Info: Dana 70-B - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 05-18-2006, 07:00 AM   #1 (permalink)
Mr.N's Avatar
Member # 1635
Info: Dana 70-B
The following had a Dana 70-B rear axle. (Same offset for gears as 70-U and 70-HD)
In my Spicer info this is all that was listed, the docs have a lot of Dana 70's that are not listed as to what type of 70's they are... so take this for what it's worth.
Also not listed is the 70-BF, which is a front drive axle. I'm slowly working on gathering info on this axle and keep my notes here -> http://77cj.littlekeylime.com/Dana70.htm
BOM 70 type Location Manufacturer Year Application
603337-10 70B Rear Dodge 1972-75 70 B
603337-11 70B Rear Dodge 1972-75 70 B
603337-12 70B Rear Dodge 1972-75 70 B
603337-3 70B Rear Dodge 1972-75 70 B
603337-7 70B Rear Dodge 1972-75 70 B
603337-9 70B Rear Dodge 1972-75 70 B
603934-1 70B Rear Ford 1979-80 E-350 Van - 70B
603934-10 70B Rear Ford 1979-80 E-350 Van - 70B
603934-2 70B Rear Ford 1979-80 E-350 Van - 70B
603934-3 70B Rear Ford 1979-80 E-350 Van - 70B
603934-4 70B Rear Ford 1979-80 E-350 Van - 70B
603934-5 70B Rear Ford 1979-80 E-350 Van - 70B
603934-6 70B Rear Ford 1979-80 E-350 Van - 70B
603934-7 70B Rear Ford 1979-80 E-350 Van - 70B
603934-8 70B Rear Ford 1979-80 E-350 Van - 70B
603934-9 70B Rear Ford 1979-80 E-350 Van - 70B
603935-1 70B Rear Ford 1979 F-350 - 70B
603935-2 70B Rear Ford 1979 F-350 - 70B
603935-3 70B Rear Ford 1979 F-350 - 70B
603936-1 70B Rear Ford 1979-80 F-350 U-Haul - 70B
603936-2 70B Rear Ford 1979-80 F-350 U-Haul - 70B
603936-3 70B Rear Ford 1979-80 F-350 U-Haul - 70B
603937-1 70B Rear Ford 1979 F-350 - 70B
603937-10 70B Rear Ford 1979 F-350 - 70B
603937-11 70B Rear Ford 1979 F-350 - 70B
603937-12 70B Rear Ford 1979 F-350 - 70B
603937-13 70B Rear Ford 1979 F-350 - 70B
603937-14 70B Rear Ford 1979 F-350 - 70B
603937-2 70B Rear Ford 1979 F-350 - 70B
603937-3 70B Rear Ford 1979 F-350 - 70B
603937-4 70B Rear Ford 1979 F-350 - 70B
603937-5 70B Rear Ford 1979 F-350 - 70B
603937-6 70B Rear Ford 1979 F-350 - 70B
603937-7 70B Rear Ford 1979 F-350 - 70B
603937-8 70B Rear Ford 1979 F-350 - 70B
603937-9 70B Rear Ford 1979 F-350 - 70B
603938-1 70B Rear Ford 1979 E-350 - 70B
603938-2 70B Rear Ford 1979 E-350 - 70B
603938-3 70B Rear Ford 1979 E-350 - 70B
603938-4 70B Rear Ford 1979 E-350 - 70B
603938-5 70B Rear Ford 1979 E-350 - 70B
603938-6 70B Rear Ford 1979 E-350 - 70B
603938-7 70B Rear Ford 1979 E-350 - 70B
603938-8 70B Rear Ford 1979 E-350 - 70B
603962-1 70B Rear Ford 1980 F-350 - 70B
603962-10 70B Rear Ford 1980 F-350 - 70B
603962-2 70B Rear Ford 1980 F-350 - 70B
603962-3 70B Rear Ford 1980 F-350 - 70B
603962-4 70B Rear Ford 1980 F-350 - 70B
603962-5 70B Rear Ford 1980 F-350 - 70B
603962-6 70B Rear Ford 1980 F-350 - 70B
603962-7 70B Rear Ford 1980 F-350 - 70B
603962-8 70B Rear Ford 1980 F-350 - 70B
603962-9 70B Rear Ford 1980 F-350 - 70B
605038-1 70B Rear Ford 1981-83 F-350 DSO Dual Wheel - 70B
605038-10 70B Rear Ford 1981-83 F-350 DSO Dual Wheel - 70B
605038-11 70B Rear Ford 1981-83 F-350 DSO Dual Wheel - 70B
605038-12 70B Rear Ford 1981-83 F-350 DSO Dual Wheel - 70B
605038-13 70B Rear Ford 1981-83 F-350 DSO Dual Wheel - 70B
605038-14 70B Rear Ford 1981-83 F-350 DSO Dual Wheel - 70B
605038-15 70B Rear Ford 1981-83 F-350 DSO Dual Wheel - 70B
605038-16 70B Rear Ford 1981-83 F-350 DSO Dual Wheel - 70B
605038-17 70B Rear Ford 1981-83 F-350 DSO Dual Wheel - 70B
605038-18 70B Rear Ford 1981-83 F-350 DSO Dual Wheel - 70B
605038-19 70B Rear Ford 1981-83 F-350 DSO Dual Wheel - 70B
605038-2 70B Rear Ford 1981-83 F-350 DSO Dual Wheel - 70B
605038-20 70B Rear Ford 1981-83 F-350 DSO Dual Wheel - 70B
605038-22 70B Rear Ford 1981-83 F-350 DSO Dual Wheel - 70B
605038-3 70B Rear Ford 1981-83 F-350 DSO Dual Wheel - 70B
605038-4 70B Rear Ford 1981-83 F-350 DSO Dual Wheel - 70B
605038-5 70B Rear Ford 1981-83 F-350 DSO Dual Wheel - 70B
605038-6 70B Rear Ford 1981-83 F-350 DSO Dual Wheel - 70B
605038-7 70B Rear Ford 1981-83 F-350 DSO Dual Wheel - 70B
605038-8 70B Rear Ford 1981-83 F-350 DSO Dual Wheel - 70B
605042-1 70B Rear Ford 1981-82 E-350 - 70B
605042-10 70B Rear Ford 1981-82 E-350 - 70B
605042-11 70B Rear Ford 1981-82 E-350 - 70B
605042-12 70B Rear Ford 1981-82 E-350 - 70B
605042-2 70B Rear Ford 1981-82 E-350 - 70B
605042-3 70B Rear Ford 1981-82 E-350 - 70B
605042-4 70B Rear Ford 1981-82 E-350 - 70B
605042-5 70B Rear Ford 1981-82 E-350 - 70B
605042-6 70B Rear Ford 1981-82 E-350 - 70B
605042-7 70B Rear Ford 1981-82 E-350 - 70B
605042-8 70B Rear Ford 1981-82 E-350 - 70B
605042-9 70B Rear Ford 1981-82 E-350 - 70B
605054-1 70B Rear Ford 1981-83 F-350 U-Haul - 70B
605054-3 70B Rear Ford 1981-83 F-350 U-Haul - 70B
605054-4 70B Rear Ford 1981-83 F-350 U-Haul - 70B
605054-6 70B Rear Ford 1981-83 F-350 U-Haul - 70B
605057-1 70B Rear Ford 1981-82 E-350 School Bus - 70B
605057-2 70B Rear Ford 1981-82 E-350 School Bus - 70B
605057-3 70B Rear Ford 1981-82 E-350 School Bus - 70B
605057-4 70B Rear Ford 1981-82 E-350 School Bus - 70B
605057-5 70B Rear Ford 1981-82 E-350 School Bus - 70B
605057-6 70B Rear Ford 1981-82 E-350 School Bus - 70B
605057-7 70B Rear Ford 1981-82 E-350 School Bus - 70B
605057-8 70B Rear Ford 1981-82 E-350 School Bus - 70B
605080-2 70B Rear Ford 1981 1/2/1983 E-350 DSO - 70B
605080-4 70B Rear Ford 1981 1/2/1983 E-350 DSO - 70B
605139-1 70B Rear Ford 1982 1/2/1983 E-350 DSO - 70B
605143-1 70B Rear Ford 1983 2-Jan E-350 DSO - 70B
605143-2 70B Rear Ford 1983 2-Jan E-350 DSO - 70B
603703-1 70B Rear GCM/Chev 1979 G-300 146" WB - 70B
603703-2 70B Rear GCM/Chev 1979 G-300 146" WB - 70B
605002-1 70B Rear GCM/Chev 1980-82 G-300 146" WB - 70B
605002-2 70B Rear GCM/Chev 1980-82 G-300 146" WB - 70B
605002-3 70B Rear GCM/Chev 1980-82 G-300 146" WB - 70B
605002-4 70B Rear GCM/Chev 1980-82 G-300 146" WB - 70B
605002-5 70B Rear GCM/Chev 1980-82 G-300 146" WB - 70B
605134-1 70B Rear GCM/Chev 1983 G-300 146" WB - 70B
605134-2 70B Rear GCM/Chev 1983 G-300 146" WB - 70B
More?
If you want a 70-U list let me know.
A 70-3HD list is here -> /forum/general-4x4-discussion/474243-info-dana-70-3hd.html
Catholic | My Dana Articles and Info -> http://77cj.littlekeylime.com/web_rs44.html
Mr.N is offline   Reply With Quote Quick reply to this message
Old 05-18-2006, 08:18 AM   #2 (permalink)
Proeliator's Avatar
Member # 12042
Send a message via Yahoo to Proeliator
Originally Posted by Mr.N
More?
Darn tootin we do! Thanks
[QUOTE=94stepsideford;7266691]Seth is scarier than you though. He looks like he would kill and eat a baby with his bare hands.[/QUOTE]
'73 F250, 533 on N2o, 35spln chromo Superior/CTM D60/D70, twinsticked 205, hydro-assist, f&r lockers, 46" Titan R1s. Evil social media page link:
Proeliator is offline   Reply With Quote Quick reply to this message
