Does anyone out there have pics or info on the proper way to "pipe" in a full hydraulic steering system with a hydroboost brake kit??? The guy I spoke to at Vanco Power Brakes said it has been done. Anyone here done it???
x2. If anyone is the poster child for doing this right, this is the man. He speaks the truth.willyswanter said:I run dual pumps. A stock p-pump for the brakes and a KRC pump for the steering. I tried a single pump but the hydroboost did not like the high pressure of the KRC. It pulsated the pedal way bad. Plus under hard braking the brakes get priority so you lose power steering for a second or two. Doesn't sound like much but it sucks.
Check out my "double ended hydro assist" thread for all the pics of my brackets and setup.
I spoke to Eddie. We did not talk about me having to run two pumps. He just said it is doable.VancoPBS said:If you got a hi-flow Hydroboost from me there's no reason at all to run 2 pumps. If you did call me, let me explain it better. If you didn't get it hi-flowed through me or run 2 pumps.
