GM 4.2L vortec swap - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 09-04-2005, 06:40 PM   #1 (permalink)
toymaniac's Avatar
Member # 3044
GM 4.2L vortec swap
I was thinking about putting one of those 4.2L votec motors in my toyota, but i want a manual. Does anyone know of any applications of a manual behind these motors? Or of a place that makes a flywheel for it?
What's your excuse? I do it for the pain.
'87 4-Runner Crawler - 4-link rear and fj-80 front axle
'03 Ford Excursion Diesel - Tow pig and DD
toymaniac is offline   Reply With Quote Quick reply to this message
Old 09-04-2005, 07:12 PM   #2 (permalink)
Member # 40937
Send a message via AIM to damageinc2785
well an H3 hummer has a 5 speed but it has the inline 5. i think the flywheel and stuff is the same for the 5 and the 6.
damageinc2785 is offline   Reply With Quote Quick reply to this message
Old 09-05-2005, 10:31 AM   #3 (permalink)
Member # 5329
Send a message via AIM to camo kid Send a message via Yahoo to camo kid
If I am not mistaken the 4.2 inline six from the trailblazers uses the same bellhousing as the I-5s from the colorados. I also remember seeing somewhere that the bolt patern on the bellhousing was the same as tho one from toyota trans (I just dont remember wich one).
I hope this helps
Jeff
83 yota ex show truck,406,700r, marlin stuff,and now one ton with big swampers
camo kid is offline   Reply With Quote Quick reply to this message
Old 09-05-2005, 09:50 PM   #4 (permalink)
ferg's Avatar
Member # 33169
Originally Posted by camo kid
... also remember seeing somewhere that the bolt patern on the bellhousing was the same as tho one from toyota trans (I just dont remember wich one).
R151F/R150F
ferg is offline   Reply With Quote Quick reply to this message
Old 09-05-2005, 09:56 PM   #5 (permalink)
Member # 144
the 4, 5 and 6 vortec motors are all based on the same block. Or at least, so I'm told.
That's because you're a pinko fascist. - Haole
I know what antidisestablishmentarianist means
mike is offline   Reply With Quote Quick reply to this message
Old 09-06-2005, 07:01 AM   #6 (permalink)
TEX
Member # 603
Yup, same bore & stroke on all 3 as a matter of fact. One issue with the 4.2 though is that the axle runs through the oil pan. I would assume you could get around that by using a 2wd tranny pan...... possibly.
Next question, is that engine too long for your Toyota?
TEX
Thanks to:
Extreme Performance
Bear Creek Auto Recyclers
TEX is offline   Reply With Quote Quick reply to this message
Old 09-12-2005, 06:42 AM   #7 (permalink)
Member # 22064
http://www.inliners.org/cgi-bin/ulti...c;f=3;t=000538
Greg55_99 is offline   Reply With Quote Quick reply to this message
Old 08-20-2009, 09:35 PM   #8 (permalink)
Member # 18528
Send a message via AIM to BenMara
Bump lookin for new info for these engines and transmissions
Function before Fashion
BenMara is offline   Reply With Quote Quick reply to this message
Old 05-29-2011, 08:29 AM   #9 (permalink)
Member # 191501
I can Tell you its an awsome motor and have been debating this same one myself. The only Problems i can see existing is deck hight/diff clearance. This is a very tall engine thus the hole in the pan for the axle on 4wd. the 2wds still have this same hole. the vortec 4cyl 5 cyl and this engine are all the same blocks/bolt patterns. its the same as the 4.3l and the 350 they just chopped some cyl's off. There is no support for this swap so doing it on a pollution controlled jeep would require alot of custom wiring and possibly a stand alone PCM. thats as far as i have gotten with it if i find out more ill let you know
Lasvjeep is offline   Reply With Quote Quick reply to this message
Old 05-29-2011, 01:12 PM   #10 (permalink)
Member # 20304
Send a message via AIM to BarrelRoll
I'm pretty sure these guys are running one in a 7200 truck and might be able to help
http://www.samcofabrication.com/proj...?g2_itemId=864
This board is no doubt slowly moving from Pirate4x4 to ElitistYuppyWithTooMuchMoney4x4.
-Braxton 357
BarrelRoll is offline   Reply With Quote Quick reply to this message
