How to remove Dana 60 front spindle bearing??? - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 12-10-2004, 02:00 PM   #1 (permalink)
Member # 278
I'm at a loss here and replacing the bearings is the last thing I need to do before I get back to a rolling chassis.
Anyways, on a Dana 60 front, there is a bearing inside the spindle that the outer stub shaft rides on.
How the hell do I remove these? I tried a pilot bearing puller with no luck. I didn't see a way to get a tool through the outside of the spindle to pound on the bearing.
Anyone?
Lil'John is online now   Reply With Quote Quick reply to this message
Old 12-10-2004, 02:05 PM   #2 (permalink)
Newb
nvrenuf's Avatar
Member # 10903
Get a big, long flat screwdriver, heat and bend the last inch or two to a 45* angle. Go in from the outboard end of the spindle, catch the inner side of the bearing race and knock it out.
Edit: Lisle does make a tool (that Snap On also carries) but it's hard to find since it's not popular.
John
'91 K5 454, 4spd, Doubler, J76/70HD, 5.86's & 43's
happy..happy..happy....
nvrenuf is offline   Reply With Quote Quick reply to this message
Old 12-10-2004, 03:04 PM   #3 (permalink)
Member # 26680
Send a message via ICQ to elacruze Send a message via AIM to elacruze Send a message via Yahoo to elacruze
I have this particular tool-
http://www.drivewerks.com/catalog/sh...AT585_pg43.htm
Money well spent.
It has a reversible two-hook puller, with a locking ring to hold the jaws in place. My bearings were out no kidding in less than 30 seconds each. It took longer to carry them to the vice than to get the bearings out.
Be certain that you have the correct installation depth-IIRC it's -.100". Check your manual.
'85 K3500 6.2diesel th400/203/205 d60 14b locked 4.10s 305/85-16 Coyotes hyd Koenig winch
One ton or none!
http://www.4x4support.com/
elacruze is offline   Reply With Quote Quick reply to this message
Old 12-10-2004, 03:13 PM   #4 (permalink)
TexasBlake's Avatar
Member # 9722
cut the outer race in half with an air hammer.
That's the most PITA bearing/seal I've ever encountered.
TexasBlake is offline   Reply With Quote Quick reply to this message
Old 12-10-2004, 03:18 PM   #5 (permalink)
pro web-wheeler
RedBullJeep's Avatar
Member # 12217
I use a dremel...I need a tool though as this is a bitch.
RedBullJeep is offline   Reply With Quote Quick reply to this message
Old 12-10-2004, 08:11 PM   #6 (permalink)
2stroke's Avatar
Member # 8981
here is how i did my 44. same concept.snapon pilot bearing puller
2stroke is offline   Reply With Quote Quick reply to this message
Old 12-10-2004, 08:29 PM   #7 (permalink)
Member # 36156
Take a carbide bur on a die grinder and cut the lip of the outer race down.(or break it with a chisel)Then thin the wall of the bearing and use a small chisel to break or crack it.Done many that way.My.02
Les H. is offline   Reply With Quote Quick reply to this message
Old 12-11-2004, 08:51 AM   #8 (permalink)
Member # 187
1 hammer 1 mushroomed punch and 4 strokes and your on to the next one.You should have brought those down when you picked up axle and I could have done it for ya.
GearMan is offline   Reply With Quote Quick reply to this message
Old 12-11-2004, 09:08 AM   #9 (permalink)
Member # 278
I didn't think they'd be this big of a pain in the ass. Otherwise I would have brought them.
Finally got them out doing something like you do
Thanks again for the great deal and good work.
Old 12-11-2004, 09:09 AM   #10 (permalink)
Keith's Avatar
Member # 52
Works for me, maybe three hits.
Rockzombie Smurf
Keith is offline   Reply With Quote Quick reply to this message
Old 12-11-2004, 09:42 AM   #11 (permalink)
Member # 27868
Send a message via AIM to cj8rckcrlr
what i did was weld 2 half in beads on the inside, and that game me something for the punch to hit on....then i just hammered them out...plus the heat helps free them up....
James Vest
cj8rckcrlr is offline   Reply With Quote Quick reply to this message
Old 12-11-2004, 10:33 AM   #12 (permalink)
Member # 3432
Send a message via AIM to TJpwr
Other wise know as a prybar. This is what I do on 44/30 spindles. Is there something different about a 60 spindle in reguards to this?
HTH
Phil
"How's the view from sugar heaven bitch?!" Quote from where?
TJpwr is offline   Reply With Quote Quick reply to this message
Old 01-11-2005, 11:40 AM   #13 (permalink)
Kaiser5's Avatar
Member # 26472
Referred to this thread when I was getting ready to go through my Chevy 60.
I bought a three-jawed bearing puller from Harbor Freight for $15.00 and it worked great.
Bearing had been in there a long time. I at first tried getting it with a bent screwdriver, mushroomed punch, etc but couldn't quite get the angle right to get a good hit.
Mike
Kaiser5 is offline   Reply With Quote Quick reply to this message
Old 01-11-2005, 02:22 PM   #14 (permalink)
Devil Dog's Avatar
Member # 11922
Send a message via MSN to Devil Dog Send a message via Skype™ to Devil Dog
i took some steel stock.. and cut out the bottom... like an upside down L... and beat it out with a hammer...
[COLOR="DarkGreen"][B]Front Toward Enemy[/B][/COLOR]
'09, '11, '13 and 2014 King of the Hammers
[B][I]BUCK[/I] Wild Racing[/B]
Team 911
[B]Degenerate[/B]
Team 488
[B]O.G. "Wreckin' Crew"[/B]
Devil Dog is offline   Reply With Quote Quick reply to this message
Old 01-12-2005, 11:11 AM   #15 (permalink)
4wDakota's Avatar
Member # 20469
So now that they are out whats the proper way to install them
Where are ya'll getting replacement bearings from?
90 K5: TBI 350/700R4/241/D60/14B/6" lift/36" Iroks/........
07 FJ Cruiser TRD SE 6 speed
4wDakota is offline   Reply With Quote Quick reply to this message
Old 01-12-2005, 11:18 AM   #16 (permalink)
Madzooki's Avatar
Member # 13569
Send a message via AIM to Madzooki Send a message via Yahoo to Madzooki
You can get them local from most any auto supplier. They are referred to in the books as ag kits. They come with the spindle seal, the bearing and another little seal. I dont recall the part number offhand, but I think it is a SBK3 in BCA. We stock them at the Carquest that I work at.
Paul
"If it doesn't fit, get a bigger hammer"
Madzooki is offline   Reply With Quote Quick reply to this message
Old 01-12-2005, 11:22 AM   #17 (permalink)
Member # 25770
Napa's got them. Any bearing supplier should have them as well. Part numbers are in 16ths by i.d., o.d. and length. Like this XX 121616. The XX represents the cage (race) style. It's likely to be an IR.
12= 3/4" 16= 1" etc...
Safety Yellow & Handicap Blue CJ with 5.3 Vortec/400/Atlas/Tons/Roks/Locks and Airshocks.
Toss me one of them Skullbusta's!
RedRooster is offline   Reply With Quote Quick reply to this message
Old 01-12-2005, 05:40 PM   #18 (permalink)
Member # 26680
The proper way is to use a properly sized bearing driver made of soft material like brass or aluminum. If you're creative you can use a nice piece of hardwood made on your neighbor's wood lathe.
Or like me, you can tap it in carefully with a brass hammer and soft drift. Be sure you check the depth specification before you get in too deep.
One ton or none!
Old 01-12-2005, 05:47 PM   #19 (permalink)
Member # 13786
I've pretty much done the same thing for the last 20 years, ONLY, I use a different tool [if any body can remember split rims] Snap-on tool for removing the lock ring. Has the bend on the end you describe making out of the screw driver. Since I don't do splits any more, I had to use the tool somehow.
KWTMECH is offline   Reply With Quote Quick reply to this message
Old 06-18-2006, 05:05 PM   #20 (permalink)
Moderator
geberhard's Avatar
Member # 5861
BTT,
Good info here as I am going through this pain. Another thing to add, what is the part number for a speedys sleeve for a D60 spindle (i.e. Ford)?
Thanks!
Gui
geberhard is offline   Reply With Quote Quick reply to this message
Old 06-18-2006, 05:49 PM   #21 (permalink)
Member # 66858
Use a sharp shisel or punch and blow a hole in one end, then remove the rollers through the hole. Next weld a bead on the inside of the bearing case, it will ussually fall right out. Maybe takes about 5 minutes each.
Member
Deep Woods Extreme 4X4 Club Of Southern NH.
LASER is offline   Reply With Quote Quick reply to this message
Old 06-19-2006, 08:46 AM   #22 (permalink)
85f150dsel's Avatar
Member # 43079
i weld a solid bead, let it cool and it falls out on its own. When the bead cools it pulls the metal race together. Make sure you knock out all the needles as it works better
85f150dsel is offline   Reply With Quote Quick reply to this message
Old 06-19-2006, 09:09 AM   #23 (permalink)
Member # 693689
I used a cut off wheel on a dremel. Not too bad. I bought new bearing and seal kits from here:
http://partsmikeparts.com/d60_axle_seal_kit.htm
DannyK is offline   Reply With Quote Quick reply to this message
Old 10-21-2013, 09:06 PM   #24 (permalink)
Member # 41438
I know this thread is ancient, but I didn't see slide hammer listed. Harbor Freight blind hole puller or some-such (slide hammer). Worked like a charm, though the biggest adapter in the kit is barely big enough.
Can anyone tell me the proper depth for the new bearing?
Mastiff is offline   Reply With Quote Quick reply to this message
Old 10-21-2013, 09:55 PM   #25 (permalink)
Wheelin 24/7
Beat95YJ's Avatar
Member # 22176
Dremel and a punch.
I swear sometimes this place should be called "Autism on bath salts".
:tank:
