FATS (Fuel Air Trap System) - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 04-21-2004, 05:41 AM   #1 (permalink)
Member # 8439
FATS as an acronym for the Fuel Air Trap System.
FATS was originally developed last year in an effort to address and help manage the problem of fuel spillage and associated safety issues of fuel spillage during ERoCC off road Rock Crawling Events.
I have recently received several requests to put this rather simple design up on the web and available for use by those who may want to employ it.
Please understand, if you have a better design, good for you! I encourage you to please make it good for me by posting it and sharing your solution with the rest of us.
Here was the specific request, which this design is engineered to help manage.
“What can we do to prevent fuel from leaking from the vent lines on competitor vehicles?
Right now we require a rollover valve and that works ok when vehicles are upside down.
The problem we have is when a vehicle is laying on its side or climbing a hill we get some pretty serious leaks. I am trying to come up with a way that will prevent this as inexpensively as possible.”
I believe you will find FATS a low cost easy to implement solution that will provide the function needed to resolve the safety and environmental issues you are dealing with.
If you think this idea has merit please feel free to distribute this document to the other folks for their comments and input. I’m sure with other’s input we can collectively fine tune this and make it even more effective.
FATS Functional Design
FATS employs a simple plumbers trap principle (Like your kitchen sink drain.).
Please take a look at the drawing below.
You will see a fuel tank having one Vent/Valve on top. Attached to the Vent/Valve is a length of fuel hose. The fuel hose is routed in a “specific pattern”. This pattern forms a Fuel/Air Trap when the vehicle is on its side.
The fuel line is terminated with a standard FRAM metal canister fuel filter.
That’s it!
That’s the entire FATS system.
Total cost about $15.
Fuel Hose Routing
The fuel hose must be routed in an easy to do, yet specific way.
From the vent/valve the hose extends to the left past the left side of the fuel tank on a slight angle past horizontal (See reference to horizontal and vertical reference lines.).
Once past the end of the tank, the fuel line is routed upward, again not quite vertical, but angled slightly.
Again the hose is routed to the right, completely over and past the right end of the fuel tank (Not quit horizontally).
And then lastly the hose is routed downward to a level close to (or below) the bottom of the fuel tank.
Hose routing is vital, for this routing is what makes the FATS design work.
Again, hose routing attributes are:
· Left-to-Right or Right-to-Left hose routing must always extend Past the Sides of the Fuel Tank.
· Vertical and Horizontal hose routing must not be square, but rather sloped so as to allow any fuel in the lines to drain back to the tank.
· Hose should terminate as close to the bottom of (or below) the fuel tank.
Fuel Hose Termination
The fuel hose should be terminated with a metal canister fuel filter similar to the FRAM G6567. This filter has both input and output fuel line nipples on the same side of the canister. The canister has a metal tab, which can be used to bolt the filter onto the frame.
The metal canister fuel filter will provide storage for any fuel in the attached line, if and only if a vehicle on its side (and the vent/valve is leaking) continues on into a complete roll over situation. (Without FATS in place this fuel would spill as it does now when the vehicle is on its side.)
Here is a simple drawing to show what these FRAM filter looks like.
Please note the FRAM Fuel Filter only comes into play during a full roll over. It is installed on the end of the fuel line to catch any fuel that may or may not be in the fuel lines.
I have physically measured this. This fuel filter can, can hold the volume of fuel found in 12-feet of 3/8-inch (I.D.) fuel line before spilling over.
FATS Operations
Let’s roll the vehicle over to the left, past 90 degrees and take a look at what happens.
If the vent/valves leak fuel in this position, the fuel runs into the fuel hose attached to the vent/valve, but cannot exit to the environment because of the fuel hose routing, which forms the trap.
The fuel level in the hose can only reach the vertical height of the fuel in the tank. (Physics says so.).
When the vehicle is up righted any fuel that may or may not have gone into the fuel hose will flow back into the fuel tank via gravity and the slope of the hose routing.
Here is another drawing of a vehicle rolled to the right.
Again, the fuel, which leaks past the vent/valve, can only reach the height of the fuel level in the tank. When the vehicle is righted, the fuel in the hose will flow back into the tank.
The metal fuel canister comes into play if and only if all these situations happen.
IF;
The vehicle rolls to the left or right
AND
The vent/valves Leak
AND
The vehicle continues to roll over completely
THEN;
Some fuel inside the fuel hose will flow into the metal canister filter when the vehicle is up righted.
ELSE;
All fuel flows back into the vehicles fuel tank
Practical Application
Here are a few simple drawing that show how the FATS design could be implemented on a vehicle. Please note I am showing how I would address this for a fuel tank having two vent/roll over valves link my Jeep has.
One hose (Blue) is routed on an angle from the left vent/valve to the right side roll bar upright. From there it is routed up and then across the roll bar and down the left upright. Terminating in a FRAM metal canister fuel filter. The second FATS hose attaches to the second vent/valve with similar but opposite routing.
Here’s what it would look like.
Let roll it to the left.
See! No Fuel Spillage!
Want to see what happens if it rolls to the right?
Print this off and rotate the paper! J
Actually that is a very good thing to do. Print and rotate the paper and test out all possible scenarios. I think you will see the Fuel Air Trap will work in any position, provided the hoses are routed as described. (Read that Hose Routing, though simple is vital to performance.)
I hope you find this helpful. If one person or Team is helped to be safer through its use then it was well worth the little bit of time to develop, document and post here.
Have a great day, I plan too!
Frank
Frank D.
Daless2 is offline   Reply With Quote
Old 04-21-2004, 08:38 AM   #2 (permalink)
Jerry Blair's Avatar
Member # 10761
Frank,
Thanks again for your help with FATS. It worked great on several comp rigs during last year's ERoCC events.
I am currently routing this setup in my own trail-only YJ as part of my raised TJ gas tank swap.
Jerry Blair is offline   Reply With Quote
Old 04-21-2004, 07:01 PM   #3 (permalink)
Member # 27375
I just dont quite see what happens to the fuel if it get to the filter, how does it get back to the tank
Jp3_99 is offline   Reply With Quote
Old 04-21-2004, 07:34 PM   #4 (permalink)
Member # 8439
The Fuel Filter is designed to be a catch can only. In operations it should be able to hold all the fuel which fills a 12-foot hose during a 180 degree roll over (On the roof)
Once righted, the fuel that was caught by the filter (Holding tank) would have to be manually emptied.
This manual "Empty effort" is indeed additional work, required to eliminate the risk of having the fuel spill into the immediate environment during a roll over.
The overwhelming majority of the fuel in the 3/8-inch lines will indeed flow back to the fuel tank when the vehicle is righted. The Fuel filter simply catches the small part that doesn't.
Hope this helps.
Frank
Frank D.
Old 04-21-2004, 07:38 PM   #5 (permalink)
Member # 8439
Originally Posted by Jerry Blair
Frank,
Hi Jerry! How are you my friend?
It's been a long time since we have been able to chat.
Rusty and Darrel have both installed the FATS system, and I have had inquires from more then a few other folks. I figured the best place to post it would be here.
Please let other know where to find it if they are interested in implementing it.
With any luck I will make it down to Jellico on Sunday. I will make sure I find you.
Frank
Frank D.
Old 04-22-2004, 11:26 AM   #6 (permalink)
Member # 10761
See you there, Frank.
I will be with my wife, 5 mo. old son, and dog. I'll be the one pushing the stroller.
Old 04-22-2004, 12:09 PM   #7 (permalink)
Member # 7163
Good deal, Frank!
Edit: FYI, after a roll, I'd recommend cleaning out the filter. If the filter is full, you may have issues with vacuum in the tank because the system will no longer be vented.
Bryan
Oxjockey is offline   Reply With Quote
Old 04-22-2004, 12:27 PM   #8 (permalink)
Lowtorious's Avatar
Member # 2387
Send a message via AIM to Lowtorious
Thank you for taking the time to draw this all out and explain it all in clear english. People should not only use this during competition but on the trail too. The less gas on the ground and in your tank the better and safer (is that a word!?).
Lowtorious is offline   Reply With Quote
Old 04-22-2004, 12:41 PM   #9 (permalink)
Member # 2538
Thanks SOOOOO much for this post. I am getting ready to do a fuel cell in my trail only buggy. I was wondering how to combat fuel spillage in the event of a roll and this is EXACTLY the info I needed. Thanks again. Since my cell will be just behind the seats, I really didn't want fuel spilling anywhere near the exhaust. I really appreciate the post.
Take care,
Sean
***EDIT*** one quick question for the computer illiterate: I'd like to copy and print JUST your first post but when I copy and paste it to MS Word, it only gives me the diagrams and no text. Anyone know how I can print out the text?
Education is what you get when you read the fine print. Experience is what you get when you don't.
Sean is offline   Reply With Quote
Old 04-22-2004, 01:50 PM   #10 (permalink)
Member # 23517
Send a message via AIM to dcgrove
Take care,
Sean
The text is there, but is is white. With your blinking cursor on the word document, press CTRL+A to select all. Then just change the text color to black.
dcgrove is offline   Reply With Quote
Old 04-22-2004, 02:50 PM   #11 (permalink)
Member # 2538
Dang, I'm a moron. Sorry about that.
Thanks again,
Sean
