Member # 23020
Hydro assist mount
I am ready to mount my PSC hydro assist now that my crossover is done, and am curious if this bracket is hefty enough to take it. It is a bracket for the track bar, and my thought was to mount the two tabs for the ram on this bracket, about where the bottom hole is.
![]() ![]() Here is how it is welded. It is onto the axle tube, on the spring bucket plate, and one in the middle. It isnt welded on teh backside by the spring yet, but it will be. ![]() So, is this a good enough place to mount the tabs for the axle end of the ram? Otherwise I could mount it on the diff cover that I made out of 1/4" but this seems like a better option for clearance etc. Thoughts and opinions welcome. j
I have a jeep. It is green. |
Team RedNeck
yeah that bracket should be strong enough. i would get it directly behind the tierod if you could but below is fine if your sure you won't hit it on anything.
Matt Hodges, Owner West Texas 4Wheel & Offroad 325-653-7001 1811 W. Beauregard Ave. San Angelo, TX. 76901 www.westtexasoffroad.com Redneck is not a style, fashion, or something that occurs due to location – It’s way of life. You can’t be one - either You Are or You Aren’t. I AM.~SilverZuk |
Member # 23020
Sorry, I should clarify, I meant the bottom bolt hole on the new bracket ABOVE the tie rod. So, the track bar is in one hole, and then mounting the ram directly under that. I want it above hte tie rod as I am sure I would hit on plenty below it.
Member # 10068
Josh,
Looks good to me. That bracket will be plenty strong enough for your hydro assist tabs. Good luck, and enjoy it!
<>< '98 XJ - 3/4ton - D300 4:1 - 39.5" IROKs - cage [URL=http://www.rockmonkey4x4.com]RockMonkey 4x4[/URL] '04 PSD - Tow Rig |
Member # 21414
Not to jack your thread, but I have a couple ?'s about your setup, is that a custom track bar bracket or did you buy it? what did you use for spring buckets? I see you used a RE bridge and upper mounts, was that a complete RE kit Looks good and I would think that would be a alright place to mount your Ram. What high steer arm is that? Thanks
87' zooki on toys 00' PSD F350 Tow Hoe |
Member # 23020
Thanks Mac, I think it should be fine as well.
Rollin, that is a bracket made by ORGS and yes I used the full RE kit for teh mounts. Works fine and worth the money to save the time fabbing them all. THe high steer arm is from sky manufacturing. Its rad. Anyone else have issues with mounting it on that bracket? j
Member # 25216
I originally mounted my ram bracket to a similar trackbar bracket and it simply bent the shit out of the bracket. I had to brace the shit out of the ram mount to stop it from bending the trackbar mount. If I ever move my ram, it's going to be mounted on my diff cover.
#327 Lambert Motorsports Follow us on facebook here. Help us race in KOH 2012. #327 Build and #327 Pics Thanks to our sponsors: Clayton Off-Road BFGoodrich Extreme Axle Sales |
#8 (permalink) | |
Member # 23020
j
Member # 25216
I mounted mine "single sear" fashion, welded to the trackbar mount. It bent the trackbar mount towards the passenger knuckle.
Member # 23020
So do you think it had to do with being in single shear? Or was it to do with thte way the bracket was mounted? So you would mount it to the cover then?
j
#12 (permalink) |
Member # 25216
I think, it was the combo of mounting to a trackbar bracket that is only supported on 3-sides and a long ram mount bracket (which gave it a lot of leverage). I wouldn't mount off the trackbar bracket... because I bent the crap out of mine.
#13 (permalink) |
Yes I agree your bracket should be fine
Here are a few pics to refer to ![]() MIne is very much like yours wil be ![]() ![]() HULK: You know where the rest of the pics are
www.iMPAKS.com, www.LoneRiderBeer Tread Lightly Master Trainer My Builds: Bus / RV, New Jeep, Camper / ToyHauler, CTD Tow Rig, Jeep XJ, Shop |
#14 (permalink) |
My only suggestion may be to add a brace like pic i attached.. that is kinda what i did for mine just to make sure it will hold
