Replacement Winch Solenoid - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 09-17-2007, 09:00 AM   #1 (permalink)
Trailduster79's Avatar
Member # 17024
Send a message via AIM to Trailduster79
Need to replace one of the solenoids on my E-12000 MM winch. Is there a generic replacement I can pick up from Napa? Such as the Ford relay commonly used on Taurus fans?
The MM guy said he might not be able to get me one since it is an older winch.
Any help would be great.
79 Trailduster 360/727/NP203/NP205/60 38.5 SX
06 CTD Muffler Delete, Billit Trans, Juice w/Attitude
Trailduster79 is offline   Reply With Quote Quick reply to this message
Old 09-17-2007, 09:58 AM   #2 (permalink)
SeaBass44's Avatar
Member # 40
starter solenoids are intermintent duty...............DO NOT USE THEM!
# 530.532.4529
TTC 2010 1989 BRONCO
-Awesome web development for your business.
SeaBass44 is offline   Reply With Quote Quick reply to this message
Old 09-17-2007, 10:05 AM   #3 (permalink)
yozsi's Avatar
Member # 91857
Send a message via AIM to yozsi
yep, a battery isolator, the kind people install on their car when they tow a camper equipped with batteries.
92 Nissan Pathfinder- 3 Link SAS, 4 link rear
02 Dodge 2500 QC LB 4x4, CTD daily.
Foreign Car Center
Vallejo, CA
yozsi is offline   Reply With Quote Quick reply to this message
Old 09-17-2007, 01:08 PM   #4 (permalink)
Member # 39297
great product support there..... i can get solenoids for a 40 year old warn, but not a milemarker that can't be more than 10 years old... truly sad...
Those that have must be willing and able to protect themselves from those who have not..
gilraine is offline   Reply With Quote Quick reply to this message
Old 09-17-2007, 01:10 PM   #5 (permalink)
Member # 17024
that's what I thought.
Looks like superwinch and t-max uses the same solenoids, so I might just pick up a coupld of them from summit.
Old 09-17-2007, 06:23 PM   #6 (permalink)
Moderhater
Halogrinder's Avatar
Member # 16980
im in the same situation. not to thread highjack, but i need a heavy duty soliniod for the taurus fan im gonna use? what aperage does it take to turn them? right now i just have a fan thru a 15 amp switch.
gun facts that will blow your mind:
Halogrinder is offline   Reply With Quote Quick reply to this message
Old 09-18-2007, 04:25 AM   #7 (permalink)
Member # 31352
I came across an add from airbagit.com...they have some 100% duty cycle solenoids for 16 bucks...may be worth checking out
TheRamChargerMan is offline   Reply With Quote Quick reply to this message
Old 09-18-2007, 06:56 AM   #8 (permalink)
Member # 55403
This is what I have used you will never have a problem again .
http://bluesea.com/category/1/productline/8
Half the fire wall/part of the hood & front grill its all CJ
ditchpig is offline   Reply With Quote Quick reply to this message
Old 09-18-2007, 10:34 AM   #9 (permalink)
Member # 13342
For $138 I saw at one dealer, it should.
Albin is offline   Reply With Quote Quick reply to this message
Old 09-18-2007, 11:06 AM   #10 (permalink)
SeaBass44's Avatar
Member # 40
you only need 2 of those
# 530.532.4529
Old 09-18-2007, 05:49 PM   #11 (permalink)
mj
Member # 1919
wow, 1.4 lbs each
how do you wire it for only 2 solenoids?
mj is offline   Reply With Quote Quick reply to this message
Old 09-18-2007, 05:58 PM   #12 (permalink)
SeaBass44's Avatar
Member # 40
Originally Posted by mj View Post
wow, 1.4 lbs each
JUST LOOK AT THE WARN WIRING, THE USE 2 FOR IN, 2 FOR OUT
the MM uses only 2, I would have to look at the wiring to see, shouldn't be too hard, look up a MM wiring setup
# 530.532.4529
Old 09-18-2007, 06:20 PM   #13 (permalink)
mj
Member # 1919
never seen a MM
every winch I have seen uses 4 solenoids
assume the ground is through the case and you just energise a different pole for direction??
Old 09-19-2007, 09:36 AM   #14 (permalink)
RustoleumWhite's Avatar
Member # 4506
I would like to see this too.
I made my own 4-solenoid winch box for my trailer winch with (4) Ford-type solenoids. Haven't had an issue yet but its a little winch.
It would be nice to be able to make one with only 2-solenoids. Then I could use better units and have a smaller set-up.
Google failed me.... so far. So if you find something and are willing to share...
I wheel a mean jackstand
RustoleumWhite is offline   Reply With Quote Quick reply to this message
Old 09-19-2007, 12:44 PM   #15 (permalink)
SeaBass44's Avatar
Member # 40
here is all you need
several ways depending on your motor type
http://www.dbelectrical.com/winch/winch.shtml
& 4 solenoid
# 530.532.4529
Old 09-19-2007, 02:53 PM   #16 (permalink)
Member # 55403
I use two of these contactors (Tyco makes them there now ~$60) for winch IN as thats where the high current draw is and winch OUT is only about 50A so the regular solenoids are fine . Series wound motors require the reversing of the windings with the armature . This is one setup done for a friend .
He did not want a switch on the dash so it was installed here and the LED on tells you the breakers are on , I would use three 200A breakers but he uses his so that when the breakers trip he double lines .
