Hydraulics Expert, Reversing pump rotation. - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 07-03-2006, 07:45 PM   #1 (permalink)
Member # 2967
Pump
http://www.surpluscenter.com/item.as...435-B&catname=
Cheap gear pump, Rotation is wrong on it. Can the pump rotation be reversed?
I have changed the rotation on variable displacement piston pumps by floping the charge pump around. I was just wondering if the rotation could be changed..
Everyone said there would be bad days, I just never figured there would be this many.
Toyota_Jim is offline   Reply With Quote Quick reply to this message
Old 07-03-2006, 08:16 PM   #2 (permalink)
78bronco460's Avatar
Member # 9152
You should be able to just swap the inlet and outlet and run it backwards.
A sword never kills anybody; it is a tool in the killer's hand.
Lucius Annaeus Seneca
78bronco460 is offline   Reply With Quote Quick reply to this message
Old 07-03-2006, 08:22 PM   #3 (permalink)
Member # 14848
here you go same pump, opposite rotation, click here
BTW, the surplus center pumps that are reversible say so in their descriptions, so I would guess that one is not. There are also far cheaper pumps than that at surplus center that are also the right direction for you, like this one, clicky
I just bought one of their 1.0 cu in. gear pumps by Dynamic, and it is excelent quality and was only like $110.
Good luck to you,
Jason
2006 JCORF Buggy, 60's,Locked F&R,42" TSLs,EFI460,C6,Atlas5.0 Comp Case
1988 Bronco,in progress
Wicked_S10 is offline   Reply With Quote Quick reply to this message
Old 07-03-2006, 08:24 PM   #4 (permalink)
Member # 2967
Im trying to save buying a new pump...
Im going to rip this one apart tomarrow and see what can be done inside.
Old 07-03-2006, 08:25 PM   #5 (permalink)
Member # 9152
Here's a link to the repair manual for that pump with instructions for changing input rotation:
http://hydraulics.eaton.com/products/pdfs/07-624.pdf
