Dana 60 mini spool - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 02-27-2004, 07:31 PM   #1 (permalink)
Member # 10345
Send a message via AIM to Deadman514
Dana 60 mini spool
did a search -here and everywhere else -can't seem to find one/info on one.
Lookin for a mini spool for a 35 spline Dana60. Want to be able to yank it out for the winter without having to reset the gears.
78 Bronco, 4"suspension-3"body lift
42" Swampers on Eaton 8 lugs, Performance Unlimited Rockproof steering/trac bar, Westtexasoffroad Steering box -modified Saganaw pump and Redneck Ram.
514 stroker, Edelbrock 750 carb, Jacobs ignition & wires, Fluidampr, Pete Jackson gear drive
6" K&N w/x-tream top,L&L underdrive pulleys,
L&L headers,Dual Flowmasters, B+M C-6, TCI Truckmaster TC, All Aeroquip
braided stainless hoses, Dual Optimas, Powermaster 140amp alt.
High Angle 1 Ton CV Driveshafts front and rear -now with 1410 joint in the rear and driveline e-brake,
F-350 Booster/master, Braided stainless brake lines,14 bolt 4.56 welded rear with TSM disc brake conversion -Dana 60 front Herculined interior
Deadman514 is offline   Reply With Quote Quick reply to this message
Old 02-27-2004, 08:07 PM   #2 (permalink)
Banned
Member # 27003
Send a message via Yahoo to acprokeith
i want one too this dummasss no-slip is a piece o shat....anybody got some of these i really want one ?????????????
acprokeith is offline   Reply With Quote Quick reply to this message
Old 02-28-2004, 12:59 AM   #3 (permalink)
Member # 11998
Send a message via AIM to BrettM
you can get one cheap here
awshifting.com
BrettM is offline   Reply With Quote Quick reply to this message
Old 02-28-2004, 02:19 AM   #4 (permalink)
Member # 27460
if your gonna spool a dana 60 id highly recomend not using a mini spool. you will destroy a mini spool. You notice how they dont make the cheapie lockers for the dana 60 well you most likely will break the mini spool or cheapass locker. go with a full case spool about two hundski or a detroit or arb. Or as already mentioned if you really wana be a cheapass just bust out the welder and lay some serious amounts of weld on your spiders and lock them up
"Friends Of The Rubicon"
Outlawz 4x4 NORCAL
well it started as a 85 blue ford f250 not sure what to call it now
lentzOUTLAWZ4x4 is offline   Reply With Quote Quick reply to this message
Old 02-28-2004, 07:07 AM   #5 (permalink)
Member # 10345
The price is not an issue -it's that I want to be able to swap it out when the snow season comes and goes. Lookin for the same thing for my 14 bolt -right now I have it welded (don't like the street manners of the Detroit).
Old 02-28-2004, 09:57 AM   #6 (permalink)
Member # 187
well if its not the price go ARB and forget it when you want fun turn it on when fun time is over turn it off trust me ive played a-lot in the snow and there is no better choice then ARBs
GearMan is offline   Reply With Quote Quick reply to this message
Old 02-28-2004, 10:43 AM   #7 (permalink)
Member # 10345
Sorry -wasn't clear. BIG difference between $300 for a locker/spool and $800 for the ARB -which is out for this year.
Old 02-28-2004, 11:07 AM   #8 (permalink)
Member # 5286
Send a message via Yahoo to Jason M
Oh really??
They don't make lockrights for a D60??
Interesting..
DEAR MADAM:
THANK YOU FOR YOUR RECENT ORDER FROM OUR SEX TOYS WEBSITE.
YOU'VE REQUESTED THE LARGE RED VIBRATOR AS FEATURED ON OUR WALL DISPLAY.
PLEASE SELECT ANOTHER ITEM.
THAT'S OUR FIRE EXTINGUISHER
Jason M is offline   Reply With Quote Quick reply to this message
Old 07-14-2005, 11:48 AM   #9 (permalink)
Derek K10's Avatar
Member # 43420
i am bumping this up as i am searching for the same thing
anyone who isnt going to be a jackass and tell me to weld it, know where i can get a mini-spool, cause ive driven a fully locked rig on the streets in the winter and it sucks
bone stock MJ on 40s
Derek K10 is offline   Reply With Quote Quick reply to this message
Old 07-14-2005, 12:51 PM   #10 (permalink)
jopes's Avatar
Member # 8469
Send a message via ICQ to jopes Send a message via AIM to jopes Send a message via Yahoo to jopes
no money for the ARB this year then leave it open.
I perfer welding them up myself.
408ci SEFI, 70mm throttle body, 90mm mass air, stang harness, tweecer R/T waiting on a home.
jopes is offline   Reply With Quote Quick reply to this message
Old 07-14-2005, 03:17 PM   #11 (permalink)
Member # 31352
power trax DOES sell a drop in locker for the d60. May be your best bet.
TheRamChargerMan is offline   Reply With Quote Quick reply to this message
Old 07-14-2005, 04:57 PM   #12 (permalink)
Banned
Member # 24704
Yep, I have one, it has survived several hard wheelin' trips without issues. If I ever swap gears I will put in a Detroit, but the LockRight works fine.
Tim84K10 is offline   Reply With Quote Quick reply to this message
