Who drives a Lull(skytrak)? - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 06-30-2004, 01:13 PM   #1 (permalink)
Member # 29634
I noticed today that they have a hydro cylinder hooked to their centerpinn articulating planitary axles. But I thought I saw one freely articulating. Was wondering if their is a bypass valve or if it is setup as some kind of shock? Or if maybe that one just was messed up.
The less we take care of our neighbors, the more $ U.Sam will take to screw up trying to do our job
bigsub is offline   Reply With Quote Quick reply to this message
Old 06-30-2004, 01:56 PM   #2 (permalink)
Member # 1889
The ones I've seen, one axle is forced (hydro cylinder) and the other is free.
Scott@Rockstomper is offline   Reply With Quote Quick reply to this message
Old 06-30-2004, 02:07 PM   #3 (permalink)
Member # 29634
That may be what it was. The CAT definitely had two cylinders and the rear one had some kind of control box mounted directly on the rear cylinder. But maybe the skytrak I saw hop the curb only had a front cylinder. Guess theres no Vodo Magic afterall. Can anyone confirm?
Old 06-30-2004, 05:20 PM   #4 (permalink)
Member # 28587
Confirmed
No voodoo.
I'm not building my truck anymore.
NH Jeep Junkie is offline   Reply With Quote Quick reply to this message
Old 06-30-2004, 08:53 PM   #5 (permalink)
jstarnes's Avatar
Member # 12575
Location: It puts the lotion on its skin OR it gets the hose
lifts that you see with a cylinder on the front and rear have whats called Oscillation lock when the boom goes up so far it locks the rear axle from oscillating when the boom is down the rear is free lifts with only a cylinder on the front the rear is always free
you can (in certian circumstances) use the frame tilt and a chain to force the machine to lift a tire in mid air in the case of a broken axle
and on older lulls if you had the right combo of problems you could step on the brake pedal and it would lift a front tire ~3 feet in the air and when you let off the padal the machine would fall quite quickly causing most operator to shit themselvs
what more would you like to know?
Im special, just like everyone else.
jstarnes is offline   Reply With Quote Quick reply to this message
Old 07-01-2004, 12:57 PM   #6 (permalink)
Member # 29634
Why would the tire lift if you stepped on the brake?
Old 07-01-2004, 04:25 PM   #7 (permalink)
jstarnes's Avatar
Member # 12575
when you step on the brake it locks the rear axle for safety when a specific valve sticks it causes pressure to be fed to the frame level cylinders
