Welding a 14 bolt 2 different ways? - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 05-28-2007, 10:08 AM   #1 (permalink)
FYRDUDE's Avatar
Member # 16686
Going to be welding up my 14B and have run into two different ways to do it. The first is to weld the all the spider and side gears together. The second is to fill weld the valleys of the spiders and then reassemble.
Which have you used and which do you think is stronger?
Here are the pics.
GETTING FLAMED FOR A LIVING AND LOVING EVERY MINUTE!!!
[COLOR=Red]FDNY 343[/COLOR]
F-toy #23 buildup
Project Double Wide : F-Toy #23
FYRDUDE is offline   Reply With Quote Quick reply to this message
Old 05-28-2007, 10:10 AM   #2 (permalink)
FYRDUDE's Avatar
Member # 16686
Here it is with the valleys welded.
F-toy #23 buildup
Old 05-28-2007, 10:10 AM   #3 (permalink)
FYRDUDE's Avatar
Member # 16686
Here it is welded all together.
F-toy #23 buildup
Old 05-28-2007, 10:12 AM   #4 (permalink)
FYRDUDE's Avatar
Member # 16686
Also, how straight would it stay if you took the spiders out along with the side gears and welded them outside the carrier. I know doing this on a toy
3rd can be disasterous. How did you guys do it?
F-toy #23 buildup
Old 05-28-2007, 10:20 AM   #5 (permalink)
Member # 5110
Make a "gear ball" (opt 2).
Link to thread on my calculator http://www.pirate4x4.com/forum/showthread.php?t=204893
Triaged is offline   Reply With Quote Quick reply to this message
Old 05-28-2007, 10:48 AM   #6 (permalink)
Member # 595
If you don't weld it all together there is a chance for movement, wear, slop and more chance of failure IMO.
x 2 "Gear ball"
1967 Bronco for sale $13,000 in classifieds
Injected 5L, Dana 60, ARB, Swampers, Hydroboost
EBSTEVE is offline   Reply With Quote Quick reply to this message
Old 05-28-2007, 10:51 AM   #7 (permalink)
Master Apprentice
Member # 56692
Can any one find that pic from the welded rockwell?
1992 Explorer SAS'ed on HPD44/9" W/ 5.13 Locked F/R 36" TSL-SX on DIY Locks
sn0border88 is offline   Reply With Quote Quick reply to this message
Old 05-28-2007, 11:04 AM   #8 (permalink)
Member # 3483
Do not fill the valleys.. Eventually it will fail. It was a good idea, but the weld metal can't handle the job and eventually will allow slop, movement, and eventually some funny acting differential action. Weld it all together and create the "orb of traction". Tack it while in one half of the carrier then just pull it out and get to work.
Benny
350/350/205/60/60/linked/locked/lowered
Bigger Valves is offline   Reply With Quote Quick reply to this message
Old 05-28-2007, 11:20 AM   #9 (permalink)
blackcloud's Avatar
Member # 68088
Send a message via AIM to blackcloud
Ive been loking for it for 2 hours now im pissed cus I still cant find it
blackcloud is offline   Reply With Quote Quick reply to this message
Old 05-28-2007, 11:26 AM   #10 (permalink)
blackcloud's Avatar
Member # 68088
found ithttp://www.pirate4x4.com/forum/attac...1&d=1180376807
Old 05-28-2007, 11:35 AM   #11 (permalink)
Member # 25601
Originally Posted by blackcloud View Post
YES!!!
do it like this.
this is how i did my 14 bolt when i welded it up.
i tacked everything in one half of the carrier, then flipped it to the other side tacked it good, and welded the shit out of it.
i didnt just weld where the gears touch one another, but i filled in all of the voids in between them... "Orb Of Traction" style
CrustyJeep- "Your faith in your government to protect your wife from you is LIBERAL THINKING."
88burban is offline   Reply With Quote Quick reply to this message
Old 05-28-2007, 11:42 AM   #12 (permalink)
Member # 12991
Send a message via AIM to 74_Chevota
Originally Posted by 88burban View Post
YES!!!
do it like this.
X2
Works great.
11' Go-fast buggy:LS3-TH350-Atlas 3.0-bypasses-n-shit
74_Chevota is offline   Reply With Quote Quick reply to this message
Old 05-28-2007, 11:43 AM   #13 (permalink)
Jaycar's Avatar
Member # 67315
Here is rockwell spiders welded up.
[U][/U][FONT="Century Gothic"][SIZE="4"][COLOR="Red"][COLOR="Red"][SIZE="5"]www.creepycrawlers4x4.com[/SIZE][/COLOR][/COLOR][COLOR="Red"][/COLOR][/SIZE][/FONT]
Jaycar is offline   Reply With Quote Quick reply to this message
Old 05-28-2007, 01:02 PM   #14 (permalink)
Member # 1792
This is the way I did mine also.I haven't finished the axle yet.But I have no worries about it holding up.It is the same as a mini spool this way with no moving parts to wear and give out.
CJJuggy.FI406/465/205/D60/14bolt FF on 39.5 Swampers.Kid's '70 Jeepster D44/14bolt FF.
Cheepin is offline   Reply With Quote Quick reply to this message
Old 05-28-2007, 01:09 PM   #15 (permalink)
FYRDUDE's Avatar
Member # 16686
When you were finish welding it, it didn't warp and prevent it from properly seating back in the carrier. I've welded other diffs and had problems getting the shaft back in because of warpage of the side gears in relation with the spiders. I guess I will just go slow and do opposing sides.
F-toy #23 buildup
Old 05-28-2007, 01:34 PM   #16 (permalink)
Member # 56456
Weld then cover it up with some leather or something to keep it from cooling fast. I welded mine up like that rockwell spool (except alot less weld) then I assembled the carrier then welded all 8 holes up in the carrier. Slow cooling too, its heat treated.
74 f100, 4bt, 3link hp 60/14 bolt, welded f/r np435/205
Fordman500 is offline   Reply With Quote Quick reply to this message
Old 05-28-2007, 01:42 PM   #17 (permalink)
FYRDUDE's Avatar
Member # 16686
So after you welded the spider and side gears, making the ball. You then put the "ball" between the two sides and welded them together. Why?
Wouldn't the little spool be enough or am I missing something?
Just curious.
F-toy #23 buildup
Old 05-28-2007, 02:01 PM   #18 (permalink)
Member # 25601
Just curious.
i didnt do that, i saw/see no point in it.
Old 05-28-2007, 04:48 PM   #19 (permalink)
Member # 43587
Send a message via AIM to TBItoy
the "orb of traction" style is how my Toy v6 diffs are welded. I assembled the spider ball in 1/2 of the diff and tacked it all up real good. No warpage, no shaft problems.
The Gremlin - small ugly linked beater Toyota
TBItoy is offline   Reply With Quote Quick reply to this message
Old 05-28-2007, 04:57 PM   #20 (permalink)
FYRDUDE's Avatar
Member # 16686
Thanks for the assistance. Will post up pics. of the process on my buildup. All hail the "orb of traction". It just sounds funny.
F-toy #23 buildup
Old 05-28-2007, 05:17 PM   #21 (permalink)
Member # 3483
I claim coining the term back in 2003 when I made my first one (see attached) and had it on my webpage..
Benny
Old 05-28-2007, 06:14 PM   #22 (permalink)
Member # 22513
dont just fill the valleys just blew that up this weekend. id sugest pony up the money for a mini spool.
CJ-8,heavily modified?
HOOLIGAN ROCK CREW.
CRICKET is offline   Reply With Quote Quick reply to this message
Old 05-28-2007, 07:13 PM   #23 (permalink)
FYRDUDE's Avatar
Member # 16686
I think that "ORB" is going to be plenty strong. It looks like you added 10lbs. of material to that thing.
F-toy #23 buildup
Old 05-28-2007, 07:18 PM   #24 (permalink)
Member # 12991
Or just weld it up and make your own "mini spool"
Old 05-28-2007, 07:31 PM   #25 (permalink)
Member # 81750
should i weld my Dana44 into a ball or just fill the valleys?
sorry for the Hijack
gobigorgohome is offline   Reply With Quote Quick reply to this message
