PowCon plasma cutter, $100? - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 06-25-2005, 02:15 PM   #1 (permalink)
Member # 26680
Send a message via ICQ to elacruze Send a message via AIM to elacruze Send a message via Yahoo to elacruze
Found a PowCon Starcut plasma cutter, 80A which throws a pilot arc and blows but won't cut, for $100.
Worth it? Any idea whether whatever's wrong is common, I can fix, how much, or should I send it back to them for service? I've never had a PC before. Is this unit good? I searched and only found one reference to PowCon but it wasn't relevant.
'85 K3500 6.2diesel th400/203/205 d60 14b locked 4.10s 305/85-16 Coyotes hyd Koenig winch
One ton or none!
http://www.4x4support.com/
elacruze is offline   Reply With Quote Quick reply to this message
Old 06-25-2005, 02:57 PM   #2 (permalink)
Member # 29650
did you put the ground on?
Rock rash provided by..... Bud light!
CANYON KRAWLER MIKE is offline   Reply With Quote Quick reply to this message
Old 06-25-2005, 04:50 PM   #3 (permalink)
Member # 30115
really sounds like the ground system is not hooked up either u didn't put the ground on or it's disconected in the inside or the cord is broke thats all i can think of
stunnin650 is offline   Reply With Quote Quick reply to this message
Old 06-25-2005, 06:25 PM   #4 (permalink)
Member # 26680
I connected everything by the directions, which are clearly displayed on the side of the unit. I didn't do anything except hook it up, I didn't verify any of the connections at or inside the machine. It's had plenty of use, some of the cables aren't 100% so maybe something came loose inside.
I guess if that's all that's wrong with it, it's a good buy?
One ton or none!
Old 06-26-2005, 04:35 PM   #5 (permalink)
Member # 26680
Ah...
Ok. I'll try it again with a DC power supply.
One ton or none!
Old 06-26-2005, 05:22 PM   #6 (permalink)
jasonmt's Avatar
Member # 3236
PowCon was bought by ITW (Miller/Hobart et. al. parent company) in the mid 90's for its inverter technology. Service parts can still be bought from Arc Products: http://www.arc-products.com/powcon/ and Arcon still offers a slightly modernized version of the Starcut: http://www.arconweld.com/index.html
The Starcut runs off of a DC CC welding power source and they can be picky about needing good connections.
[QUOTE=Roxywheels]The trolls always out themselves :laughing: :roxy:[/QUOTE]
jasonmt is offline   Reply With Quote Quick reply to this message
Old 06-26-2005, 07:06 PM   #7 (permalink)
nhgpnut's Avatar
Member # 42521
Send a message via AIM to nhgpnut Send a message via Yahoo to nhgpnut
also make sure you have a good water seperator for your compressor.otherwise.your arc will just keep starting and stopping.good luck
nhgpnut is offline   Reply With Quote Quick reply to this message
