dana 61 HELP??????? - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 01-19-2007, 10:54 AM   #1 (permalink)
Member # 71842
Question dana 61 HELP???????
To start off my build has:
Chevy 350 bored and stroked
TH 350 auto
NP 205 doubled to Dana 300 with 4:1 kit
Dana 60 front 35 spline inner and outers, 4.88 gears
38 X 14.5 SX Swampers
Ok; I have been looking for a Dana 70 and came across what seems to be a Dana 61, 35 spline out of a 81-83 F350 Bill of material 605040-3.
How does this axle compare to the 70 or 60 with 35 spline shafts?
How easy is the 61 to get parts for?
Thanks
Jake
jeepester is offline   Reply With Quote Quick reply to this message
Old 01-19-2007, 11:17 AM   #2 (permalink)
Hendo's Avatar
Member # 20295
Send a message via MSN to Hendo
i was told by a axle dealer that there is no such thing as a d61 and if they was that all the parts are identicle,i have done a search in the past and found no manufacturers info on a d61 just people on the board who had said there is , so i dont know what to believe
Hendo is offline   Reply With Quote Quick reply to this message
Old 01-19-2007, 11:26 AM   #3 (permalink)
Member # 1889
D61 is a high gear ratio (3.07?) D60. The housing is machined with a different pinion to ring offset to allow for the ginormous pinion that a 3.07ish gear requires.
The swap stackup of thick gear, spacer, oddball carrier, etc., has been covered here, but I don't know what terms to search for or remember exactly what has to be done to run it with normal ratios. GearMan knows, if he's around.
Scott@Rockstomper is online now   Reply With Quote Quick reply to this message
Old 01-19-2007, 11:40 AM   #4 (permalink)
k7mto's Avatar
Member # 32838
Some time ago I found a Ford van with a D61, but when I posted on various boards, the overall consensus was to ignore it and find a D60. As I recall there are issues finding desirable gears, lockers, etc. for the D61.
k7mto is offline   Reply With Quote Quick reply to this message
Old 01-19-2007, 11:44 AM   #5 (permalink)
Member # 11753
Send a message via ICQ to Sonnenburg Send a message via AIM to Sonnenburg
yea - D61 sucks!!! When I was looking for a rear 60, I brought home probably 2-3 D61 before I found an actual D60. You could theoretically use a stock one, but good luck finding aftermarket parts. Also, I bored out my spindles to accept 35 spline shafts, and if you plan on doing that, an easy way to tell if you've got the right axle is by looking at the wheel bearing. It should read 104949. Also, Reider Racing will look up the code on the axle and tell you exactly what it came out of. Just give them a call - really nice guys.
Sonnenburg is offline   Reply With Quote Quick reply to this message
Old 01-19-2007, 11:45 AM   #6 (permalink)
Member # 71842
Wink Dana bill of material list
This axle does exist!!
http://www2.dana.com/pdf/X510-2CVSP.PDF ---Page 139---
And it has 4.10 gears
How does it compare???????
Thanks
Old 01-19-2007, 11:51 AM   #7 (permalink)
Member # 71842
Originally Posted by Sonnenburg View Post
yea - D61 sucks!!!
That is what I'm looking for
Any more opinions
Thanks
Old 01-19-2007, 12:02 PM   #8 (permalink)
Member # 7903
Here's a thread that points to other threads about the Dana 61..
/forum/general-4x4-discussion/245900-d61-gears-detroit-locker.html
JohnnyJ is offline   Reply With Quote Quick reply to this message
Old 01-19-2007, 12:09 PM   #9 (permalink)
Member # 71842
http://www.pirate4x4.com/forum/showthread.php?t=245900
Thank's
Old 01-19-2007, 12:48 PM   #10 (permalink)
Keith's Avatar
Member # 52
I just put 4.56 gears with a detriot in a D61. They do run 3.07's. I did have to run an offset carrier with a spacer and wide gear. I dont know about running a deeper gearset than a 4.56 though
Keith is offline   Reply With Quote Quick reply to this message
Old 01-19-2007, 12:55 PM   #11 (permalink)
Member # 71842
Thank's
Old 01-19-2007, 01:33 PM   #12 (permalink)
Non-Lemming
SanDiegoCJ's Avatar
Member # 840
Originally Posted by jeepester View Post
Thank's
That's the thread I started. I do have a D61 in the rear of my CJ7 and I have
4.88 gears and a detroit locker in it. I got the gears, locker, and ring gear spacer
from Reider Racing. It's been in there for about 2 years without a problem.
One of the great achievements of science has been, if not to make it impossible for intelligent people to be religious, then at least to make it possible for them not to be religious. We should not retreat from this accomplishment.
Salesmen and women. God sells to the ignorant.
SanDiegoCJ is offline   Reply With Quote Quick reply to this message
Old 01-19-2007, 01:36 PM   #13 (permalink)
J Kimmel's Avatar
Member # 2102
I didn't have the time to cross reference to find a Detroit, so I welded mine, 3 years and its still happy, so am I
J Kimmel is offline   Reply With Quote Quick reply to this message
Old 01-19-2007, 01:45 PM   #14 (permalink)
Member # 14848
Give reider raceing a call. They have the skinny on what parts to mix and match to get different gear ratios. They also have a custom machined spacer so you dont have to do the mr. gasket spacer stack... The biggest downfall of the axle, is that most of the dana factory ratios for it have been discontinued. Not a big deal if you are trying to go lower than the factory 4.10, and don't mind useing a D60 carrier and spacer, but I have been trying to find 3.55 gears for one, and no one has them around anymore, and dana discontinued them a few years ago...
If you end up getting a locker for it, drop me a line, I would be very interested in buying your 35 spline carrier.
2006 JCORF Buggy, 60's,Locked F&R,42" TSLs,EFI460,C6,Atlas5.0 Comp Case
1988 Bronco,in progress
Wicked_S10 is offline   Reply With Quote Quick reply to this message
Old 01-19-2007, 02:01 PM   #15 (permalink)
Member # 71842
After reading threads from 2002 and on dana 61 sound like a PITA but after setup sound OK I'll keep looking for a 14 bolt or 70.
THANKS for all the input and help
Old 01-19-2007, 02:28 PM   #16 (permalink)
Member # 14437
I built one. IMHO, 61s are awesome axles. The tubes are bigger than a 60, the spindles are already big enough for aftermarket 35 spline shafts, and the housing has way more meat than a 60 but still has more clearance than a 70. To build mine, I used a 4.56 and numerically higher Detroit,had a custom spacer machined, then the 5.89s set-up perfectly.
freds40 is offline   Reply With Quote Quick reply to this message
Old 01-19-2007, 03:11 PM   #17 (permalink)
Member # 22267
Send a message via AIM to HEEPJEEP
So did regular D60's ever come with 3.07's? Reason being is that I found some dodge one ton axles the webbing mark is too far gone to be able to read if 60 or 61 and I get read the BOM either. I checked the ring gear and it's def 3.07s front and rear (assuming 60 front, and I know its a 70 rear)...
YJ and Corey-So buy some then. I've always wanted a pony. Ponies are badass. Do I have a pony? No.
HEEPJEEP is offline   Reply With Quote Quick reply to this message
Old 01-19-2007, 05:48 PM   #18 (permalink)
Member # 14437
What year truck? My guess is 61. From what I remember, the 61 was created because the pinion for high gears wouldn't fit in the standard 60 housing so they built the 61 with slightly more pinion offset to accomodate the higher gears.
Old 01-20-2007, 11:56 AM   #19 (permalink)
Keith's Avatar
Member # 52
You found a D70U and an D61 if they had 3.07's. The 61 I set up was pretty simple, but the 70u took a bit more playing with different offset carriers, ring gears, carrier spacers.....
Old 04-22-2008, 05:40 PM   #20 (permalink)
Member # 80295
i run 2 dana 61 front and back with 5.13 gear with out any issue, the way to run higher gear in them is simple, you need a carrier part number 706400x from spicer and a mr gasket ring gear spacer, only draw back is your locker is limited to a lunchbox locker or welded
1990 yj on 42 (mine),2002 tj on 35 long arm(for sale need a truck),little weet heart girlfriend
paulyj is offline   Reply With Quote Quick reply to this message
Old 05-05-2008, 07:46 PM   #21 (permalink)
Member # 113531
the dana 61 is a great axle if you can figure ou how to build it. Im running one in the rear of my 91 s-10 with 4.88 gears, detroit locker, and 38" baja claws with absolutely zero problems and it gets wheeled pretty hard in the mud..havent rock tested it yet. As was said before the 61 is esessially a 60 with the pinion slightly offset from the ring gear to allow for higher gears. the lowest stock gear for a 61 is 4.10 I believe, but with the carrier part and the ring spacer you can put what ever you want. Most major brands do make a variety of lockers for the 61 you gotta look around and find someone who knows what they are talking about. In my opinion the 61 is a little stronger than the 60 due to more housing struts.
wg1202 is offline   Reply With Quote Quick reply to this message
Old 05-05-2008, 08:10 PM   #22 (permalink)
speedo's Avatar
Member # 23262
According to Dana's own website the BOM that was shown is for a Dana 61, 4.10 gears and comes with a Trac-Loc.
FORD Model 61 REAR 1981 - 1983 F-350 - FULL FLOAT
Bill Of Material(605040-3) Differential Type( T/L) Ratio( 4.10)
Ring And Pinion Kit(706661-9X)
Gus
The ultimate result of shielding men from the effects of folly is to fill the world with fools.
--Herbert Spencer, English Philosopher (1820-1903)
speedo is offline   Reply With Quote Quick reply to this message
Old 05-05-2008, 10:19 PM   #23 (permalink)
Member # 75018
I f you want all the benefits of the dana 61 ,ie 35 spline and thick-ass housing , find a dodge van with a HD 60 , its wide but ,as big as a dana70 with all the dana 60 ratios and parts . Late 70's and in the 80's , it will have a totally different look to the housing - Its smooth , with 2 parallel ribs , one about 2 inches ahead of the diff cover flange and then the diff cover flange is a matching rib and then on the top , between the pinion yoke and the diff cover , will be a large cast HD.
'69 Jeepster charity case rockcrawler :imagined
pyrocrat is offline   Reply With Quote Quick reply to this message
Old 05-05-2008, 11:14 PM   #24 (permalink)
Member # 2395
Pm gearman. He knows all!
Thanks to everyone who has helped us out!!!
- CTM Racing
Dustin is offline   Reply With Quote Quick reply to this message
Old 05-08-2008, 02:06 PM   #25 (permalink)
Member # 14707
IF you found a smokin deal on a 61 front this debate would be valid. for a rear, why ahssle with a 61? dana 60 rears are very common. if you can't find one i guarnatee you can find a 14 bolt or a sterling 10.25. both of these axles are VERY strong and have a large aftermarket following, plus you can get them for 150 or less!
'87k5 swapped in blown 2.8, th350, 208, 12" suspension lift, custom 5" body lift, ARB locked 10 bolts f/r w/ 2.73's, 49" irocks... never rub = I'M HARDCORE!!! goes anywhere, never been stuck. still rockin despite the hate...you're all just jealous
reeser is offline   Reply With Quote Quick reply to this message
