relative strength of np208 - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 01-31-2002, 04:35 PM   #1 (permalink)
Member # 3636
i already tried a few searches
im running a 360, auto tranny, 4.10s and 38s(yeah i know my crawl ratio sucks) im wondering if the 208 is up to this. truck weighs prolly about 5000#. not too stupid with the gas. i will be building a 203/205 combo but its gonna take some time fore its done. i read somewhere that they are actually pretty strong chain drives but i dont know for sure.
zstrange is offline   Reply With Quote Quick reply to this message
Old 01-31-2002, 07:04 PM   #2 (permalink)
High5's Avatar
Member # 1700
so what is it out of? chevy, ford, dodge, jeep????? i know tom eliston of sunray eng. ( the developer of the ford 9"/d60 hybrid) recomends using a 208. it is light weight and stronger than the cj version t-cases. they have a large output shaft that take abuse better than the d300 can. he likes the dodge version because the chevy version uses a slip yoke. actually the ford and fsj versions use a fixed yoke too. if you are running a chevy you can take a dodge case and swap out the input gears between the two and have fixed yoke unit. anyway i don't run one but alot of the guys he runs with have a fixed yoke 208 behind healthy v8's and they have no problems.
also the main weak point of the 208 is it's aluminum case. it is prone to breakage or cracking if not setup correctly. make sure your d/shafts do not bottom out. this will surely leave the 208 with a broken housing. and also make sure it is protected from rocks. put a skid plate under it. hope this helps.
High5
IT'S 1TON O' FUN!
High5 is offline   Reply With Quote Quick reply to this message
Old 01-31-2002, 07:14 PM   #3 (permalink)
Member # 4224
I have a bud who runs them, they are pretty strong, he runs one in his crawler w/ 39.5s and another in a mud drag truck with big ass motor, they will take some serious use for a while.
Some of my best welds are made with the cutting torch...
dirtrod is offline   Reply With Quote Quick reply to this message
