Rockwell T-223 transfercase - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 10-22-2004, 04:47 PM   #1 (permalink)
Member # 3995
Ok guys, I have SEARCHED as much as you can... Even all over Alaska. What I am looking for is a rockwell t-223. I have been priced up here $2000, and $4000 for a swap in on the one I have. That sounds a bit steep. I was wondering if anyone knew of a place down there in the lower 48 I could try? This goes in a 4x4 f-700 drill truck. And it is divorced from a Clark 5 spd. Thanks, and any help will be greatly appreciated.
1973 CJ-5, 302HO, NP435, Atlas, Ford HP D60, Detroit,4:56 gears,3 Link,14" travel SwayAWay coil overs, PSC Full Hydro, Rear Dana 60, Spool,4:56 gears, 35 Splined Currie HD shafts, 4 link, 16" Rock Equipment Coil overs, 44x19.5 boggers 112" WB
Alaskan Assassin is offline   Reply With Quote Quick reply to this message
Old 10-22-2004, 05:53 PM   #2 (permalink)
steve gerstner's Avatar
Member # 12741
Send a message via Yahoo to steve gerstner
There are many different models, there is LH drive RH drive, 1 1/2" shafts input and output to the front up to 2" shafts. And this is just ford, also chevy, dodge, IH. A freind will let me konw about one next week, i have 5 of them but can not build one good one from all of them. steve
steve gerstner is offline   Reply With Quote Quick reply to this message
Old 10-22-2004, 06:25 PM   #3 (permalink)
jasonmt's Avatar
Member # 3236
There are over 80 different part numbers for the T223, with A,C,E,H, and M series. Find out what model you have and then go from there. Is the current case non-repairable? Parts are still available from Meritor and I have a PDF of the Maintenance Manual No. 3A in the computer at the shop if you need it. For 4K you should almost be able to buy a new t-case if needed as it is divorced.
[QUOTE=Roxywheels]The trolls always out themselves :laughing: :roxy:[/QUOTE]
jasonmt is offline   Reply With Quote Quick reply to this message
Old 10-22-2004, 06:42 PM   #4 (permalink)
Member # 3995
I will get ya'll some more info. I dont know anything about this thing. It is in a Ford F-600. Not 700... Missed placed numbers... And of course it is 4 wheel drive. The one that is in there is repairable. See to run the drill on the back of the truck we have to use a pto set-up. And when we got the drill, the oiler wasnt working. So we knew that the previous owners used it without oiling the top bearing. Well, we got the oiler working. But it seems like it was to late. Last week, we found a cup full of metal chunks in it. Looked to be like bearing retainers and such. So I called up the local Six States. And a rebuild kit is $1300. But I will get the serial # off the thing. And it is a passenger side drop. Thanks guys.
Old 10-22-2004, 06:51 PM   #5 (permalink)
BigWoodyWag's Avatar
Member # 26468
Send a message via AIM to BigWoodyWag
Just curious, what does this thing look like?
I bought a divorced outta a mid-80's Chevy Drill rig, I know its a Rockwell but nothing else. Has input up high with a PTO and brake on the backside at the same height. Both outputs are about 6 inches lower. Any idea? I'd post pics if I had some, its in Blacksheep10's shop I'll see if he can snap a pic for ID.
JasonMT, I'll PM ya, wouldn't mind getting a copy of that PDF.
EDIT: Passenger side drop as well
#555 Triple Nickel Racing, & TGTW Lemons Racing
Build Thread
BigWoodyWag is offline   Reply With Quote Quick reply to this message
Old 10-22-2004, 07:02 PM   #6 (permalink)
Member # 3995
HHHmmm, sounds interesting. Sounds just like what I have. Take a picture of it. Would you be interested in selling it?
Old 10-22-2004, 07:22 PM   #7 (permalink)
jasonmt's Avatar
Member # 3236
Here are a few drawings from the manual:
Old 10-22-2004, 07:28 PM   #8 (permalink)
jasonmt's Avatar
Member # 3236
Two more:
Old 10-22-2004, 07:40 PM   #9 (permalink)
Member # 3995
The second picture is VERY simular to ours. Ours doesnt have that style yoke end off the PTO. And it doesnt drain oil from the side. The rest looks the same
Old 10-22-2004, 09:39 PM   #10 (permalink)
Member # 10736
weren't they used in deuce trucks?
masonmachines is offline   Reply With Quote Quick reply to this message
Old 10-22-2004, 11:13 PM   #11 (permalink)
Member # 29210
Send a message via AIM to Davethorik
in the first pic, it says Rockwell T221/T223. What is the difference between these two transfer cases? I saved the T221 that came out of my GMC when I put the NP205 in, but the T221 shit the bed pretty hardcore. Is the Rockwell worth keeping? I know parts for it are $$$ but how does it compare strength wise to the 205? sorry for the OT.
Davethorik is offline   Reply With Quote Quick reply to this message
Old 10-23-2004, 11:37 AM   #12 (permalink)
Blackjack's Avatar
Member # 165
Send a message via MSN to Blackjack
The 211/223 are like little and big brothers. The basic design is the same, just different sizes. The parts are very spendy (as with any Meritor product) and probably not worth putting any effort in using for a wheeling rig. Frank has little choice as that 223 is really the heart of his drill rig.
Blackjack is offline   Reply With Quote Quick reply to this message
Old 10-23-2004, 11:48 AM   #13 (permalink)
Member # 3995
It sure is. And if you can Dan. Could you put that parts list, and blow up in with Coles hubs? Would be greatly appreciated.
Old 10-23-2004, 07:51 PM   #14 (permalink)
Member # 12741
The 221 is a POS, most of these i have seen were broken in half. steve
