Rubicon Air Locker? - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 01-14-2004, 08:21 AM   #1 (permalink)
GOAT1's Avatar
Member # 5969
Rubicon Air Locker?
Anyone use a rubicon air locker in any regular dana 44 housing and gears, is there anything different about them? Also anyone know what pressure they take to opperate? I am getting a whole housing for free so I'm seeing what my options are.
GOAT1 is offline   Reply With Quote Quick reply to this message
Old 01-14-2004, 08:45 AM   #2 (permalink)
Member # 21180
Inside these Dana 44s, you’ll find front and rear locking 4.10:1 differentials built by Tochigi Fuji Sanjyo, chosen, according to Jeep engineer Jim Repp, “because they were the only ones we couldn’t break.” These lockers, which can be actuated at speeds up to 10 mph, require 5 psi to make them work. When the lockers are unlocked, they are limited slip units...
EDIT: only rear is limited slip in unlocked condition!!!!
I found this info on........
http://www.fourwheeler.com/featuredvehicles/77698/
KC_JoNeS is offline   Reply With Quote Quick reply to this message
Old 01-14-2004, 08:55 AM   #3 (permalink)
GOAT1's Avatar
Member # 5969
Thanks, that cutaway is cool. I thought that the rear is a LSD when unlocked and the front is open. Can anyone confirm? They use two little air compressors, one for each diff, mounted next to the T-case. I was thinking about just buying one of those to operate it. Has any one replaced one or know how expensive they are?
Old 01-14-2004, 08:59 AM   #4 (permalink)
Member # 21180
Drew, are you planning on just using the locker in your existing D44? Or are you planning a full out swap?
And yeah, looking at that article, it shows the cut out of the rear locker and says it is limited slip. So I stand corrected. I guess the front is not. My mistake. But I would bet that the rear would work fine in front.
KC
Old 01-14-2004, 09:20 AM   #5 (permalink)
GOAT1's Avatar
Member # 5969
I just want to use the locker in my current 44.
Old 01-14-2004, 09:59 AM   #6 (permalink)
P&T Jeeps's Avatar
Member # 3916
I believe the carrier specs are totally different. I know they are at least for the R&P.
TJ; ARB'd & ChroMo'd 1-tons; 42" IROK's; Atlas 4.3; 4-linked, 106" WB...
P&T Jeeps is offline   Reply With Quote Quick reply to this message
Old 01-14-2004, 10:01 AM   #7 (permalink)
Member # 21180
Originally posted by P&T Jeeps_
I beleive the carrier specs are totally different. I know they are at least for the R&P.
So, why would there be a problem with taking that assembly and using it in a later model 44 housing? Worst case scenario, Drew will have to do some grinding.....right?
Old 01-14-2004, 10:05 AM   #8 (permalink)
braxton357's Avatar
Member # 14685
Send a message via AIM to braxton357
Yeah...if you can grind to within .0001"
In vino veritas
73 linked 5.8efi Bronco
99 QCLB 4x4 twin'd cummins on meth.
braxton357 is offline   Reply With Quote Quick reply to this message
Old 01-14-2004, 10:05 AM   #9 (permalink)
kwrangln's Avatar
Member # 6971
Pretty sure the rubi's ring gear is thicker than a standard 44 set. Have heard of people making spacers in order to regear the rubi axles. Try a search to be sure.
I'm the "tack tack tack" welding nazi.
:flipoff2:
"I didn't mean to kill nobody ... I just meant to shoot the sonofabitch in the head. Him dying was between him and the Lord." R. L. Burnside
kwrangln is offline   Reply With Quote Quick reply to this message
Old 01-14-2004, 10:06 AM   #10 (permalink)
Member # 21180
Well, Drew is rather talented.
Old 01-14-2004, 10:19 AM   #11 (permalink)
GOAT1's Avatar
Member # 5969
Any machine work to the carrier would not be a problem. But I talked to the guys at Supior Axle and gave me all the info. The problem is they use the ring gear offset for faster gears so the you would need a thicker ring gear or a spacer to run my current 4.88's. I guess Yukon makes a special gear set for a Rubi for this but I have a high pinion so I'm screwed unless I run a spacer.
Old 01-14-2004, 10:39 AM   #12 (permalink)
Member # 940
You might have to run the gears made for a Rodeo. They are a high speed carrier and you can get gears up to 4.56 "I think" for them.
Tanlking out my ass here......
Deep Cryogenic Tempering Service
Find all my products at
916-434-6978
Custom Sway Bars and Axles built to order.
Got 40 spline? I have the hubs, spindles, and axles you need to kickass!
Custom Hummer wheels and centers
Axle Resplining
66CJdean is offline   Reply With Quote Quick reply to this message
Old 01-14-2004, 11:40 AM   #13 (permalink)
Blackjack's Avatar
Member # 165
Send a message via MSN to Blackjack
Front is open when off, rear is the planetary limited slip. Not sure about the compressors, other than the stock location on the RUBI is not good for here in AK.
Blackjack is offline   Reply With Quote Quick reply to this message
Old 01-14-2004, 07:42 PM   #14 (permalink)
Member # 187
your parts will work just fine they are no different your gears your carrier and it will work trust me
GearMan is offline   Reply With Quote Quick reply to this message
Old 01-14-2004, 08:26 PM   #15 (permalink)
In GOD we trust. USA
NoJoke's Avatar
Member # 15480
The gears are "thick gears" and the lockers work at 5 psi.
I'm not too sure by how thick "thick gears" is but places like Randys has a separate part for the rubicon 4.88's I believe.
<-- AVATAR for Concealed Carry Weapons permits in the U.S. over time: No issue / May issue / Shall issue / Constitutional carry- No restrictions / FROM 1986 to today
NoJoke is offline   Reply With Quote Quick reply to this message
Old 01-14-2004, 10:59 PM   #16 (permalink)
Haole's Avatar
Member # 5859
IIRC, Rubi's are a type three and "normal" 44's are a type four. Whatever the hell that's supposed to mean besides the parts don't interchange.
Ka 'aina uluwehi, ko kakou
kuleana.
- The lush life-giving land, our personal responsibility.
- Darlington County Chapter
Haole is offline   Reply With Quote Quick reply to this message
Old 08-02-2005, 11:15 PM   #17 (permalink)
Member # 19446
Send a message via AIM to ?????
Goat and Gearman, this is exactly what I'm trying to do. Have either of you done this? I've got a front Rubicon locker and want to put it in a high pinion d44 housing with reverse cut 4.88 gears. So far I haven't had any luck finding an answer on how or even if this will work.
If you did it, can you tell me exactly what ring gear, ring gear spacer, machining, etc that you needed to do it, and where you got the parts from.
????? is offline   Reply With Quote Quick reply to this message
Old 08-03-2005, 07:15 AM   #18 (permalink)
GOAT1's Avatar
Member # 5969
I gave up on the idea and will just use the complete rubi housing in something else. I popped the cover and it definately uses a thick ring gear. I think your only option is to use a ring gear spacer. I dont know where you would get one though, most of the major gear and diff suppliers should have them.
Old 08-03-2005, 04:29 PM   #19 (permalink)
Member # 19446
Damn...this swap is looking less and less possible.
Someone needs to make a high pinion dana 44 housing with the cast in UCA that will fit a rubicon locker, and a reverse cut thick 4.88 ring gear. I know a bunch of guys with Rubicon's would buy the housing.
Old 08-03-2005, 04:48 PM   #20 (permalink)
GOAT1's Avatar
Member # 5969
Jeep has made that housing for a long time, all the South American TJ's have a hi pinion 44 housing stock. Currie bought a whole container of them and were reselling them. The rubi housing is not any different than any other 44's, it is just the locker is made for 3.31 gears, not 4.10's hence the special thick ring gears.
Old 08-03-2005, 05:47 PM   #21 (permalink)
DSI
DSI's Avatar
Member # 920
Send a message via Yahoo to DSI
there is one other difference in a rubi housing... when i worked for SOR we put a rubi 44 housing into a TJ for a customer, and used an ARB, it needed about an extra 100thou of carrier shim per side to get the bearing's tight. so without machine work, i don't know that the rubi locker would fit the standard case, and yes, the deck is just a 3.73 carrier.
I like Pizza Steve...
DSI is offline   Reply With Quote Quick reply to this message
Old 08-03-2005, 06:59 PM   #22 (permalink)
Member # 19446
The ring gear spacer itself doesn't seem that hard to make. If I knew the dimensions, could I just get any machine shop to make one for me? How wide will it need to be for the 4.88 ring gear?
Old 08-03-2005, 07:02 PM   #23 (permalink)
Member # 19446
What about this?
"The .100" Milled On Each Side Of The Housing Is For Outside Shims. The Ruby Locker Is Not Designed To Use Shims Under The Bearings. The Bearings Will Stick Out .030"-.040" On Each Side And Will Cause Early Failure Of Bearings Or The Carrier. I Have Seen This And The Carrier Will Break Under The Bearing. When This Happens The Carrier
Loads-twists In Housing And Usauly Breaks More Stuff. I Have Also Seen The Air Line Not Clear The Bearing And Cap." 4-banger
Does he have a valid point, or is that bs?
Old 08-03-2005, 07:06 PM   #24 (permalink)
TR
TR's Avatar
Member # 2877
dont forget the rubi uses bigger ring gear bolts than a normal 44 too.
Penn State study finds that heavy drinking is 100% easier than giving a shit
TR is offline   Reply With Quote Quick reply to this message
Old 08-04-2005, 06:30 AM   #25 (permalink)
Member # 42139
If I were to swap in a RUBI front 44. Do they make chromo shafts for it? Could I get 4.88 or 5.13 for it? Warn hubs for it? It is HP correct? And does anyonre know the width? Thanks
appx91 is offline   Reply With Quote Quick reply to this message
