline   Reply With Quote Quick reply to this message
Old 09-20-2003, 07:53 PM   #12 (permalink)
Member # 13786
I am talking about the nut that comes on the end of the tubing in the stores. You can buy these separatly and can buy a fitting that threads on.
