pics of a slave cyl set up on a sm465 - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 09-06-2005, 12:43 PM   #1 (permalink)
AVS60/40SPLIT's Avatar
Member # 30112
looks like the factory chevy set up was all "rod and lever"
what have you done to convert to a hydrolic slave cyl.
pics would be appreciated
thanx
jim
AVS60/40SPLIT is offline   Reply With Quote Quick reply to this message
Old 09-06-2005, 01:50 PM   #2 (permalink)
Dabbler
actionpaintball's Avatar
Member # 29562
Send a message via AIM to actionpaintball
Get a chevy hydraulic style bellhousing...thats it...
actionpaintball is offline   Reply With Quote Quick reply to this message
Old 09-06-2005, 02:37 PM   #3 (permalink)
jeeplord's Avatar
Member # 28273
This is off my SM420, using the S-10 bellhousing, the bracket was fabbed from the steel on the original S-10 slave and some 1/4" plate
[QUOTE=kodiak1232003]"RUN, WHITE PEOPLE!! RUN!..SAVE YOUR FAWKING SELVES!!!" or some sh#t, in broken engrish...."[/QUOTE]
jeeplord is offline   Reply With Quote Quick reply to this message
Old 09-06-2005, 03:06 PM   #4 (permalink)
G.C. Bandit's Avatar
Member # 3237
Send a message via AIM to G.C. Bandit
ILL GET SOME PICS TONIGHT. I used a toy land crusier slave cyl that bolts to the bellhousing. Then ran a steel braided line to the stock master
TJ/Wrangler MUTT...
Dana 80 37 Spline, Discs :)
Bling HP60 Dendenbears,Chromos/Longfields FULL HYDRO 47LTB's Locked with C&R BreadLocks 350TBI Sm465 203-205 Gen2 Doubler
[SIZE="5"][B][COLOR="Blue"]ROCKZOMBIES4X4.com[/COLOR][/B][/SIZE]
R.I.P. Dave "Kyle"
That was one hell of a ride, I will never forget!
G.C. Bandit is offline   Reply With Quote Quick reply to this message
Old 09-06-2005, 03:08 PM   #5 (permalink)
Member # 107
Send a message via AIM to The Jerk Send a message via MSN to The Jerk Send a message via Yahoo to The Jerk
thats why you made it, your running cruiser parts.
RockZombie:68FJ40 LPG350/420/300/60/70
69FJ40 350/stock | 70FJ55 350/700r4/205 | 72FJ55 stock
The Jerk is offline   Reply With Quote Quick reply to this message
Old 09-06-2005, 05:30 PM   #6 (permalink)
Member # 24876
i made mine this past weekend... seome 1" wide 3/16 strap bolts to the bellhousing bolts and a brace back to the block that supports the back... doesnt flex..
then a few hours after it was made, i saw the chevy hydro bell housing. looks pretty sweet...i would lean toward that route...... anyone know the years for this?
sorry, i know pics are worth 1000 words
[COLOR="Lime"]'85 Toyota ext cab. 4 cyl. 5.29s. Chromoly birfs. dual cases. hi-steer. OBA. front ARB. rear welded. cage.[/COLOR]
FullsizeYota is offline   Reply With Quote Quick reply to this message
Old 09-06-2005, 05:59 PM   #7 (permalink)
Member # 144
I did my 420 like this:
I was going to essentially do the same but off the mounting bolts instead
That's because you're a pinko fascist. - Haole
I know what antidisestablishmentarianist means
mike is offline   Reply With Quote Quick reply to this message
Old 09-07-2005, 08:33 PM   #8 (permalink)
Member # 39942
slave cylinder
i used the original bellhousing off the 465 and used a kit that UPS uses on there truck. it had the slave cylinder, the bracket, and the clutch. ups replaces all that stuff regularly even if it is not worn out. just search there dumpster behind one of there terminals. ha! ha! just talk to there mechanics and they will probably give ya the stuff they remove.
1983 Toyota, really beat up, old school rig.
windrockguru is offline   Reply With Quote Quick reply to this message
Old 09-07-2005, 10:12 PM   #9 (permalink)
Member # 17313
my buddy runs the factory setup on his rig..
A recent survay of over 1000 trailer parks in the southeast found the 350 chevy out numbered the mullet by nearly 4:1, draw your own conclusion.
Jrod-13 is offline   Reply With Quote Quick reply to this message
Old 09-08-2005, 09:34 AM   #10 (permalink)
Member # 3237
heres some pics of mine
TJ/Wrangler MUTT...
R.I.P. Dave "Kyle"
Old 09-08-2005, 09:45 AM   #11 (permalink)
GloNDark's Avatar
Member # 2482
Here's my setup
350 to SM465. Using all stock cruiser hydro clutch parts. I actually have a bracket that might work for ya, if your interested.
BUILD THAT FUCKING WALL!!!
GloNDark is offline   Reply With Quote Quick reply to this message
Old 09-08-2005, 12:36 PM   #12 (permalink)
Member # 30112
glondark, you got a pm.
looks like a good basic set up.
thanx all!!!
Old 09-08-2005, 12:47 PM   #13 (permalink)
Member # 8459
FYI- the bracket pictured above by GC bandit is available from advance adapters. It also has holes to run a Jeep slave cylinder if you want something more common and easier to pickup than the more rare 'cruiser stuff. Its the bracket I have as well. Don't recall the price ?19.99?.
Never ending Frankenstein FJ40 project.
ckolloff is offline   Reply With Quote Quick reply to this message
Old 09-08-2005, 12:55 PM   #14 (permalink)
Brian1's Avatar
Member # 2205
Mine - Chevy 350 to 420 using chevy cast bellhousing, same basic setup. Bracket attaches to block and bellhousing bolt. Slave is a CNC and I use a Wilwood master. Note - to bleed it I have to take it off and flip it so the bleeder is on top, I couldnt find a fitting to install it the "correct" way.
Brian
NMOffroad.com
Brian1 is offline   Reply With Quote Quick reply to this message
Old 09-08-2005, 03:36 PM   #15 (permalink)
Member # 347
You have the fittings. The body of the slave is threaded with 1/8" NPT pipe threads. Swap the brass fittings for the bleed and supply, and you'll have it handled.
Randii
[B]
[/B]... you pick up after your dog, so clean up after YOU, too.[I][SIZE="1"]
- [B]VIRTUAL RALLY[/B] for the HAMMER TRAILS in JOHNSON VALLEY
- [B]VIRTUAL RALLY[/B] for TELLICO
and
- [B]KOH Pledge Drive:[/B] for
[/SIZE][/I]
randii is offline   Reply With Quote Quick reply to this message
Old 09-08-2005, 04:56 PM   #16 (permalink)
Brian1's Avatar
Member # 2205
Randii
I should have been more specific 90 degree fitting with an AN fitting, it just wasnt going to happen in the space I had without it hanging down too far and hitting the exhaust. I spent a good part of a day running around town and looking online for fittings. I did find fittings for it but it was stupid looking by the time I had it hooked up. Small inconvienence but I dont have to bleed it very often.
Brian
NMOffroad.com
Old 10-05-2005, 06:43 AM   #17 (permalink)
Member # 30549
Does anyone have pics of how they installed a CNC push style slave on a Dodge 4-speed(np435?)
Thanks
792.5cj5 is offline   Reply With Quote Quick reply to this message
Old 10-05-2005, 11:28 AM   #18 (permalink)
Member # 4406
I have a stock hydro clutch bellhousing for an SM 465 for sale, off an '87 K5 Blazer. I'm in the SE Denver metro area, if you're interested, email me pete.corssmit@stollemachinery.com.
Those brackets are a pretty slick idea.
Pete
Life should not be a journey to the grave with the intention of arriving safely in an attractive and well preserved body, but rather to skid in sideways , beer in hand, body thoroughly used up, totally worn out and screaming "WOW, what a ride."
pcorssmit is offline   Reply With Quote Quick reply to this message
