Wheel Base Chart (Inside) - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 03-25-2006, 04:15 PM   #1 (permalink)
Member # 37519
This is a good chart to answer a lot of the stock wheel base questions
Wheelbase (inches) Vehicle
GM
86..............Geo Tracker 89+
100............S10 Blazer 2 dr 83+
107............S10 Blazer 4 dr 91+
108............S10 Pickup Shortbed 83+
117............S10 Pickup Longbed 83+
122............S10 Pickup extended cab 86+
107............Oldsmobile Bravada 91+
104............Full Size Blazer /Jimmy 69-72
106............Full Size Blazer /Jimmy 73+
115............Fullsize Pickup 6 Bed 60-72
117............Fullsize Pickup 6 Bed 73-87
131............Fullsize Pickup 8 Bed 73-87
129............Suburban 73+
117............Fullsize pickup 6 Bed 88+
131............Fullsize pickup 8 Bed 88+
155............Fullsize pickup ext,Cab 88+
Ford
92..............Early Bronco 66-77
94..............Bronco II 84-90
107............Ranger PU shortbed 83+
113............Ranger PU Long Bed 83+
125............Ranger PUExt cab 85+
102............Explorer 2 Dr 91+
112............Explorer 4 dr 91+
104............Fullsize Bronco 78-79
105............Fullsize Bronco 80+
116............F150 / 250/ 350 6 Bed 78+
133............F150/ 250/350 8 Bed 78+
155 ...........F150/250/350 Ext Cab 78+
Dodge
92..............Dodge Raider 87 89
110............Ram 50 Mini PU 83-86
105............Ram 50 PU shortbed 87+
116............Ram 50 PU longbed 87+
112............Dakota PU Shortbed 87+
124............Dakota PU Longbed 87+
131............Dakota PU Shortbed Extra Cab 97-99
106............Ramcharger 74-91
115............Fullsize PU 6 Bed 74+
113............Fullsize PU 8 Bed 74+
149 ...........Fullsize PU Club Cab 80+
JEEP
83.............CJ5 72-75
93.............CJ7 76-86
103...........CJ8 (Scrambler) 81-85
93.............YJ 87-95
93.............TJ 97+
101...........XJ (small Cherokee) 84-2001
113.........MJ Comanche PU SB (6ft) 86-92
120.........MJ Comanche PU LB (7ft) 86-92
108...........Fullsize Wagoneer 69-91
118...........Fullsize PU shortbed 69-87
131 ..........Fullsize PU Longbed 69-87
International Harvester
100............Scout 75-80
118 ...........Traveler, Terra PU 75-80
Toyota
90.............LandCruiser FJ40 60-83
104...........LandCruiser FJ45LV 63-67
116...........LandCruiser FJ45LPB 63-66
89.............Landcruiser 2 Dr 72-84
107...........Landcruiser 4 Dr 81-90
112...........Landcruiser 4 Dr 91+
103...........4 Runner 84-91
103...........PU Shortbed 79+
112...........PU Longbed 79-84
112 ..........PU Longbed and ext cab 85-91
Nissan / Datsun
101............PU Shortbed 78-86
112............PU Longbed + kingcab 78-86
104............Pathfinder 87+
104............Hardbody Shortbed 87-91
116............Harbdody Longbed 87-91
Mitsubishi
92...............Montero 2Dr 83-89
106.............Montero 4Dr 89-91
105.............PU shortbed 83-91
116 ............PU Longbed 83-91
Isuzu
104.............Trooper 2 Dr 83-88
104.............Trooper 4 Dr 83-91
92..............Amigo 2 Dr 91+
91.7".......... 1st gen Amigo 89-94
96.9"...........2nd gen Amigo 98+
109.............Rodeo 91+
104.............PU Shortbed 83+
117.............PU Longbed 83+
117............. PU Ext. Cab 88+
Suzuki
79...............Samurai 85-90
86...............Sidekick 2 Dr 89+
98 ..............Sidekick 4 Dr 90+
Daihatsu
86............... Rocky 90-91
[COLOR="Black"]..............[/COLOR]//)
[COLOR="Black"]............[/COLOR],/../
[COLOR="Black"]...........[/COLOR]/..../
[COLOR="Black"].....[/COLOR]//'...'/`
[COLOR="Black"]..[/COLOR]/'/.../..../......./\
[COLOR="Black"].[/COLOR]('(.......... ~/'...')
[COLOR="Black"]....[/COLOR]\.................'...../
[COLOR="Black"]......[/COLOR]''...\.......... _.
[COLOR="Black"].......[/COLOR]\..............(
[COLOR="Black"].........[/COLOR]\.............\
mudslinger99 is offline   Reply With Quote Quick reply to this message
Old 03-25-2006, 05:06 PM   #2 (permalink)
Typical White Guy
Member # 9769
A correction on the Isuzu information.
1st gen Amigo (89-94): 91.7"
2nd gen Amigo (98+): 96.9"
________
Toyota Corolla E30 History
Indyguy is offline   Reply With Quote Quick reply to this message
Old 03-25-2006, 08:05 PM   #3 (permalink)
Member # 1792
'72 and older Blazers are 104" And I believe The shortbox Chevys are 119"
CJJuggy.FI406/465/205/D60/14bolt FF on 39.5 Swampers.Kid's '70 Jeepster D44/14bolt FF.
Cheepin is offline   Reply With Quote Quick reply to this message
Old 03-25-2006, 08:10 PM   #4 (permalink)
Member # 6957
how about a 70 fj40 cruiser
ironpig70 is offline   Reply With Quote Quick reply to this message
Old 03-25-2006, 08:20 PM   #5 (permalink)
Member # 37519
Post it up if you know what it is
Old 03-25-2006, 08:23 PM   #6 (permalink)
ACHASE6002's Avatar
Member # 54836
this should be added to the faq board
ACHASE6002 is offline   Reply With Quote Quick reply to this message
Old 03-25-2006, 08:27 PM   #7 (permalink)
Member # 6957
don't know mines stretched to 98 now
Old 03-25-2006, 08:32 PM   #8 (permalink)
Member # 25339
Toyota LandCruiser FJ40 90"
Toyota LandCruiser FJ45LV 104.3"
Toyota LandCruiser FJ45LPB 116.1"
'82 Toyota LandCruiser BJ60 3B AXT turbo, factory A/C, factory PTO winch, rear Aussie locker. From Vancouver, B.C., Canada!
'67 Toyota LandCruiser FJ45LV being restored by my shop class c/w 3B and turbo, H41 low range 4 speed, as well as minitruck disc upgrade!
cruiser guy is offline   Reply With Quote Quick reply to this message
Old 03-25-2006, 08:47 PM   #9 (permalink)
Member # 37519
What years are those numbers for ?
2 door or 4 door ?
Old 03-25-2006, 09:03 PM   #10 (permalink)
Member # 37519
Where is this FAQ board you speak of located
Old 03-25-2006, 09:06 PM   #11 (permalink)
Member # 37519
Ok I've added all the ones you guys posted up as you will see in yellow.. If there are anymore that should be added or corrected post'em up and I will add those too
Old 03-25-2006, 10:27 PM   #12 (permalink)
Member # 22721
Send a message via MSN to TheRipper Send a message via Yahoo to TheRipper
Hey you forgot the Pinto 4x4 jacked up with 44" tires and dana 30 front with a amc 20 rear.. ..good thread and thx here is the bump.
[SIZE="5"][COLOR="Blue"]
to rockwell question's and info...[/URL]
TheRipper is offline   Reply With Quote Quick reply to this message
Old 03-25-2006, 11:57 PM   #13 (permalink)
jgarden1's Avatar
Member # 584
66-77 early bronco = 92 inch
jgarden1 is offline   Reply With Quote Quick reply to this message
Old 03-26-2006, 08:32 AM   #14 (permalink)
Member # 35922
fj40 90" 1960-1983
fj45lv 104.3" 1963-1966
fj45lpb 116.1" 1963-1966
rogersfj401969 is offline   Reply With Quote Quick reply to this message
Old 03-26-2006, 10:34 AM   #15 (permalink)
Member # 37519
This one says it's a 67
Toyota Land Cruiser FJ45LV wagon 1967
Old 03-26-2006, 10:36 AM   #16 (permalink)
Member # 37519
All the updates have been added
Old 03-26-2006, 12:57 PM   #17 (permalink)
tw89yj's Avatar
Member # 52621
Comanche specs are a little off, sb 113", lb 119"
tw89yj is offline   Reply With Quote Quick reply to this message
Old 03-26-2006, 01:30 PM   #18 (permalink)
Member # 68649
LandRovers
1948-1953 ..80 inches.
1954-1957 --86 or 107 inches
1957-1982--88 or 109 inches
1982-present--93.5 or 110 OR 127 INCHES.
RangeRover classics --100 inches
Discoveries --100 inches.
There are a couple more RangeRover variants but I can,t remember the numbers.
Bill.
Agrover is offline   Reply With Quote Quick reply to this message
Old 03-26-2006, 01:33 PM   #19 (permalink)
Member # 14922
Samurai 82"
deepmud is offline   Reply With Quote Quick reply to this message
Old 03-26-2006, 01:59 PM   #20 (permalink)
Member # 37519
Originally Posted by deepmud
Samurai 82"
Are you saying that the 85-90 info should be 82 inches instead of the 79 that's listed or what
It helps if you post years along with the numbers
Old 03-26-2006, 03:55 PM   #21 (permalink)
Member # 25339
Yep, just like mine!
Old 03-26-2006, 04:02 PM   #22 (permalink)
Member # 37519
So does that change the numbers he has from 1963-1966 to 63-67 but keep the 104.3 wheelbase ?
Is 67 the last year of that model or what
Old 03-26-2006, 04:06 PM   #23 (permalink)
Member # 2058
Send a message via ICQ to Foxfab Send a message via AIM to Foxfab Send a message via Yahoo to Foxfab
FJ25 is 2285mm which equals 89.96 inches
FJ45SWB is the same wheelbase as a FJ45LV
Undoing years of Toyota engineering one SAS at a time!!
2007 Yaris--1959 FJ25--www.yankeetoys.org
Foxfab is offline   Reply With Quote Quick reply to this message
Old 03-26-2006, 04:17 PM   #24 (permalink)
Member # 37519
What years 00-00 ?
Old 03-26-2006, 05:02 PM   #25 (permalink)
piratebuggy's Avatar
Member # 53597
My 78 Jeep CJ5 has 84" wheelbase.
78 Jeep CJ-5 304 ---setting off car alarms with extreme prejudice.......
out cali style!!!!!!
piratebuggy is offline   Reply With Quote Quick reply to this message
