rebuilding a tc pump - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 06-03-2004, 04:32 PM   #1 (permalink)
Member # 141
Send a message via AIM to CRAWLTOY
Last weekend on the con my front seal behind the pulley started leaking bad. I called and its a hundred to rebuild it or I can get the seal kit for 20. Has anyone ever rebuilt one. I never rebuilt a pump before. If anyone has any tips or pics please let me know. Not sure how to get the retainer clip off the back too. Thx for any help rob
Do you need me to shove your head up your ass so you can see shit more clearly
CRAWLTOY is offline   Reply With Quote
Old 06-03-2004, 04:33 PM   #2 (permalink)
Member # 141
oh yeah its a sweet or howe pump
Old 06-03-2004, 06:41 PM   #3 (permalink)
Knee Grow
jstarnes's Avatar
Member # 12575
Location: It puts the lotion on its skin OR it gets the hose
pull the pump off the engine
pull the pully off the pump
put a large socket over the pump shaft
put pump and shcket in a vice
use another small socket between the back plate and vice jaw
squeze the pump slightly to relieve the pressure off of the retianing ring
push ring out with a seal pick (2 might be needed one pushing through the hole and one to hook and pull the ring out)
renove pump from vice
use a soft face hammer to tap the pump shaft (taping the pump guts out the hole the back plate sits in)
stack every thing as it comes out
remove all seals and O rings
clean all the pump guts and crap
put the seals and o rings back in
lube the seals and o rings
put the pump shaft back in with out the cam pack ring or vanes
put the 2 alignment pins in
put the cam pack ring on (or in)
put the vanes in
lube the rotor/vanes
put the pressure plate and spring and back plate (depending on what tc you have)
apply pressure to the pump body and back plate (to compress the pressure plate spring) ( vice and sockets)
reinstall the retianing ring
put the pump/and pully back on your shit
She said her name was Bambi, I said thats a coincidence darlin cause I was just thinkin about skining you like a deer then wearing your face like a mask as I do my little kooky dance
jstarnes is offline   Reply With Quote
