Member # 48084
White residue all over spark plugs....why?
In my experience, whenever you have white on a spark plug, its burning lean. So what's up with this? What would cause it? Should I be worried? 1995 Geo Prizm (Toyota Corolla) bone stock 1.8L I4. Still running great with no known problems at 230,000. Plugs have probably been in there for 1.5 years / 40,000 miles.
2011 TTF buggy |
I'm back and watchin
Member # 43607
Maybe it was running rich or burning oil, and then quit??
KOH racer #554 Huge thanks to our partners: Trick Toys Fabrication, NITTO Tires, Longfield Super Joints, PSC steering components, Brian Smith Development.............tricktoysracing@yahoo.com |
Damn you chuckie...
it means you need to stop driving like a old lady.
1996 F150 - Supercharged 5.8L, E4OD, Vortech S-trim, PSD Intercooler, 15 psi , 1356, Dana 60, 10.25, 5.13 gears, welded rear diff, 14" Air/Coilovers. Check it out:Build thread: ![]() ![]() Here The un-named buggy - 2.3L, lotsa tube, and FJ80s.
Member # 48084
You have no idea. I beat the piss out of this car every single day and it just keeping going, and going, and getting 38 MPG doing it.
2011 TTF buggy |
Member # 36795
oil Deposits( burnt ash)
The accumulation of deposits on the firing end is influenced by oil leakage, fuel quality and the engine's operating duration. ![]()
Derek: '69 bronco crawler/ 5.0 HO EFI/ 1 tons & 42''s Last edited by bronco69drp; 08-15-2007 at 09:22 PM. |
#11 (permalink) | |
Ford Bigot
Member # 31227
It looks like what's said above: it's burning a little oil, and modern 4 cylinders run leaner than shit on the freeway to get the mileage. You could maybe step up to a hotter plug if it's fouling, otherwise wire brush those and put them back in if you're a cheap bastard, or buy a new set at the parts store.
Project Flat F***er (Fender) Project SR5.0 |
#12 (permalink) |
Damn you chuckie...
id say oil. ive seen the additives, they look more redish when it burns...ive got a B2200, it did the same thing... burning oil.
#13 (permalink) |
Member # 36795
Overheated:
On this symptom you will notice a chalky appearance, white insulator, rapid electrode wear as well as an absence of deposits. The actual shell may also be discolored. To cure this you must first verify that the plug is the correct heat range, the ignition timing settings are correct, the air/fuel mixture is not too lean, there are no vacuum leaks and that the EGR valve (if equipped) is functioning properly. ![]() Ash Deposits These are light-brownish deposits that are encrusted to the ground and/or center electrode(s). This situation is caused by oil and/or fuel additives. This condition can cause misfires. The cure for this is to verify worn valve guides or valve seals, not using fuel additives, or you might even try changing fuel brands. By the way, a hotter plug is what most people try to fix this problem. You need to first understand that the plug is NOT typically the problem.
Derek: '69 bronco crawler/ 5.0 HO EFI/ 1 tons & 42''s |
