Exoskeleton build suggestions. - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 09-24-2006, 03:56 PM   #1 (permalink)
nissancrawler's Avatar
Member # 76684
Well, once I get my axles ordered, the build will be down for the 2 months it takes to get the housings, so I may make the exo sooner than planned. Here's my idea.
The blue bars will be openable, obviously. I don't know how to explain the latching idea here, but it will work. They're low on the door, because my other doors will get cut that low, too. the yellow pipes in the bed will be exhaust and intake. Please keep in mind this is rough (obviously) and if it looks a little angled where it should be straight, it's probably meant to be straight. I'm not going for complete elimination of body damage, just anything that could incapacitate the vehicle/injure occupants. I don't want miles of tubing on it. Any suggestions/ideas from people that have done this? What size tubing would you recommend? .120 1.5 or 1.75? I don't mind if a tube bends and it has to be replaced, as long as it does it's job.
Oh, and the front of the exo will bolt onto the bumper/brushguard that's not showin in the pic.
[QUOTE=nahmus;9175355]asking chit chat to stop before they are done is kinda like asking piranhas to stop after one bite.[/QUOTE]
nissancrawler is offline   Reply With Quote Quick reply to this message
Old 09-24-2006, 04:32 PM   #2 (permalink)
Bunk's Avatar
Member # 41059
Send a message via Yahoo to Bunk
WAY too much tube
Bunk is offline   Reply With Quote Quick reply to this message
Old 09-24-2006, 04:48 PM   #3 (permalink)
Member # 76684
Ok, as in you would eliminate what? I'm asking for constructive comments.
Old 09-24-2006, 04:51 PM   #4 (permalink)
Member # 2892
Send a message via AIM to Pavement Pounder83 Send a message via Yahoo to Pavement Pounder83
just protect the cab. thats all thats worth saving.
Drew Reynolds
[SIZE="4"][COLOR="Red"]ECV 7-11[/COLOR][/SIZE]
1991 Toyota Ex Cab
All Stock
1993 Xr650L
[COLOR="Red"]
[/COLOR]
Isautia[88:54] Delta World, Town: PBB Broski
Pavement Pounder83 is offline   Reply With Quote Quick reply to this message
Old 09-24-2006, 04:56 PM   #5 (permalink)
Member # 76684
I would agree, but this will be my daily driver (I have the titan if this gets screwed, so no biggie), plus after dumping $8000 or so into this sas, I won't be able to do anymore major mods after this. I maybe should have stated this earlier, but my goal is to make this last for 4-5 years, at which point it'll probably get stripped and the complete drivetrain will go in a buggy. However, if there are tubes ppl think I can safely eliminate, or ones I need to add to keep it structural, I'll do that. I also need an idea on tubing size. Also, part of the reason the rear is the way it is, is because I'll be building a crude type of can-back for it.
Old 09-24-2006, 06:02 PM   #6 (permalink)
Mr. Personality
Azzy2000's Avatar
Member # 11869
8,000 for a SAS??? why?
Azzy2000 is offline   Reply With Quote Quick reply to this message
Old 09-24-2006, 06:12 PM   #7 (permalink)
Member # 10796
$8000 seems a little high for a SAS unless you are buying some high dollar axles.
Iwould suggest selling the bed while it's still straight and building a flat bed in it's place. Integrate the flatbed into the exo. You'll save a little weight, gain a bunch of rearward visibility and clearance, and the exo will be stronger as a whole.
USMC 0311
Semper Fi
CWToyota is offline   Reply With Quote Quick reply to this message
Old 09-24-2006, 06:32 PM   #8 (permalink)
Member # 76684
You know cw, you really might be right...I would build a flat bed with the "sides" like...allpro's? kit. hmm... As for the $8,000, that's front and rear diamond housings, all the 60/9" components, all alloy axles, strange third members, arb lockers, dual cases with low range in one case, steering, suspension, sliders, bumpers, beadlocks, tires, etc. Now, back to contemplating the flat bed thing...
Old 09-24-2006, 07:06 PM   #9 (permalink)
numtel's Avatar
Member # 31735
Send a message via AIM to numtel
Have you looked at other exo cages, there is not the need for that much tube. The cage isn't meant to keep your paint from being scratched but to save your life and in the case of an exocage, the windshield too.
More pics at http://www.trailbusters4x4.org/index...k%20Zierenberg
This cage didn't bend or deform at all after being rolled onto the roof.
numtel is offline   Reply With Quote Quick reply to this message
Old 09-24-2006, 07:14 PM   #10 (permalink)
Member # 76684
I'm not concerned about paint, however, my doors still have to be able to work. I can probably elminate and/or use some pretty light tubing in places that need support for the can-back, though.
Old 09-24-2006, 09:36 PM   #11 (permalink)
Member # 2892
take the doors off or make tube doors when you wheel
Drew Reynolds
1991 Toyota Ex Cab
All Stock
1993 Xr650L
[COLOR="Red"]
[/COLOR]
Old 09-24-2006, 09:51 PM   #12 (permalink)
mj
Member # 1919
is that a harpoon platform out front?
mj is offline   Reply With Quote Quick reply to this message
Old 09-24-2006, 10:28 PM   #13 (permalink)
American's Avatar
Member # 12257
Send a message via AIM to American
An exocage is SUPPOSED to do whatever the FAWKIN' HELL the owner of the truck wants it to do. Mine, will prevent as much body damage as possible, and eventually will tie into an interior cage for structure (that whole saving my life thing). Yours, on the otherhand, does whatever the hell you want it to do.
I personally say that you need to exo the cab pretty good, because you're inside it. Plus a cab is pretty hard to replace. Then run a bar or two to your front bumper that will protect the fenders and tie into the cab exo. Same for the bed. done.
American is offline   Reply With Quote Quick reply to this message
Old 09-24-2006, 10:31 PM   #14 (permalink)
American's Avatar
Member # 12257
You seem to be alot like me. You need a set of wheeling doors, and a set of DD'ing doors. I plan to buy a set from a wrecked truck sometime down the road to make 1/2 doors out of.
My whole plan is to have a "road mode" with the full doors, power windows, subs/amp, cheap 37's, etc. And a "trail mode" with the 1/2 doors, no door windows, removed subs/amp, not-so-cheap 39.5's etc.
But I'm weird like that...
Old 09-24-2006, 10:50 PM   #15 (permalink)
Member # 76684
I totally agree, that's why I said my other doors will be cut down to the body line, which is why those bars are that low. I'll be running 38x12.50 sx's or 39.5 Iroks on the trail, and 35" xterrains on the road. I guess I'll probably eliminate the bars at all, if the wheeling doors get trashed, I'll just get more junkyard ones.
Old 09-25-2006, 05:19 AM   #16 (permalink)
Member # 41653
whats being done diffrent...
diagonals going oppisite the ones already on the fender areas..and TWIN tubes for the center post and plated between the 2..(keep bendin the dang things!!!)...I would really support yer middle pillar right behind the door...either double tubes or square tubing..somethin...
and window bars...they've saved the windshield too many times to count since it was done in june...
when it was done..I've since added the snorkle and paint.. www.bbpfab.com did it..and I think its awsome..exactly what I wanted..with a little builder flair thrown in for fun!!..(its mosly body protection..and rollover protection for me and my 3yr old daughter that HAS to go wheelin with dad..cant leave her at home..she gets PISSED!!...16point..200ft 1.5 .120 and .090)
Gotta Love people who have "soon to have/be" in their signatures....Im soon to be thin,rich and nice..
yea right..
"They are little angels but they are trying to fuck the wings off each other!"
--Sturgell
Black eyes last but a week, the shame of sodomy lasts a lifetime.-TheRedHorseman
wanderer-RRORC is offline   Reply With Quote Quick reply to this message
Old 09-25-2006, 07:38 AM   #17 (permalink)
thhhpptthh!
sceep's Avatar
Member # 10798
Send a message via AIM to sceep Send a message via MSN to sceep
ideas for ya.. this was an xtracab i did awhile back. pre-flatbed.
Originally Posted by USDA forest service website
It is every American's birthright to use the national forests and grasslands in multiple ways, including outdoor recreation in all its forms.
sceep is offline   Reply With Quote Quick reply to this message
Old 09-25-2006, 08:16 AM   #18 (permalink)
Member # 11921
I second the flat bed.
Two main tubes for the cab.
X behind the cab.
I went with tube clamps for my door bars. I take them off when I have doors on.
My build thread:
ramv is offline   Reply With Quote Quick reply to this message
Old 09-25-2006, 11:08 AM   #19 (permalink)
ZUKROVER's Avatar
Member # 18798
This is one I built for a buddy. It has mog axles under it.
IT'S NOT VERY BIG AROUND, BUT IT SURE IS SHORT!
ZUKROVER is offline   Reply With Quote Quick reply to this message
Old 09-25-2006, 11:19 AM   #20 (permalink)
motorcitydak's Avatar
Member # 54956
Send a message via AIM to motorcitydak
Is that truck linked up front held up by leaf springs? Looks like it has shackles on the front and rear
96 dakota 44/9 4.56s loc rite front, detroit rear, 3 linked w 14 inch FOA coilovers and Alcan leafs on the rear, Dana 300, 35in MTZs. O ya, and that things got a HEMI!!!
motorcitydak is offline   Reply With Quote Quick reply to this message
Old 09-25-2006, 11:24 AM   #21 (permalink)
ZUKROVER's Avatar
Member # 18798
It is on leaf springs. The shackle you see is for the anti wrap/traction bar. There is one for the front and rear axle.
Old 09-25-2006, 11:30 AM   #22 (permalink)
MUCHADO's Avatar
Member # 21752
Send a message via AIM to MUCHADO
that taco exo was pulled off real clean.. I like it.
MUCHADO is online now   Reply With Quote Quick reply to this message
Old 09-25-2006, 11:56 AM   #23 (permalink)
thhhpptthh!
sceep's Avatar
Member # 10798
x2 very nice...
Old 09-25-2006, 12:07 PM   #24 (permalink)
Member # 54956
How did you weld/paint/coat it? Is it removable so you could finish all that?
Old 09-25-2006, 12:15 PM   #25 (permalink)
Member # 76684
I'm a big fan of the 'yota cages. I think I'll do mine quite close to that. I'll build a set of low skinned trail doors supported by tube, and call that good. I was going to be doing a bed bob anyway, so the flatbed is very tempting. Keep posting up, I'm getting better ideas!
