Member # 7646
Craaaaazy leaf spring pad... what U think
good, bad, no point, not worth the truble,
what http://community.webshots.com/photo/...4860FXdgiSeViv bwahahaha "Dana 14 bolt"
85 suzuki sj 410, 82 suzuki sj 410 pickup 68 IH pickup, 78 Scout II 76 Scoutt II turbo 345 propane |
Member # 2643
Shadetree is what i was thinking. ( mixed feelings).
1985 TOY TRUCK, FULL BLOWN CHEVY 350 V8, DUAL 4 BRL EDELBROCKS ON A 6-71 WEIAND. RUNNING ON METHANE. 625+ HP. REAR DANA 70 WITH DISK BRAKES, 60 FRONT, WELDED & LOCKED, 44"BOGGERS, FULL HYDRAULIC STEERING, RADIATOR IN BED, TILT FRONTEND, W9000I ( YES IT IS BUILT MOSTLY FOR ROCKCRAWLING, WITH A LITTLE EXTRA HP ). www.4x4realm.com |
#3 (permalink) | |
Re: Craaaaazy leaf spring pad... what U think
EMS Offroad |
Member # 1007
that style has actually been around for awhile. It has been discussed in the toyota board too if you want to do a search. I think it is a bad idea. I wouldnt wast 2 min on it myself.
[B][COLOR="Gray"][SIZE="4"][url]www.DLUXfab.com[/url][/SIZE][/COLOR] [/B] |
Dana 14 bolt?
![]() But the pads to me seem like a bad idea, IMHO just my .02
[QUOTE=CAMO;4] [B] build what ya can with what you have and plan on redoing it a few dozen times as you learn the required skills [/B][/QUOTE] Never, underestimate the amount of stupidity in people! |
www.patparts.com
Member # 4821
I think that they're a good idea if they stay together. BC Broncos makes some hinged pads for old Broncos that don't look like they would work as well as that pic. Why does everyone think that these are a bad idea? Isn't everything most of us do pretty shade-tree?
J. J.
#8 (permalink) | |
Member # 8488
04.5 Dodge Ram 2500 Cummins NV5600 4x4 Been there done that got many t-shirts OIF 02/24/03-04/04/04 |
Member # 14
None of those pics are coming up for me, so I'm gonna try one.
BTW I don't see any thing wrong with the "swivel saddle" as he calls it. But that's without knowing his skill level or material used. |
I would be worryed about locating the axle laterally. Seems like with the pivot the leaf spring would be more prone to roll over if a lateral load is placed on the axle. A panhard bar would solve the problem, but I'm not sure I'd trust it without one. What do the rest of you think?
'50 CJ-3A, SVO Turbo 2.3L, T-98, D18, Warn OD, PTO Winch, D30, FFD44, lockrites in both Jeeps, they're not just a hobby, they're a freakin adventure :D :usa: |
#12 (permalink) |
Member # 3273
axle wrap city. That setup looks lie it oughta flex pretty good if the shachles are at the right angle but I'd want a single t-bar at the minimum.
[QUOTE=Alfred W.;10665950]When a man has the scent of pussy in his nose...... The best advice in the world bounces off the block formerly know as his head. :grinpimp:[/QUOTE] |
#13 (permalink) | |
This guy must be from Tennessee. Sorry TN guys
Rob Ellis |
#14 (permalink) | |
Also, looking at his flex pictures, it looks like the front out flexes the rear even though the front has regular spring pads. Doesn't look like its too effective.
#15 (permalink) |
Member # 8211
What is that welded to the axle tube just to the left of the diff? Looks like some sort of traction bar (or attempt at a locating link?) running up to the frame rail. That thing going to the top of the pad is bizare. Doesn't look like it would hold much without collapsing. Also, did you notice that the pivot bolt is welded in? I guess it's "non-serviceable".
Russ 85 K30 truggy, 350 TBI, TH350, 203/205, D60/C14, 4.56 Locked, 42" TSLs, 4" lift, 112" wheel base, front leafs, rear double triangulated 4 link with coils. |
#16 (permalink) |
Member # 8211
Check this out...
Looks like this guy has a "thing" for unbraced strap and plate. Look at that spring mount. Looks like it's buckling!Edit: For some reason this is IMG tag pic not working for me. Here is the link if it doesn't work for you. http://community.webshots.com/storag...UCocnoJ_ph.jpg
Russ 85 K30 truggy, 350 TBI, TH350, 203/205, D60/C14, 4.56 Locked, 42" TSLs, 4" lift, 112" wheel base, front leafs, rear double triangulated 4 link with coils. Last edited by BadDog; 05-22-2002 at 09:43 AM. |
#17 (permalink) | |
Member # 6726
[COLOR="Black"]Did you expect to find something deep and meaningful here?[/COLOR] "He has all the virtues I dislike and none of the vices I admire." -- Winston Churchill |
#18 (permalink) |
I've got the bc bronco pivots. It really freed up some more flex in mine. I don't drive it everyday but I do drive it on the highway and I don't notice any difference in driving characteristics. I relocated my shocks at the same time to an inboard set-up and run the shocks stiffer to compensate for the angle they are now at. Still it feels fine on the highway. (As well as one can with sx's anyway.)
I don't know about the lateral support either with how tall the sping mounts are on the axle. If they were shorter I think I would feel better about it. I'm assuming he did it to run a flatter leaf?
Jake Good Special Thanks to: COOPER TIRES, Trail Tough, Inland Truck Parts, Kansas Rocks, The Awesome RBR Crew! Last edited by inphobic; 05-22-2002 at 10:18 AM. |
#19 (permalink) |
Member # 800
I have thought of this kind of setup to unbind the springs, I didn't because it would require some linkage to controll it side to side as part of the spring binding laterally is what locates the axle side to side.
also looks too tall and lightweight for my tastes, i tend to overbuild things a lot, easier than fixing them on the trail.
my dodge sucked, I went superduty |
#20 (permalink) |
www.patparts.com
Member # 4821
So basically, after more thought, what I am hearing and agree with is that it is a good idea with shitty fab work. Sounds like someone who knows what they are doing should try it.
J. J.
