Ford NP 205 to GM 4L60E (4wd version)? - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 02-10-2005, 11:46 AM   #1 (permalink)
Member # 42769
Does anyone make an adapter that will mate a Ford NP205 directly to a GM 4L60E (4wd version)? I have a driver drop axle which is why I want the Ford t-case. I read a few dozen other posts, but none seemed to definitively answer this. Sunray engineering was listed as having one, but I checked their site and didn't find anything. I checked AA, but they didn't list the supposed adapter they were going to make.
Please post here or email me at ryan@bjsoffroad.com
Thanks!
billyrb is offline   Reply With Quote Quick reply to this message
Old 02-10-2005, 12:49 PM   #2 (permalink)
JJSBADYJ's Avatar
Member # 14155
Send a message via Yahoo to JJSBADYJ
Change the input gear on the 205 from Ford to GM. They are the same size and the GM is either a 32 or 27 spline input versus the Ford 31 spline input. You will need a 27 spline input to match the output of the 4L60E. AA sells a short shaft that is about 2 inches shorter otherwise you will need a spacer. I think the adapter for the GM 205 to the T350 will work just that the ford 205 is driver drop and the GM is passenger drop. I think they bolt up the same way. It also depends on the year of the 4L60E. I know the 4wd unit without the removable bell housing has the same 4 bolt pattern as the T350.
JJ
JJSBADYJ is offline   Reply With Quote Quick reply to this message
