Bleeding Brakes - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 05-09-2006, 11:44 PM   #1 (permalink)
Member # 27601
Bleeding Brakes
OK, after reading the brake bleeding post in the toy forum I decided to say screw it and voice my opinion. I used to bleed the air out of brake lines by the normal method of one person pumping and the other turning the bleeder valves. This worked ok. Then one day I didn't have anybody to help and decided to do it myself. I found that by opening all the bleeders and leaving them open for 5ish minutes did the trick. This may not work on some of the crazy brake line routes but it works on all of my vehicles.
Hope somebody else can use this.
camodan is offline   Reply With Quote Quick reply to this message
Old 05-10-2006, 12:00 AM   #2 (permalink)
rokcrwlrtj's Avatar
Member # 27180
Send a message via AIM to rokcrwlrtj
gravity bleeding, yup
Save Tellico Post 296
rokcrwlrtj is offline   Reply With Quote Quick reply to this message
Old 05-10-2006, 12:04 AM   #3 (permalink)
Member # 3475
i just use another person and
open line push once to floor close line
and repeat about twice..
no pumping involved
REELMOAB.COM
Moab Austin is offline   Reply With Quote Quick reply to this message
Old 05-10-2006, 12:14 AM   #4 (permalink)
Member # 57140
Send a message via Yahoo to rockcrawler80
Vacuum bleeders work nice as well
[B][/B][FONT="Arial Black"][SIZE="4"][COLOR="Yellow"][B]FKM[/B][/COLOR][/SIZE][/FONT]
rockcrawler80 is offline   Reply With Quote Quick reply to this message
Old 05-10-2006, 05:56 AM   #5 (permalink)
PAToyota's Avatar
Member # 37600
Send a message via AIM to PAToyota Send a message via Skype™ to PAToyota
I did the two-person route for years. Then finding someone else got to be a problem. Tried the MityVac route, but always ended up with more air in the lines than when I started. Bought a Motive Power Bleeder. That thing is well worth the money.
94 GMC 6.5TD K1500 Yukon SLE / 93 Chevy 6.5TD K2500
85 Toyota 22R RN60 4x4
PAToyota is offline   Reply With Quote Quick reply to this message
Old 05-10-2006, 06:28 AM   #6 (permalink)
Member # 14094
Send a message via AIM to Hvy_Chevy
holy shit - how long did it take you to think of that?
Size does matter.
Leave the Zukes to those who really understand.
Hvy_Chevy is offline   Reply With Quote Quick reply to this message
Old 05-10-2006, 06:41 AM   #7 (permalink)
DUG
DUG's Avatar
Member # 858
Send a message via AIM to DUG
Works even better if you only open one bleeder at a time.
Will not work on some ABS systems and anythign where the master is not the highest point in the system.
Be yourself, by yourself.
DUG is offline   Reply With Quote Quick reply to this message
