Teraflex Dana 60 front axle!!! - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 03-19-2004, 10:02 PM   #1 (permalink)
Member # 24609
I am ordering a Tera 60 front axle but have a few questions. Let me tell you what I know and what I know I don't know and you guys can tell me what I don't know, I don't know. First off it's going into a 99 TJ with a RE 5.5 long arm w/custom tri-uppers, rear Tera60 4.56 gears, ARB, 35 spline axles, Atlas 5.0, 1410 rear pinion High Angle Drive 1350 CV with there flange. The front will be a ARB locker((( What spline count for the ARB, 35 right ?))) Now the outer shafts should be 35 spline??? and what u-joint??? Teraflex has hubs called a Uniberring??? What knuckles, Tera says they make there own??? High Steer, again Tera says they make there own. I talked to Jess at High Angle and I will be going with a 1410 yoke and his front shaft w/1350 cv.
Jeep TJ - with a few mods....and a TJ buggy project....
matt99tj is offline   Reply With Quote Quick reply to this message
Old 03-19-2004, 10:41 PM   #2 (permalink)
The Piratenite
camo's Avatar
Member # 4
Send a message via Yahoo to camo
unit bearings come stock with 30 spline outer axles. make sure they upgrade it to 35 spline. if they can't .....then buy else where
Millennials, making hippies look tough since 1980
camo is offline   Reply With Quote Quick reply to this message
Old 03-19-2004, 10:56 PM   #3 (permalink)
TNToy's Avatar
Member # 5776
What he said. If they won't build you one with 35 spline stub shafts, you're spending a whole lot of money for relatively little axle.
Old 03-19-2004, 11:02 PM   #4 (permalink)
Supergper's Avatar
Member # 2159
Send a message via ICQ to Supergper Send a message via AIM to Supergper Send a message via MSN to Supergper Send a message via Yahoo to Supergper
well, let me ask this...is there a specific reason you are going with a tera axle...why not a pro rock or the new(er) Rockcrusher? I would go with either of those housings before the Tera...and I dotn care too much for any type of unit bearing (doesn;t Dynatrac use a unit bearing?)...I also bet you could have a shop like Mad4WD build you a Rockcrusher with Dedenbears or Crane knuckles for about the same or maybe just a little more but you will have WAY more strength over a BJ 60...
-Caleb Call
Supergper is offline   Reply With Quote Quick reply to this message
Old 03-19-2004, 11:05 PM   #5 (permalink)
Member # 9222
tell them you want crane inner C's/knuckles/indexed highsteer arms. then you can run 35 spline outers/drive flanges and stock 60 spindles/bearings/etc.
larryboy is offline   Reply With Quote Quick reply to this message
Old 03-19-2004, 11:07 PM   #6 (permalink)
Member # 13410
Send a message via ICQ to TJ Fan Send a message via AIM to TJ Fan Send a message via Yahoo to TJ Fan
Yep...this is what you need..thanks for the props
Phone: 330-549-9082
Custom Axles, CNC Machining (Vertical, Horizontal and Lathe Work), Welding and Bending
TJ Fan is offline   Reply With Quote Quick reply to this message
Old 03-19-2004, 11:17 PM   #7 (permalink)
Keith's Avatar
Member # 52
and just how much does that cost?
Rockzombie Smurf
Keith is offline   Reply With Quote Quick reply to this message
Old 03-20-2004, 01:01 AM   #8 (permalink)
Member # 187
if ya have to ask you must not have AMERICAN EXPRESS with axles 7500$ i bet unless your a "ill do a write up on it guy "
GearMan is offline   Reply With Quote Quick reply to this message
Old 03-20-2004, 10:17 AM   #9 (permalink)
Keith's Avatar
Member # 52
PEN AND PAPER READY BEEEEEEOOOOTCH!
Rockzombie Smurf
Old 03-20-2004, 11:31 AM   #10 (permalink)
tubehead's Avatar
Member # 13221
Send a message via AIM to tubehead
You can do a front with the Crane stuff a little cheaper than $7500. The one in the pic was for a customer of mine for a single seater I'm building for him. The Crane stuff is sweet and worth the money.
Roark Fab Works
Atlas Support Ring
Authorized Spyderco knife dealer
Shooting targets
tubehead is offline   Reply With Quote Quick reply to this message
Old 03-20-2004, 01:53 PM   #11 (permalink)
Member # 24609
So the Crane inner and outer knuckles are the way to go. What u joints??, 35 spline inners and outters but what brand, hubs or drive flange, What brand?? I read the Warn 35 spline outter upgrade tech article, so is that the to go??
Old 03-20-2004, 02:10 PM   #12 (permalink)
Member # 9222
matt,follow the link in this thread...all the answers are within.
http://www.pirate4x4.com/forum/showt...hreadid=233894
Old 03-20-2004, 02:59 PM   #13 (permalink)
Member # 187
i bet its atleast 7500 with GOOD AXLES not stock spicer stuff if it has a ARB in it quick add in the head gives me that and that would be doing it for free
Old 03-20-2004, 05:43 PM   #14 (permalink)
Member # 24609
I did some reading from that link and are the Crane high steer arms not recommended for now?? Are the OTT ones' better and will they fit the Crain knuckle??
Old 03-20-2004, 06:53 PM   #15 (permalink)
Supergper's Avatar
Member # 2159
what do you mean the high steer arms are not rocommended now? IMO, the Cranes with the key are the envy of the industry...at this point you will not get a better setup...
-Caleb Call
Old 03-20-2004, 09:15 PM   #16 (permalink)
Member # 24609
"Overall a good first design from Crane, with an innovative and extremely useful indexing system, that could use some refinements.*** BREAKING NEWS *** Here's the really cool thing - I shared all of these initial opinions of mine with Tim Plamondon, one of the key players at Crane High Clearance (who is, incidentally, a fourth or fifth generation pattern maker [that's a dude who makes things from molten steel!], a heck if a nice guy to talk to, with a keen interest, super technical ability, and great customer service) I also shared with him a few other observations and design ideas I haven't yet published here, as he has agreed to work with me in designing and developing the ULTIMATE D60 high steering arm, one that can truly take it's place beside their great knuckles. Stay tuned - I will post results, impressions, and more testing here as the project progresses." FROM ---- The BillaVista 60 Bomb Proof Dana 60 Pirates4x4.com If you read through the artical he mentions that the thinest part of the steering arm is a 1/2 inch. I got the impression that it was a nice way of saying that maybe one should wait until an improved version is realeased, maybe I read too much into it!
