4 link Calculator 101 please? - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 04-02-2006, 03:41 PM   #1 (permalink)
another Lance's Avatar
Member # 26077
Send a message via AIM to another Lance
Sorry if I sound like a dumbass but can someone do a nice writeup for the tech section on how to use the link calculators, something pretty detailed that you don't have to be an engineer or a suspension expert to read and figure out how to use them. I was messing around with it the other day and would really like to know what anti-squat is, not only what it is but what percent is the goal, like higher or lower. roll over angles? whats that? also RC slope, height, angle? no clue. instant center? Vector? roll point?
or if there already is some kind of training link, please post it! thanks!
Originally Posted by John F. Kennedy
Today, we need a nation of Minutemen, citizens who are not only prepared to take arms, but citizens who regard the preservation of freedom as the basic purpose of their daily life and who are willing to consciously work and sacrifice for that freedom.
another Lance is offline   Reply With Quote Quick reply to this message
Old 04-02-2006, 04:10 PM   #2 (permalink)
TRD
TRD's Avatar
Member # 8286
can of worms.
There is no single answer.
Your best bet is to start reading.
To get started do a search for Gordon and read what he says.
Ryan
909-265-4443
We use VOIP phones - call or text today!
Shop
- Custom Spring and Valving Specialists
Check out the cool rigs we work on:
Visit Us at EJS
TRD is offline   Reply With Quote Quick reply to this message
Old 04-02-2006, 04:14 PM   #3 (permalink)
tdavis's Avatar
Member # 908
Here's how to get the values to plug into the calculator..
http://www.pirate4x4.com/forum/showp...3&postcount=21
I take my zuk out for walks.
tdavis is offline   Reply With Quote Quick reply to this message
Old 04-02-2006, 04:17 PM   #4 (permalink)
TRD
TRD's Avatar
Member # 8286
I got time so here is a quick summary of what you are going to find:
anti-squat - how much the chassis lifts or squats on acceleration. Common range is 0-125%. My feeling is that you should stay under 80%. Also look at how it changes with compression and droop
RC height - Your chassis is rolling about the roll center. The higher it is the less body roll you will have. Down side to a high roll center is that your axle will move weird (side to side under articulation) because your axle rotates about it also. Downside to low roll center is lots of body roll. Can be aided by a sway bar
RC angle - Effects over steer and under steer. Also can be seen as roll steer (axle moves forward and back as it articulates). The front can angle up as it goes back but the rear should be flat or angle down.
I think that is all you really need for definitions. If you really want to know what is going on start reading.
Ryan
909-265-4443
Shop
Visit Us at EJS
Old 04-02-2006, 04:27 PM   #5 (permalink)
Member # 2274
Send a message via AIM to Dust Puppy
yeah dude big can o worms. read the god of suspensions thread and the 4 link 4 dummy's thread and there are a couple other good ones.
or if your around this way swing by and ill explain it one day im out in the garage.
Its all about the Bling!!!!!!
"no voodoo, no black magic" -- BillaVista
Originally Posted by JESSE_at_TLT
I could make rollcages shaped like balloon animals and they sure would be different and eye catching. Want one?
Originally Posted by Dieselmh
Do the world a favor and just kill her. It needs to be done.
Dust Puppy is offline   Reply With Quote Quick reply to this message
Old 04-02-2006, 06:10 PM   #6 (permalink)
Member # 5110
4 Bar Link Calculator Version 3.0 Tutorial
This is one that I started working on a while ago and never finished...
Any comments are welcome (post here or email to triaged at gmail dot com)
Let's start with the Vehicle Specifications.
Most of these should be obvious. If they aren’t don’t read any farther.
Vehicle CG Height: To measure this you will need access to some accurate scales. See www.jeepaholics.com for the procedure. A quick guestimate is to measure the top bell housing bolt height from the ground. This way however, is an approximate of the Sprung Mass CG Height (2nd tab).
Unsprung Mass: With the wheels on the ground this is everything that does not move if you bounce the body of the vehicle up and down. Some parts will have one end that will move up and down and one end that will not (like shocks or the links themselves). These parts are generally considered with half of their mass as unsprung mass. The best way to measure this is to unbolt the parts (tire/wheel, rear axle, shocks, etc.), weigh them individually, and add them all up.
Park your vehicle on level ground
Remove the rear tires and support the axle with jack stands at operating height if you need the clearance to climb under the vehicle
Use a plumb bob from the center of the axle tube to the ground on each side of the vehicle. Mark these points with chalk on the ground and draw a line between them.
Measure the distance between the marks, divide by two and mark the center. Now use a large square to mark a line under the center of the vehicle or do the same thing in the front and connect the dots.
Now start looking for places to put your links. When you find places you like drop the plumb bob from there. Measure from the transverse line (the one under the rear axle) to where the plumb bob meets the ground. This is your “X” value. Now measure from the longitudinal line (front to back down the center) to where the plumb bob meets the ground. This is your “Y” value. Now measure the length of the plumb bob from the point you picked for the suspension to mount to the ground. This is your “Z” value. Do this for both ends of both links on one side of the vehicle.
After you have these measurements (some basic and some far from it) enter them all into the light blue cells on the main page.
Link to thread on my calculator http://www.pirate4x4.com/forum/showthread.php?t=204893
Triaged is offline   Reply With Quote Quick reply to this message
Old 04-02-2006, 07:42 PM   #7 (permalink)
Member # 65516
Where do oversteer and understeer play into this?
JackieTreehorn is offline   Reply With Quote Quick reply to this message
Old 04-20-2006, 12:45 AM   #8 (permalink)
Member # 31804
I have a couple questons also, bear* with me here.
Is 0 to -1 the best roll axis angle for crawling? do u want roll over steer? or understeer? if u have like lets say 6 degrees is that going to effect it that much?
Should your roll axis be level as possible?
when measureing cog or cg is the easiest way to do this measuring from the top bellhousing bolt to the ground?
how high is too high for your roll center height? should it be above your upper links, etc. is there a standard go around on that.
I have read a litte bit on the suspension links for dummies thread, maybe i should get a red star.
FatMeats12 is offline   Reply With Quote Quick reply to this message
Old 04-20-2006, 05:49 AM   #9 (permalink)
stomper4x4's Avatar
Member # 22805
it effects how a rig will track when its flexed out, like in a boulder field,, and on steep rutted out climbs where on side will fall into a hole or rut...A little is ok(id say no more then 6*, some might say more, but just as long as its not in the double digits its good), but alot is not good..
[B][COLOR=Green][QUOTE]
So you want all for yourself alone
And you don't think about the other man
Let me tell you my friend if you gonna live this life
It's not good for you to build strife
Robert Neshta Marley ; Cravin choke puppy[/QUOTE][/COLOR][/B]
stomper4x4 is offline   Reply With Quote Quick reply to this message
Old 02-17-2009, 02:39 PM   #10 (permalink)
Member # 121272
*yes yes I know holy 3 year old thread batman and the op prob won't read this but oh well some might*
But also another big part of how body roll can be felt in over/understeer, is say you are turning around a sharp corner at a fair amount of speed, weather it be you are driving your 4-linked DD on the streets, or you are in a rock racing tournament, or you are just chasing that bunny rabbit in your crawler...
If you have lots of body roll, it is felt the same as rear steer (say when like your flexing out on a rock.) So, when you turn around a corner at speed and your body rolls, your rear axle will change its square-ness to the frame. The outside tire (in the corner) moves towards the rear of the vehicle, and the inside tire moves towards the front of the vehicle. Make sense? (its all because your control arms follow an arc of a circle, rather than move straight up and down)...
When this happens, your rear axle will actually not follow in the exact same line as your frame, and so therefore it is felt as "Understeer" and you will not turn as sharp as you were origionally planning on.
ChocFlip201 is offline   Reply With Quote Quick reply to this message
Old 02-17-2009, 03:53 PM   #11 (permalink)
Member # 5110
Originally Posted by ChocFlip201 View Post
...So, when you turn around a corner at speed and your body rolls...The outside tire (in the corner) moves towards the rear of the vehicle, and the inside tire moves towards the front of the vehicle. ...and so therefore it is felt as "Understeer" and you will not turn as sharp as you were origionally planning on.
What you describe is actually oversteer and it will turn sharper.
Old 02-17-2009, 08:52 PM   #12 (permalink)
Member # 109931
What is the best percentage to shoot for on upper and lower lengths? I have been trying to lower my oversteer from 6* to 2* and to do this my uppers will be at 80%. 70% gives me more like 3* . I was almost content with 6* oversteer as my final result untill I started trying different numbers on the calculator. Is it going to be that much of a difference?
offroadwerks is offline   Reply With Quote Quick reply to this message
Old 03-18-2009, 10:00 PM   #13 (permalink)
Member # 121272
Yep you're right thanks for the correction... I was tired when I posted that...
Old 05-31-2015, 06:40 AM   #14 (permalink)
Newbie
Mauiview's Avatar
Member # 357018
Send a message via Skype™ to Mauiview
Appreciate the info in this thread to help with the mysteries of 4link.
Christine - 99 TJ 42in IROKS, TR Beadlocks, PSC Full Hydro, RCI Fuel Cell, 108 WB, Artech trusses
Crush 2013 JKU 35in Nitto, Rugged Ridge 17x9, Poison Spyder Customs Bumpers, Rockers
and
Mauiview is offline   Reply With Quote Quick reply to this message
