Moderator
Member # 10249
Power steering pump spill proof lid?
I have a 79 Chevy PS pump Im Using for my full hydro, I cut the filler off it and planned to extend it with some tube to make it a larger volume resivor but the diaphram does not seal well, so when I get it side ways this will be a mess.
SO now I have a PS pump with no cap at all. I can weld anyting to it. I was eyeing a spare gass cap and filler I have sitting around, it has a pressure release, but I dont know how many PSI or if that would be acceptable for the PS pump? I was also eyeing generic radiator caps. How much pressure is ok to build up inside the PS pumps? Whats a good fix to make a spill proof PS pump? Ill be running a 7.4cu/rev valve, with a 8X1.125 single ended ram, so the resivor will have a different displacement for each direction. Thanks Im itching to try out the new steering.
Dave, 2013 KOH "Got, Some of it" #697 JIMMY'S 4X4 Grand Cherokee Buggy ADS Shocks LQ4-Th400-Atlas4sp D60 14B Come wheel with us WheelingArizona.com Ashman's youtube channel |
Member # 5982
I bought a filler cap and machined bung from Summit. Welded it onto the top of the can, welded in a bung for a pipe fitting and ran a hose from that to an overflow can. Plenty of capacity for hydro assist.
Was that a comment meant to hurt? RU Dysfuncational http://thisdysfunctional.org/forum |
Member # 1636
I bought a replacement can from PSC for the GM pump. I am running the same (dimensionally) pump as you. It replaces the ham can GM resivior with a sealed can for use with remote res systems. It's got a -10 return fitting brazed into the top too.
PSC # 25-45x $35
[url]http://www.pirate4x4.com/forum/misc-stuff-sale/1192938.html[/url] |
Moderator
Member # 10249
I welded on the gas cap and filler neck, It will work for initial testing, may be perminent if it works good.
