Dana 60 3.08? - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 12-15-2006, 05:21 PM   #1 (permalink)
Ground and Pound's Avatar
Member # 79968
Dana 60 3.08?
I'm looking for higher ratio gears for a dana 60. The lowest I have been able to find after market is 3.54. I found a ford F250 with a 60 and 3.33 during a trip to a local pick and pull. Are there any factory applications for 3.08s?
Ground and Pound is offline   Reply With Quote Quick reply to this message
Old 12-15-2006, 05:47 PM   #2 (permalink)
bremen242's Avatar
Member # 28687
Dana 61s have 3.08s. I believe the lowest is 3.54 for the 60s. You can't fit anything lower than than that because there isn't enough room for that huge pinion.
bremen242 is offline   Reply With Quote Quick reply to this message
Old 12-15-2006, 05:57 PM   #3 (permalink)
Member # 79968
Ahh! That makes sense I suppose! I was going to grab that 3.33 diff but I was thinking that it might be a bit hard to find replacement gears should the need occur. Dana 61 huh...I don't know much about them but I keep hearing ppl say to avoid them. I'll have to do some more digging to figure out how to tell a 60 from a 61 and whether a 61 will work for me. Thanks for the reply.
Old 12-15-2006, 06:35 PM   #4 (permalink)
Member # 14848
The only reason people tell you to avoid the D61 is because of the limited ratio selection, from the factory the lowest gear ratio you could get in one was 4.10 and w/o doing some odd ball carrier/spacer/gear set swaps, you cannot get any lower than that. The D61 has larger diameter tubes than most D60s, more center section webbing, and in some cases larger spindles. They are plenty tough, and use indenticle sized gears to a D60, the only difference is the pinion offset in the casting of the center section.
Later,
Jason
2006 JCORF Buggy, 60's,Locked F&R,42" TSLs,EFI460,C6,Atlas5.0 Comp Case
1988 Bronco,in progress
Wicked_S10 is offline   Reply With Quote Quick reply to this message
Old 12-15-2006, 06:59 PM   #5 (permalink)
bremen242's Avatar
Member # 28687
Later,
Jason
you can get over 4.10 gears, you just need the right carrier and spacer.
Old 12-15-2006, 07:04 PM   #6 (permalink)
jarvisjeep's Avatar
Member # 55381
Send a message via AIM to jarvisjeep Send a message via Yahoo to jarvisjeep
Ok d61 aside, why do you want 3.08's? Do you have double 4:1 tcases with a 7:1 first gear or somthing?
[COLOR="Lime"][CENTER]4x4 limo guy
[/COLOR][/center]
jarvisjeep is offline   Reply With Quote Quick reply to this message
Old 12-15-2006, 07:29 PM   #7 (permalink)
Member # 14848
No shit, sounds like something I said...
...D61 is because of the limited ratio selection, from the factory the lowest gear ratio you could get in one was 4.10 and w/o doing some odd ball carrier/spacer/gear set swaps...
I am fairly certain 4.10 is the lowest D61 gearset, you can use D60 gears and a special spacer on the D61 carrier, or D61 gears and a standard spacer on a D60 carrier, but for ratios available for a D61, on a D61 carrier, W/ D61 gears is 4.10
But like the other guy says, why do you want such a high ratio? Just a highway DD or something?
Old 12-15-2006, 09:53 PM   #8 (permalink)
TR
TR's Avatar
Member # 2877
Well if you had a 4wd ford truck with a powerstroke you could put 3.08s in both ends like the 2wd guys and get better fuel milage & higher top end speed
Penn State study finds that heavy drinking is 100% easier than giving a shit
TR is offline   Reply With Quote Quick reply to this message
Old 12-16-2006, 01:00 AM   #9 (permalink)
Member # 79968
Thanks for the info on the 61! I found some info in Billavista's Dana 60 Bible which is something I didn't check before as it is listed as "front dana 60" and I had no idea that a 61 was ever offered as a front diff...learn something new everyday. 3.00 and 3.07 are offered for the D61, perfect but goofy offsets, spacers, dana 61 specific gears...the million dollar question... will an ARB for a 60 work in a 61?
Old 12-17-2006, 10:14 AM   #10 (permalink)
Keith's Avatar
Member # 52
Ha, I just put a detroit and 4.56's in a D61. No problem...
Keith is offline   Reply With Quote Quick reply to this message
Old 12-17-2006, 10:28 AM   #11 (permalink)
Member # 187
4.88 and arb no problem in a 61. the lowest for a 60 is 3.31 3.33 is dana 61
GearMan is offline   Reply With Quote Quick reply to this message
Old 12-17-2006, 10:33 AM   #12 (permalink)
Member # 4243
Fords are easy... if its a Dana axle and says 3.07 on the tag.... it can't really be anything but a D61.
Dodge cobbler... junkyard style (1stgen cummins theme)
u2slow is offline   Reply With Quote Quick reply to this message
Old 12-17-2006, 12:03 PM   #13 (permalink)
bremen242's Avatar
Member # 28687
What size of spacer and which Dana 60 carrier have you used?
Old 12-17-2006, 12:22 PM   #14 (permalink)
Member # 14848
When I started searching for info for my D61/TTB50 frankenstein axle, I spoke with reider raceing about gearing choices for it. I didn't have the factory D61 carrier, as the PO had put D60 stuff in it and absolutely shreaded the gears, and reider told me that I could do the following. D60 4.10 and numerically lower carrier, standard D60 ring gear space (about $20 from MR Gasket), and any D61 ratio, although most D61 gears have been discontinued, and there are only a few ratios left available. Or I could go D60 4.56 and numerically higher ratio and their D61 spacer, (about $70 from them), and any D60 gear set for the 4.56 serries carrier.
I am going to do 4.10's since I have a 4.10 D60 carrier, but I am looking for 3.54 D61 gears for it, as that is what I prefer, but they have been discontinued...
Later,
Jason
Old 12-17-2006, 12:33 PM   #15 (permalink)
Member # 187
4.56 and lower 2 spacers mr. gasket machined right thrust back .080 to make up distance
Old 12-17-2006, 12:50 PM   #16 (permalink)
Dan Dibble's Avatar
Member # 12695
If anyone is looking for a Dana 61 Detroit locker 30spline I have one. 250.00 and It will be on your doorstep.
Dan
"We live in the Land of the Free because of the brave." Please remember our Troops!
Dan Dibble is offline   Reply With Quote Quick reply to this message
Old 12-17-2006, 05:45 PM   #17 (permalink)
Member # 79968
K this is odd, the thread summary on the main page says 19 replies yet I only show 16...
Anyway, thanks for all the awesome 61 info. Another 4 hours at pick and pull and I didn't find anything lower than 3.54. Anyone know of an application that should have 3.07? I'm getting tired of crawling under trucks and vans to scrape the BOM tag clean enough to read it only to find it's not what I'm looking for.
Old 12-17-2006, 06:42 PM   #18 (permalink)
Member # 4243
I saw a D61FF at the wrecking yard last week... was labelled 83 F250. Tip: It does NOT have even a slightly smooth shape to it. Very chunky.
Old 12-17-2006, 06:58 PM   #19 (permalink)
Member # 29210
Send a message via AIM to Davethorik
front or rear? i know for fronts, most common is from an early cummins dodge without overdrive.
Davethorik is offline   Reply With Quote Quick reply to this message
Old 12-17-2006, 06:58 PM   #20 (permalink)
Dan Dibble's Avatar
Member # 12695
61s with 3.07s
Dodge FRONTS
610265-1,-3. 1987-88
610333-1,-3. 610342-1,-3. 1989
610358-1,-3 1991-92
610431-1 610406-1,2,3,4 1992-93
FORD REARS
603438-6 F-250 1974-75
603713-5 603714-1 603540-5 603899-1 1976-78 F-250 4X2
603594-19 1975-78 E-250 (VAN)
603925-1 1979 F-250 4X2
603932-7 1979-80 E-250
603946-1,2 1980-81 F-250 SEMI-FLOAT 4X2
605022-10,12 1981-83 E-350 DRW CHASSIS
605039-5 1981-83 F-350 CHASSIS
Good Luck,
Dan
Old 12-17-2006, 07:27 PM   #21 (permalink)
Member # 79968
I should have mentioned that I just needed a rear.
Thanks for that list Dan...where'd you track that down?
Old 12-17-2006, 07:33 PM   #22 (permalink)
Dan Dibble's Avatar
Member # 12695
I have a Dana/Spicer library that dates from 1967-2000
Dan
Old 12-20-2006, 05:16 PM   #23 (permalink)
Member # 79968
I made a quick trip to the wreckers with Dan's cheap sheet of rigs with 3.07 Dana 61's. The first truck I saw that fit the year and model in that list did infact have 3.07's. Thanks for the info, it saved me a ton of time
