coarse threads vs fine threads off-road suspensions - Page 2 - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 05-19-2017, 05:52 AM   #26 (permalink)
Member # 157355
Are there standard torque numbers that apply to most situations and are based on the bolt size? for our purposes... Link bolt, coil over bolt, seat belt bolt, etc..
Minimal mech. knowledge, overly ambitious
Pokeman is offline   Reply With Quote Quick reply to this message
Old 05-19-2017, 06:00 AM   #27 (permalink)
Member # 4375
Originally Posted by DirtyComanche View Post
And you're wrong on everything else. If you can't fab to the point that your washers/fasteners are seating on flush and flat surfaces with holes that are the correct diameter, just give up.
I've been involved in trying to get folks to understand how bolts work for years and I've come to the conclusion that it is pretty much a waste of time to get folks to understand what you and Frank are preaching. It would seem that such a simple concept that escapes even some smart folks wouldn't be that hard to understand, but it is.
I am an official member of the "I saw Dave Cole get run over by a rock buggy" club.
mrblaine is online now   Reply With Quote Quick reply to this message
Old 05-19-2017, 06:03 AM   #28 (permalink)
I'm Zach
Beat95YJ's Avatar
Member # 22176
When I was working we had a chart we used as a baseline, based on diameter and unf/unc. It was great. Wish I had a copy now.
:tank:
Beat95YJ is online now   Reply With Quote Quick reply to this message
Old 05-19-2017, 06:10 AM   #29 (permalink)
Member # 4375
Plain nuts or nylocks also peg the meter. Stovers are the commonly available preferable nut, the price is not much higher and they work considerably better.
I've converted to the high strength thread locking compounds and plain high quality properly graded nuts and moved away from the upset style locknuts simply due to having too many issues with them tearing up threads even with a light application of anti-sieze and I'm not buying cheap stuff.
My preference would be a dependable supply of Stover or similar but I've not found the correct ones that I don't have issues with yet.
Cheap washers... Don't even bother. They will do more harm than good. 90% of washers I run into are cheap garbage that isn't suitable for use on disposable furniture.
That can NOT be stressed enough. Good quality hardened washers are worth what ever it takes to find them. If you aren't using them, you're pretty much wasting your time and effort putting together anything with fasteners.
Never assembly anything dry. Always use a torque wrench on a critical component and use the correct torque.
Many fastener failures would be prevented if people actually purchased fine thread fasteners, used properly sized high quality hardened washers, and torqued said fasteners correctly. A loose bolt is a soon to be broken bolt. Shit washers will not shoulder the bolt/nut correctly, and will either cause a point overload on the fastener, or will extrude and lead to the loosening of the fastener. Coarse threads with plain nuts or nylocks will not maintain torque in environments of high stress cycles. A bolt that was never torqued correctly is not even given a chance.
But, that's just me.
No, it's not just you. But hey, you can't be a race car god if you aren't buying fasteners that are too long and cutting them down to keep the threads out of the joint.
Old 05-19-2017, 06:14 AM   #30 (permalink)
Member # 693705
That would be a nice poster for the shop and trailer wall.
Ultra4 #128
Tuckers Off Road - Team Yukon - PowerMaster - Happy Stitches Embroidery -Corning Data
Rock IT Racing is offline   Reply With Quote Quick reply to this message
Old 05-19-2017, 06:18 AM   #31 (permalink)
Member # 693705
This, and those of you hammering bolts in so hard that you're fucking up the threads, are idiots. If your suspension is so bound up you can't get the bolt in you have bigger issues. Hell buy a prybar, something.
I wouldn't say "idiot" but it's trail fix situation. Winch pulling an axle back in place while someone is prying on a heim or link on a trail.
If you are hammering a bolt in while in the shop... then I agree.
Ultra4 #128
Old 05-19-2017, 06:20 AM   #32 (permalink)
I'm Zach
Beat95YJ's Avatar
Member # 22176
Originally Posted by rockyota83 View Post
oh looky more engineer shit that doesnt compute to the real world of 4x4 backyard fab the vast majority of bolts on our rigs are seeing shear forces, bray d brings up another great point of diameter. the forces seen in what we do most people either dont have a large enough diameter bolt to get enough tension to remove any shear forces or they are not tightening the bolts to the proper torque, which once again the fine thread comes into play with its greater shear strength of the threaded section.
youre right bray d we could run around in circles arguing about this subject for a long time love me my fine threads
If more people did "engineer shit" backyard guys wouldn't be breaking bolts.
:tank:
Old 05-19-2017, 10:24 AM   #33 (permalink)
Member # 100050
Shear application =/= pure shear loading, and I did not intend to imply that.
We're going to have to agree to disagree, gents. A properly designed joint will perform as expected with a coarse thread bolt if it's assembled properly and bolt tension is maintained. If Loctite isn't sufficient, I would use Nordlocks.
You have success with fine threads and Stovers. I have success with coarse threads and Loctite. Neither of us have issues.
If you guys' shit is designed to the point that you absolutely need the advantages of fine thread bolts to prevent failure, perhaps you should reconsider who's the hack.
Quoted for truth.
96 Ranger-2012 4WOR Ultimate Adventure Invited Reader
Bray D is offline   Reply With Quote Quick reply to this message
Old 05-19-2017, 11:52 AM   #34 (permalink)
hurleygo3's Avatar
Member # 80862
Yeah because you see course thread bolts on high end race cars.
I've never had issues with fine thread bolts. But also always cut, shoulder, and chase every bolt that goes on the car. I also fit tabs and brackets that the bolts slide into without the need for a hammer.. I'm sure most would never have issues with coarse bolts. But for those that are looking for every advantage. Quality fine thread bolts are the answer.
Mike Johnson #4588 EMC 2nd, 3rd, 4th, 5th and 6th
hurleygo3 is offline   Reply With Quote Quick reply to this message
Old 05-19-2017, 12:43 PM   #35 (permalink)
Member # 4375
And if you're as good at designing and implementing joints as you say you are, you won't have the problems with them the hacks do, now will you?
Old 05-19-2017, 01:35 PM   #36 (permalink)
Member # 100050
High end race cars vs garage fab rock buggies. Application is everything.
I never said fine thread bolts don't have their place. An environment where they're subject to contamination, damage, and improper installation is not one of them.
So far so good.
Old 05-19-2017, 01:50 PM   #37 (permalink)
Member # 685026
The F1 guys will still think its a tractor. I'm thinking BSF Whitworth and that way you've the distinct aura of pedigree.
Tnsejed is offline   Reply With Quote Quick reply to this message
Old 05-19-2017, 01:54 PM   #38 (permalink)
Member # 75858
Sums it up pretty well.
LQ9, Atlas, tons, 8274 & the rest of the usual
white-rhino is offline   Reply With Quote Quick reply to this message
Old 05-19-2017, 03:10 PM   #39 (permalink)
Member # 4375
Just so we have our descriptions correct, is KOH considered the non fine thread environment?
Old 05-19-2017, 03:30 PM   #40 (permalink)
hurleygo3's Avatar
Member # 80862
When I say race car. I'm talking off-road racing. You're not going to find coarse thread on any quality build.
Old 05-19-2017, 03:31 PM   #41 (permalink)
I'm Zach
Beat95YJ's Avatar
Member # 22176
Since that's where Hurley races his garage fab rock buggy I say yes. Hell, he should use all thread...
:tank:
Old 05-19-2017, 03:33 PM   #42 (permalink)
I'm Zach
Beat95YJ's Avatar
Member # 22176
Most of my friends wouldn't put them on homebuilt crawlers.
:tank:
Old 05-19-2017, 04:49 PM   #43 (permalink)
Provience's Avatar
Member # 138976
mount all your brackets with sleeves to take the load, stuff them with all thread and double nut with a nor-lock in between on both ends.
no more loose bolts
I just want to build cars, collect watches and get tattoos.
Old 05-19-2017, 06:00 PM   #44 (permalink)
Weasel's Avatar
Member # 5639
Agree. Just looking at CAT's bolt selection the amount of coarse thread fasteners is far greater than fine. Seems they are okay with 80% coarse.
Yep, so I buy CAT bolts see above.
Twisted uses as much coarse as they can. They don't have issue with bolts breaking. Oh course they run bolts in single shear as well which many seem to think will trigger the spontaneous explosion of the universe.
You guys want to get really uppity then any quality builds should only use gun drilled bolts and that is the ideal way to make bolts with the optimal strength/weight ratio for racing. So that leaves only 2 quality build rigs ever.
Experience is what you get 30 seconds after you need it
Just Add Lightness
Weasel is offline   Reply With Quote Quick reply to this message
Old 05-19-2017, 07:44 PM   #45 (permalink)
pcoplin's Avatar
Member # 17986
Years ago I printed out and laminated the charts from Portland bolt. Gives the grades and wet/lubed torque values.
KOH 2017 #4822
1998 TJ 6.0/TH400
pcoplin is offline   Reply With Quote Quick reply to this message
Old 05-19-2017, 08:11 PM   #46 (permalink)
Member # 685026
Its always advisable to use the charts from the specific manufacturer you are using.
I only pointed it out because of the various choices of hardware and the massive degrees of variation between specs. Especially when considering alot of our domestic goods come from regions that don't really much care if it meets the certificate they provide or not.
This rolls back to another point someone else wrote about using good washers. I think something that should be taken into consideration before pitch should be quality of fasteners. What we hope we are purchasing when we purchase a good fastener is a quality alloy with an engineered, and consistent, heat treat throughout the batches.
Old 05-20-2017, 09:15 PM   #47 (permalink)
pcoplin's Avatar
Member # 17986
I will say I always use coarse thread bolts on all my suspension. We work on and drive a race car, it has coarse thread bolts. However, we use grade 8 washers and always torque to the rated bolt torque. Except on heims, if you do that it'll squash the misalignment spacers, so we under torque and use a stove nut. I'm sure if we raced every month maybe we would find something wrong with coarse threads, but I can't say I've ever had one come loose that I've torqued.
If you are breaking bolts, you aren't torquing it properly, using shitty washers, and the nut got loose, no matter the thread pitch.
KOH 2017 #4822
1998 TJ 6.0/TH400
Old 05-21-2017, 08:09 AM   #48 (permalink)
Member # 141944
So what are the preferred nuts to use with fine thread link/shock bolts properly shouldered and cut down with hardened washers?
Best of Luck,
Mike
'05TJLWBRUBY is offline   Reply With Quote Quick reply to this message
Old 05-21-2017, 10:49 AM   #49 (permalink)
Member # 256962
So what does everybody think about cut vs rolled threads?
Does anyone carry one spare bolt with a long shank and a die to thread it as needed?
Best of Luck,
Mike
Depends on the application
Old 05-21-2017, 12:41 PM   #50 (permalink)
Member # 236179
Rolled threads hands down.
Kevin
gt1guy is offline   Reply With Quote Quick reply to this message
