Who makes a Ford 9 truss - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 12-29-2006, 11:52 AM   #1 (permalink)
Marc Daniels's Avatar
Member # 27287
Where can I get a truss for a ford 9" that is the racing style that welds to the back of the housing, it needs to be the full width of the housing, someone told me summit had these, but I couldn't find them on there site. Had all sorts of problems bending tubes forward with the dana 44 axles with a mountain off road traction bar, so am switching to the 9 because I already have the detroit and nodular housing, just wanted to weld the truss on first, and didn't want to use tubing. Thanks Marc
Marc Daniels is offline   Reply With Quote
Old 12-29-2006, 12:05 PM   #2 (permalink)
Rotten Sperm
Nordic1's Avatar
Member # 63386
newb
http://store.summitracing.com/egnsea...115+4294841822
(x) Remove Department: Drivetrain
(x) Remove Section: Differential & Rear-End Components
(x) Remove Part Type: Axle Housing Braces
Nordic1 is offline   Reply With Quote
Old 12-29-2006, 12:13 PM   #3 (permalink)
YJ4RoX's Avatar
Member # 1930
pretty sure currie and moser have them too.
YJ4RoX is offline   Reply With Quote
Old 12-29-2006, 12:27 PM   #4 (permalink)
Well Done Man!
welndmn's Avatar
Member # 398
You want one that touches wheel bearing to wheel bearing.
The one Summit/jegs sells, just touches the center, and it for drag crap, not 4 wheeling IMO.
Mark
welndmn is offline   Reply With Quote
Old 12-29-2006, 12:34 PM   #5 (permalink)
YJ4RoX's Avatar
Member # 1930
I believe the one strange engineering sells touches the entire length of the housing.
Old 12-29-2006, 01:17 PM   #6 (permalink)
Member # 13857
Send a message via AIM to Tutt
a truss that welds to the top of the axle will do much more to prevent your axle from smiling or frowning.
Josh <><
Tutt is offline   Reply With Quote
Old 12-29-2006, 01:44 PM   #7 (permalink)
Member # 9666
Giant Motorsports Truss
77Blaza is offline   Reply With Quote
Old 12-29-2006, 03:49 PM   #8 (permalink)
Member # 27287
Thanks for the info. Marc
Old 12-29-2006, 04:28 PM   #9 (permalink)
Rotten Sperm
Nordic1's Avatar
Member # 63386
Originally Posted by 77Blaza View Post
Thats cool because it integrates all of the control arm mounts into the truss. At first I was like 350 for a truss And then I saw it was a truss, lowers and upper with all mounts boxed good price if those brackets work for your setup
Old 12-29-2006, 05:52 PM   #10 (permalink)
Banned
Snoopy's Avatar
Member # 5650
TNT Customs have freakin awesome truss at a good price.
Pictures are at:
http://www.colorado4x4.org/vbb/showthread.php?t=79698
I've got two of these trusses on the way.
Snoopy is offline   Reply With Quote
Old 12-29-2006, 06:13 PM   #11 (permalink)
Rotten Sperm
Nordic1's Avatar
Member # 63386
Pictures are at:
I am loving the front control arms
There should be some kind of brace on the bend but that's not bad for hi clearance for the tires and rocks
