Member # 7352
Yukon 4340 drops available for testing...
This has been a while ago, but in this post alot of people expressed an interest in seeing some independant test results on the Yukon 4340 stuff. I don't have drops from a 60 shaft, these are from some D44 blanks a friend of mine cut and resplined for me. I am willing to ship these to a vendor who would like to test the hardness, or composition if they can/want. I know the composition would be expensive to analyze. Sorry, but I can only offer up the drops, in order to help satisfy some curiosities. I searched to see if anyone had followed this up yet, but noone has, at least not publicly.
Here is a pic of the drops: Here's a few pix of the splines, JD does great work every time! I gotta say that Ted from Peake Empire has EXCELLENT customer service and gave me damn good hook up by being able to get these blanks. Lemme know if anyone wants a drop.
Always workin' on it or at it. |
Member # 3916
I've got the 14th of March marked on the calander, likely Hot Springs or Gilmer...
how was the trip last weekend to KAT, worth going back?
TJ; ARB'd & ChroMo'd 1-tons; 42" IROK's; Atlas 4.3; 4-linked, 106" WB... The Build |
Member # 5639
I can check with one of my met buddies at school and see if he would be interested in doing this for ya.
On second thought what do you want to test? The composition should be 4340, Carbon - 0.43, Manganese - 0.74, Phosphorus - 0.006, Sulfur - 0.002, Chromium - 0.77, Nickel - 1.81, Molydenium - 0.24 and Copper - 0.19. That hardness should be fairly easy to test for as alot of machine shops will have a RC tester. What else did you want? Probably cheaper to have it done localy then ship it out.
Just Add Lightness I'd rather be simple-and-wrong than complicated-and-wrong. Last edited by Weasel; 02-11-2004 at 09:48 PM. |
Member # 7352
I went to Clayton since noone from here could go to Katemcy, met up w/some of the Black Sheep. They were building, running some trails on the new place that became available up there. It was badass. Friday, finished building a 5 trail. Hard work getting the group out by 9PM that night. Mike Green knows how to cut trails
Saturday, I spent about 6 hours in a flooded creek crawling serious rocks behind 4 rigs with 44's. Finished the rest of the day on some rocky uphill washes strung together. Sunday, blew the end cap partially off my saginaw box on a trail they call 8point due to the turns involved. What a BITCH. Had to do front digs basically all the way out in order to be able to steer at all. Great trip. Broken: My Ramsey 9500, Saginaw box, Dash , turn signal , and my tub is dented so bad I can't install my windshield. I wanna go back in May. I am gonna be a daddy around March 6th, so I will have to miss that trip with you . Weasel, I was kinda looking to see if one of the more capable shops that float around on PBB wanted to verify composition/hardness on their own. I understand that is what 4340 is"supposed to be", but there were some doubters on here who sounded like they didn't trust the original source. I personally DGAF. I just thought I would be nice and offer the drops up. My personal testing will be more along the lines of what P&T is talking about . As in when/if/how they break. If your friend wants to check the composition for something school related, that is cool, I'll send it his way. It will benefit all of us here as well maybe.Here is a pic of the Saginaw break. The plate to the right is what I used to move it ahead 4.25". I turned up the pressure in the pump about a year ago. I used to have 2 finger turning . Soon I will have full hydro .
Always workin' on it or at it. Last edited by shelljeep; 02-11-2004 at 10:19 PM. |
Member # 3916
I'm hoping someone takes them, as when I build my D60 front I'm considering on going Yukon rather than Superior to save some $$ but not until there is more consistancy in what Yukon is producing. If they're just heat treated junk I'll pay up for the good stuff....
Member # 5969
I can do a hardness test on them, but a chemical composition test will cost some money, I'll look into what that would cost. Unfortunately, that is the only way to find out what alloy they are.
Member # 7352
Mebbe we can all pitch in? (sounds hard to organize, but I ain't gonna foot the entire bill on something I am only marginally interested in...)
P&T, JD said he could verify the hardness. I could drop it off to him if y'all want. But the hardness test seems like it's less useful than the composition. Hardness could vary from piece to piece, seems more subject to QC than composition. JMO. Goat1, looking forward to what you find out on the comp. analysis costs, thanks!
Always workin' on it or at it. Last edited by shelljeep; 02-12-2004 at 07:58 AM. |
Member # 5969
The chemical composition test is not as expensive as I thought, it is only $30-$40. I can send that out and have it done. I can also acid etch the end to see the case depth and do a hardness test to see the hardness at different depths. PM me and I will give you my address and info. I'll pitch in $10 to have it done, who else is in?
#16 (permalink) | |
Member # 52
Rockzombie Smurf |
#17 (permalink) | |
Member # 3916
#18 (permalink) | |
Member # 5639
Just Add Lightness I'd rather be simple-and-wrong than complicated-and-wrong. |
#19 (permalink) | |
Member # 1007
Or are you just talking shit?
#21 (permalink) |
CMP owner
send me a drop i can have the met. lab check them out at work.
C&M PERFORMANCE MACHINE CNC Laser Cutting Press Braking, H1 Wheel Centers, H1 Rock Rings, 37"Goodyear MT's, 37" Goodyear MTR's, 12 Bolt, 24 Bolt Wheels, Yukon Gear Distributor, Fabrication Parts and Accessories. |
#22 (permalink) |
CMP owner
I just had them test a spider from a 14 bolt for my 14 bolt mini spool material and hardness. And its FREE
#23 (permalink) | |
Member # 5969
#24 (permalink) | |
Member # 3916
I'm interested in the tests of the materials & real world tests PBB members put them through that's all. I've got no desire to spend less $$ twice; I'd rather spend more once, ONLY if it is necessary...
#25 (permalink) |
Member # 7352
Right on Mad Mac!! You will get the other drop, then. You aren't affiliated with The Mac, are you? I'm guessing we would rather have 2 INDEPENDENT labs carry out the tests, am I right, fellas? B/T/W-No offense to The Mac, this may be a way to verify his company's alledgedly questionable QC on these items.
Pssst : P&T, I think Eric D was jumping on the strongman that time, not on you...
Always workin' on it or at it. Last edited by shelljeep; 02-13-2004 at 07:27 AM. |
