do I really need springs?? - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 05-30-2007, 09:43 AM   #1 (permalink)
Member # 75479
Red face my 76 f150 build.. flex shots page 6
ok, here's the deal.. I have a 76 f150 4x4 the I cut the bed off of & shortened almost 2 feet. I'm in the process of 3-linking the rear & puting stock xj coils on instead of leafs (too stiff w/ no weight in the back). then I remembered I had some pro comp MX6 shocks laying around that are pressurized to 300psi.
here is the question!! do you think the shocks alone will hold up the weight of the rear of the vehicle without having to use springs??
thanx
jason
Last edited by racebronco; 08-03-2007 at 10:24 PM. Reason: no longer need questions about springs. changed title.
racebronco is offline   Reply With Quote
Old 05-30-2007, 09:50 AM   #2 (permalink)
Member # 9845
I think you should give it a shot and report back to us
Mark Janzen
7FootYeti is offline   Reply With Quote
Old 05-30-2007, 09:50 AM   #3 (permalink)
sceep's Avatar
Member # 10798
Send a message via AIM to sceep Send a message via MSN to sceep
yer good man.. run em.
are you f-n retarded?
Originally Posted by USDA forest service website
It is every American's birthright to use the national forests and grasslands in multiple ways, including outdoor recreation in all its forms.
sceep is offline   Reply With Quote
Old 05-30-2007, 10:00 AM   #4 (permalink)
Member # 44108
300psi...mx-6...DOOOO it!
[center][SIZE="4"][url]Shop.FarmboyFabrications.com[/url][/SIZE]
[B][SIZE="6"]
[COLOR="DarkRed"]239.337.LIFT[/COLOR][/SIZE][/B]
[SIZE="4"]
[COLOR="Silver"]One Up Offroad[/COLOR][COLOR="DarkRed"] Rize Industries [/COLOR][COLOR="Silver"]Icon Vehicle Dynamics [/COLOR][COLOR="Yellow"]RCD[/COLOR] [COLOR="Silver"]Full-Traction[/COLOR] [COLOR="darkred"]Rubicon Express [/COLOR][COLOR="Navy"]KING[/COLOR][COLOR="DarkRed"] Sway-a-Way[/COLOR][COLOR="Navy"] FOX[/COLOR] [COLOR="Silver"]Dynatrac[/COLOR] [COLOR="Indigo"]Yukon Gear[/COLOR] [COLOR="DarkRed"]ARB [/COLOR][COLOR="Silver"]Detroit[/COLOR] [/SIZE]
Including the largest selection of tires and wheels that you will find. Don't see what you are looking for? Give us a call.[/center]
bigreen is offline   Reply With Quote
Old 05-30-2007, 12:10 PM   #5 (permalink)
rokcrwlrtj's Avatar
Member # 27180
Send a message via AIM to rokcrwlrtj
I have a friend running that set up now with success
Now if you believe that your a fucking idiot
Save Tellico Post 296
rokcrwlrtj is offline   Reply With Quote
Old 05-30-2007, 12:29 PM   #6 (permalink)
Member # 75479
awsome.. thanx guys for the input..
Old 05-30-2007, 12:50 PM   #7 (permalink)
Member # 44108
edited for Sceep
[B][SIZE="6"]
[SIZE="4"]
Old 05-30-2007, 12:51 PM   #8 (permalink)
sceep's Avatar
Member # 10798
not to hijack, but along the same lines...
I have an old fire extinguisher laying around that we modified to use as a squirt gun.
can i fill it up with like 500PSI and use it for a powertank?
Old 05-30-2007, 01:15 PM   #9 (permalink)
Eskimo's Avatar
Member # 10429
NO! You're insane!
co2 has a vapor pressure of 800psi
Rich Q.
FJ-40 Cruggy - tuned 5.3/4WS rockwells/linked/ORI's/42's
Eskimo is offline   Reply With Quote
Old 05-30-2007, 02:18 PM   #10 (permalink)
Myanarchy's Avatar
Member # 14059
Not a problem man.
You might actually have too much pressure in those shocks though. To test, lay under the truck and have a buddy jump up and down on the back, it'll probably be too stiff.
This could be great
Jeeper89 is a bitch
Myanarchy is offline   Reply With Quote
Old 05-30-2007, 03:17 PM   #11 (permalink)
comeonstart's Avatar
Member # 49939
Send a message via AIM to comeonstart
Worked well for me, I am surprised more people dont do it.
________
Web shows
comeonstart is offline   Reply With Quote
Old 05-30-2007, 03:39 PM   #12 (permalink)
IDIot!
MT4Runner's Avatar
Member # 44480
I know a guy on Jeeps Unlimited who did it; worked pretty well for him.
Let me see if I can find the link.
Surely you won't click the link this time, Myanarchy! :blackflipoff2:
MT4Runner is offline   Reply With Quote
Old 05-30-2007, 04:23 PM   #13 (permalink)
Redmist's Avatar
Member # 43646
Also, if you run them upside down, the nitrogen will be closer to the end of the stroke. This means that as the shaft passes through the oil it will pick it up on the valving disc and try to push it through the nitogen. Because the fluid does not compress it will try to pass through the oil with a mixing result.
The mixing is what your after. this makes tons of bubbles in the shock and creates an "air ride" quality just like those sleep number beds....
Your shocks do have adjustable numbers on it correct? I am a number 4, but my other wheeling buds are number 2's Pick the number that is write for you and the airation formula will result in a user specific ride.
So run the shocks CAN DOWN!!!!! Alot of ride number owners do not do this and it destroys the whole point of running a SHOCK! as a SPRING!
Redmist is offline   Reply With Quote
Old 05-30-2007, 04:24 PM   #14 (permalink)
Oilfield Trash
Red Chevy's Avatar
Member # 64526
So, this is playing nice on pirate now.
'91 k3500, 454, 4speed, 42" R-1's no lift
'97 z-71, 3" BL, 38" tsl radial, 454/th400
'97 tj, 2.5/auto, rubi 44/5.13/spartan, 8.8/5.13/spool,
34/10.50/16 ltb
Red Chevy is offline   Reply With Quote
Old 05-30-2007, 04:36 PM   #15 (permalink)
Member # 10736
i am thinking about doing this shock idea as well. it should be a best of both worlds solution.
masonmachines is offline   Reply With Quote
Old 05-30-2007, 04:42 PM   #16 (permalink)
Valley Auto's Avatar
Member # 78079
Master of the wire Wheel!Apprentice human clamp
Coastal Fabrication the " best damn shop in town"
Poly Performance
Pacific Fabrication
http://www.pacificfab.net/
Right Gear &Axle
Valley Auto is offline   Reply With Quote
Old 05-30-2007, 04:43 PM   #17 (permalink)
IDIot!
MT4Runner's Avatar
Member # 44480
Fawk you!!!
Here's that link on JU about running shocks as springs:
http://www.jeepsunlimited.com/forums/showthread.php?t=796872
Old 05-30-2007, 04:45 PM   #18 (permalink)
Myanarchy's Avatar
Member # 14059
Originally Posted by MT4Runner View Post
Fawk you!!!
Damn thats some bling there!
Yes I can read black text, and yes I still hate you for clicking it last time lol
Jeeper89 is a bitch
Old 05-30-2007, 04:50 PM   #19 (permalink)
Member # 85265
Fawk you!!!
that took me to a GAY FORUM in a foriegn language thanks alot
the beatings will continue until morale improves.
wtr40rock is offline   Reply With Quote
Old 05-30-2007, 04:53 PM   #20 (permalink)
Myanarchy's Avatar
Member # 14059
Um, newsflash dude,
by clicking on JU you should have already known that it was going to be a gay forum in a foriegn language. Its JU, what were you expecting, tech?
Jeeper89 is a bitch
Old 05-30-2007, 05:06 PM   #21 (permalink)
JeffHPK5's Avatar
Member # 45481
If you would have SEARCHED you would know that this is a very economical way to fabricate a flexy rear suspension all while keeping an incredibly low center of gravity!
Search is free for everyone
Support Yellow Star Members
/forum/general-4x4-discussion/688801-yellow-star-vendors-list.html
Aerospace Tool&Die by trade..Don't call me a machinist!
Currently enduring the mother of all affirmative action hires!
TEAM CARWASH 2010 TTC CHAMPS
JeffHPK5 is offline   Reply With Quote
Old 05-30-2007, 05:07 PM   #22 (permalink)
IDIot!
MT4Runner's Avatar
Member # 44480
My humblest apologies.
I can't believe that people actually click links in flame-the-newbie threads
Something must be wrong with TinyURL.
Worse yet, you thought you'd find tech on JeepsUnlimited
Let's see if I can fix it,
...and to trust a JU link when you're in a Toyota Forum
there must be a good explanation
Is racebronco your boyfriend? :blacklaughing:
Old 05-30-2007, 05:08 PM   #23 (permalink)
Oilfield Trash
Red Chevy's Avatar
Member # 64526
I am so quick to click on a link, I realized that I had seen this like the other day after I had clicked on it.
34/10.50/16 ltb
Old 05-30-2007, 05:48 PM   #24 (permalink)
Member # 50366
Glad I'm not the only idiot on here.
I did the exact same thing.
Red_SC is offline   Reply With Quote
Old 05-30-2007, 06:01 PM   #25 (permalink)
misterfubar's Avatar
Member # 65026
Originally Posted by Myanarchy View Post
Um, newsflash dude,
That's quotable right there.
*BACK ON TOPIC*
I'm running the exact same setup on my 77 and it works great. Not sure if it will work on your 76 though.
“Is it ignorance or apathy? Hey, I don't know and I don't care.”
misterfubar is offline   Reply With Quote
Copyright ©2000 - 2014, Jelsoft Enterprises Ltd.
