Best way to start a diesel after sitting 10 years? - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 06-17-2005, 01:32 PM   #1 (permalink)
Member # 21267
Its a 3.0L five cylinder Mercedes in a Mog. It was running good when it was parked 10 years ago. The hoses and belts are in good shape and still soft. I figure I will change the oil, oil filter, fuel filter, and air cleaner. Any other precautions I should know about before I throw in a battery and fire it up?
Flat50 is offline   Reply With Quote Quick reply to this message
Old 06-17-2005, 01:40 PM   #2 (permalink)
Dinkerdoodledoo
Member # 10448
Send a message via Yahoo to Grendel
I'd fnd some way of getting oil down into the head, Marvel Mystery Oil works well for this.
Let it sit over night, at the minimum. Hand cycle the crank, add more oil etc.
Youre the only person on earth who knows all the details of your life, and thus, you are the most qualified captain of your own ship. Dont worry about justifying your course for pirate's sake. There's always someone here to tell you that you did it wrong.
Grendel is offline   Reply With Quote Quick reply to this message
Old 06-17-2005, 02:32 PM   #3 (permalink)
Member # 14094
Send a message via AIM to Hvy_Chevy
any way to prime the oil system without running the engine?
Size does matter.
Leave the Zukes to those who really understand.
Hvy_Chevy is offline   Reply With Quote Quick reply to this message
Old 06-17-2005, 02:55 PM   #4 (permalink)
Creepy196's Avatar
Member # 21558
Remove the glowplugs (unless the MB engine has a heated grid and no GPs-I don't know MBs specificaly) and squirt/pour some oil into each cylinder. Keep the plugs out and crank the engine over MANY times to distribute/dissipate the oil, as well as prime the engine's oil pump (and injector pump). Hopefully you can get the oiling system primed to the point where some oil gets to the camshaft bearings and lobes.
That's where people usualy run into problems when starting an engine that's been sitting long enough for all of the oil to have dripped off the cam's lobes. Turning a DRY bumpstick is asking for galling and rapidly flattened lobes.
With a gasser I pull the sparkplugs and disty, squirt oil in the jugs, spin the oil pump for a WHILE with a homemade driver and cordless drill, then spin the engine over (with plugs still out) while still running the drill.
Is that MB diesel OHC? If it is you could remove the valve cover and slather some oil on the cam lobes before turning the engine over at all. If it's OHV you could remove the lifter access cover and squirt oil on the cam through there.
Whatever you do, PLEASE don't use ether...
Creepy196 is offline   Reply With Quote Quick reply to this message
Old 06-17-2005, 03:47 PM   #5 (permalink)
Robert's Avatar
Member # 1050
Send a message via Yahoo to Robert
Friend and I rescued a Frieghtliner out of a field after it had sat for many years (well over ten). Has a 8V92 Detroit in it. All we did was install new batteries, then cranked it up! Damned thing fired up on the first crank. Three years later, it still fires right up, never had any issues with it.
I would say, if you are concerned about the rings sticking, turn it over by hand and see if it sticks. If it sticks, then worry about oil and all that bullshit.
I would just start it up.
Ask me anything about a Cummins, I stayed at a Holiday Inn last night.
Robert is offline   Reply With Quote Quick reply to this message
Old 06-17-2005, 06:29 PM   #6 (permalink)
CRO
Member # 7588
You can pressurize the oil system with a hudson sprayer (like for pesticides... garden stuff) you have to rig up a hose to thread into the oil gallery, then pump up the handle.
one thing the guys from California just don't understand is what 10 Edmonton winters are like....
1948 Willys
1952 M37CDN Powag
CRO is offline   Reply With Quote Quick reply to this message
Old 06-17-2005, 06:31 PM   #7 (permalink)
jgarden1's Avatar
Member # 584
Key -
jgarden1 is offline   Reply With Quote Quick reply to this message
Old 06-17-2005, 08:07 PM   #8 (permalink)
Member # 16468
I once started a Cummins 4BT that had been sitting for over three years. With just a jump, the engine cranked half a turn and started right up!
1969 Jeep M715 6x6 6BT/NV4500/NP202.5 D60/70/70
1963 Jeep J300, 4BT/NV4500/NP200/D60/60
Mikel is offline   Reply With Quote Quick reply to this message
Old 06-18-2005, 12:22 AM   #9 (permalink)
Robert's Avatar
Member # 1050
You should not talk about things you do not know.
If the belts and hoses are still in good condition, those winters have not been that hard on the engine.
Old 06-18-2005, 01:59 AM   #10 (permalink)
Brutpwr's Avatar
Member # 481
I'm no diesel expert but I've seen people start diesels with ether in cold weather...is this dangerous or harmful?
Jason
Brutpwr is offline   Reply With Quote Quick reply to this message
Old 06-19-2005, 01:45 AM   #11 (permalink)
Robert's Avatar
Member # 1050
Depends upon a few things. How much ether they use. Is it the only way the engine will start. Is it a glow plug engine.
Most heavy trucks are equipped with an ether assist start system. They release a small amount of ether into the intake with the push of a button. This is only for use in extreme climates.
If it is a glow plug equipped engine, ether will overheat the glow plugs and melt them. If the engine is equipped with an intake heater ( a common alternative to glow plugs) the ether could combust in the intake manifold.
Lastly, ether used in large doses can damage the engine, melting the pistons. This is mostly a problem with smaller or older engines equipped with aluminum one piece pistons. Newer large bore engines use two piece pistons witha steel crown that can take the abuse of ether pretty well. I have seen guys at work running Cat engines on nothing but ether, for several minutes at a time, controlling the RPM by the flow of ether. Not something I would do, but it does have some diagnostic purposes. If you have a diesel that will not fire up, you can run it on ether to verify if it is mechanically sound.
Old 06-19-2005, 09:37 AM   #12 (permalink)
Member # 22393
Wd40
Alot of the old loggers that I know use WD40 in place of ether.
OlyWa
OlyWaXJ is offline   Reply With Quote Quick reply to this message
Old 06-19-2005, 09:43 AM   #13 (permalink)
jstarnes's Avatar
Member # 12575
Location: It puts the lotion on its skin OR it gets the hose
crack the injector lines (so it will not start) crank till you have oil pressure then tighten the injector lines and start it
Im special, just like everyone else.
jstarnes is offline   Reply With Quote Quick reply to this message
Old 06-19-2005, 10:02 AM   #14 (permalink)
XJUSA's Avatar
Member # 11132
Location: If I could start again, a million miles away.
Be shure after renewing the fuel filter to exhaust the air out of the fuel lines. Don't know if this 300D has a automatic deairing or a mechanic one.
Is the compression still good, the engine should start.
----------4---------------4------|
--2---2-2---2---2-2---2-2---2---2|
The hammer of the gods will drive our ships to new lands
Valhalla, I'm coming
XJUSA is offline   Reply With Quote Quick reply to this message
Old 06-19-2005, 12:12 PM   #15 (permalink)
I build stuff
aloharover's Avatar
Member # 14561
Drain fuel tank and fill with new fuel.
Change fuel filter.
Remove glow plugs so engine cranks easier.
Squirt some MMO into the cylinders and let sit over night.
Crack the fuel lines at the injectors.
Next day, crank the engine until fuel leaks out line to injector union and all the oil is out of the cylinders.
Crank in bursts so you dont fry the starter.
Tighten fuel lines, install glow plugs.
Should start right up.
Never use ether or starting fluid, bad stuff for a compression ignition engine.
Use WD-40.
Pete
It's all fun and games 'till someone loses an eye, then it's just fun you can't see.
1970 Land Rover Series IIa 105". 5.3l L59, 4L80 MT1, NP241, F&R D110 Salisburies
aloharover is offline   Reply With Quote Quick reply to this message
Old 06-19-2005, 05:42 PM   #16 (permalink)
Member # 21267
Thanks for all the advice. I will let you know how it goes. Should have the unit home this week some time.
