Reverse rotation Power steering pump??? - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 05-13-2007, 03:06 PM   #1 (permalink)
Member # 23843
Since I am currently building a buggy that uses a honda civic engine that turns the opposite direction to most everything else in the world,I was wondering if there is any applications that the PS pump turns counter clockwise(as looking at the front of the engine).I know I can just make a mount for a regular pump the makes the pulley face the engine(so it turns the correct direction for the pump to operate).But, I wanted an easier way if its possible!!!I thought about using the stock honda pump but I doubt it will make enough pressure and volume for 4 wheel steering!!!!
Thanks for any help!!!!
THANKS TO MY SPONSORS....TFAB,TRAIL-GEAR,YUKON,TORCHMATE AND RUFFSTUFF!!!
Rock Ape is offline   Reply With Quote Quick reply to this message
Old 05-13-2007, 03:12 PM   #2 (permalink)
Member # 14094
Send a message via AIM to Hvy_Chevy
can't you just make a mount to put the pump where a serpentine belt turns it the right way?
Size does matter.
Leave the Zukes to those who really understand.
Hvy_Chevy is offline   Reply With Quote Quick reply to this message
Old 05-13-2007, 03:22 PM   #3 (permalink)
Member # 23843
It doesnt have a serp belt,and if it did I would have to find a ps pump pulley the the belt can turn on its backside(to get it to spin the pump the right way!!!)I know I can face the ps pump towards the engine and get the correct rotation but I was hoping for a magic application for a reverse pump!!!
Old 05-13-2007, 03:41 PM   #4 (permalink)
Member # 23843
Did a little searching and came up with this.....
http://www.pscmotorsports.com/produc...e655b9b411c432
Ill call them tomorrow!!!!!
Old 05-13-2007, 05:02 PM   #5 (permalink)
Pissing Excellence
Sillyneck's Avatar
Member # 517
Send a message via ICQ to Sillyneck
if you have the space mount the pump ass out. if you're fabbing a bracket it'll be the same amount of work.
4457 Team DMR
Poly Performance
Ruffstuff
Barnes Welding Supply Sacramento
RADFLO
Shock tuning..... I only work with underdogs.
Sillyneck is offline   Reply With Quote Quick reply to this message
Old 05-13-2007, 05:05 PM   #6 (permalink)
pro web-wheeler
RedBullJeep's Avatar
Member # 12217
Exactly what I was thinking...mount the pump backwards if you have the room in front of the engine.
RedBullJeep is offline   Reply With Quote Quick reply to this message
Old 05-13-2007, 05:10 PM   #7 (permalink)
lwg
lwg's Avatar
Member # 12044
Send a message via MSN to lwg
A lot of the Saginaw "Type N" pumps are reverse rotation. I think they were from an early 90's Caprice, LT1 maybe???? They are out there in stock form.
Of course PSC makes an uprated one as well.
Larry
lwg is offline   Reply With Quote Quick reply to this message
Old 05-13-2007, 05:36 PM   #8 (permalink)
GOAT1's Avatar
Member # 5969
The mid-late 80's Corvette TPI motors used a reverse rotation pump also.
GOAT1 is offline   Reply With Quote Quick reply to this message
Old 05-13-2007, 06:19 PM   #9 (permalink)
Member # 2857
Gear-driven hydraulic pumps come in RR, check out surpluscenter.com
later-
BTG Rockcrawlers - Phoenix, AZ
Rockwelled FJ40 buggy - slow , 2010 Nissan GTR - fast
elf_cruiser is offline   Reply With Quote Quick reply to this message
Old 05-13-2007, 09:55 PM   #10 (permalink)
Fl-Krawler's Avatar
Member # 47337
my buggy has an LT-1 with a reverse rotation "N" style pump
Fl-Krawler is offline   Reply With Quote Quick reply to this message
