4.3L Vortec Oil Pan Problems... - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 10-30-2007, 10:08 PM   #1 (permalink)
Member # 85316
Send a message via AIM to svt150j49
soo... I bought a 94 S10 Blazer with the 4.3L Vortec CPI motor. Im doing a motor swap into another truck...
anyway, the problem comes up at the oil pan. I have a factory pan on it, and i need to loose about 1.5" - 2" off the depth of the pan. I figured you guys would be able to point me somewhere and help me out. I know they sell pans for the older 2 peice rear mains, but i cant find one for the 1 peice. any ideas? cut my pan? can i run the 2 peice pan?
i figured somebody has ran into this in a buggy or something. im stuck until i figure something out...
1996 F150 - Supercharged 5.8L, E4OD, Vortech S-trim, PSD Intercooler, 15 psi :eek:, 1356, Dana 60, 10.25, 5.13 gears, welded rear diff, 14" Air/Coilovers. Check it out:
Build thread::evil::grinpimp:
The un-named buggy - 2.3L, lotsa tube, and FJ80s. :grinpimp:
svt150j49 is offline   Reply With Quote Quick reply to this message
Old 10-30-2007, 10:16 PM   #2 (permalink)
Member # 54844
a hammer fucker
i still say we cut and weld the pan / pickup with a drag style pop outs on both sides
[SIZE="4"][COLOR="Red"]BSW[/COLOR] Racing, Super mod & [/SIZE] [SIZE="4"][COLOR="Navy"] Bitten [/COLOR]Off Road, Pro mod[/SIZE]
BSW Driver: Aaron Whitehead - Bitten Driver: Mike Stokes
BSW Spotter: Adam Kovarik - Bitten Spotter: Dan Kovarik - AKA -
: me fuckers :flipoff2:
build up of the truggy
f250rollinon37s is offline   Reply With Quote Quick reply to this message
Old 10-30-2007, 10:20 PM   #3 (permalink)
Member # 85316
the hammer thing only works on toyota fuel tanks.
Old 10-31-2007, 01:10 AM   #4 (permalink)
Member # 70555
Get one from an Astro van, they are alot shorter. 87 and up should all have the one piece seal. Just don't get an AL one.
clicky--->
http://www.mandmfab.com/
rock mafia is offline   Reply With Quote Quick reply to this message
Old 10-31-2007, 08:03 PM   #5 (permalink)
rock-it man's Avatar
Member # 27834
I have that same motor and I have read that you can cut 2" out of the sump with no problems, good luck,Billy
2 seater Bruiser 4.3 vortec th400 4.3atlas 14 bolt shaved rear dana 60 hp front shaved 5.13 detroits ctm alloy shafts 44 tsl . looking for a 6.0 vortec
rock-it man is offline   Reply With Quote Quick reply to this message
Old 11-01-2007, 09:35 AM   #6 (permalink)
Top Shelf
Tfab's Avatar
Member # 41032
I ran into this problem and here is what I did. I started with a chevy 350 race pan that had trap doors and the oil pick up that came with it. The oil pick up bolts on. Then I cut the two pan and made one.
TRENT FABRICATION
775-358-5337
Tfab is offline   Reply With Quote Quick reply to this message
Old 11-01-2007, 09:36 AM   #7 (permalink)
Top Shelf
Tfab's Avatar
Member # 41032
ready to weld
TRENT FABRICATION
775-358-5337
Old 11-01-2007, 12:57 PM   #8 (permalink)
Member # 31763
Tfab, that looks like it turned out pretty good. I have a 2000 4.3 and have the same problem. I'm just planning on grabbing an Astro van pan like rock mafia suggested since I don't have another pan that I could modify like Tfab.
Rock Mafia, why do you say not to get an AL pan?
craigellis77 is offline   Reply With Quote Quick reply to this message
Old 11-01-2007, 01:53 PM   #9 (permalink)
under_psi's Avatar
Member # 39348
Send a message via AIM to under_psi
i went from a 4x4 oil pan to a 2wd oil pan on my 2000 model vortec 4.3.......
here is a pic of the difference...netted me about 2" clearance....
oops...dont have the old pic, but the pan used to hang below that link that is hiding the bottom of the pan....
[FONT="Times New Roman"][COLOR="Lime"][B]
[/B][/COLOR][/FONT]
under_psi is offline   Reply With Quote Quick reply to this message
Old 11-01-2007, 02:18 PM   #10 (permalink)
Member # 31763
Yep, forgot about the 2wd option. Chip clued me into that a while back. Is that half a d-shaft that I see? The pic is deceiving .
Old 11-01-2007, 02:57 PM   #11 (permalink)
Banned
Member # 46888
I have the same motor and went with a 2wd and pick up tube works great.it was like 60 bucks brand new .
Good luck.
jmdzuk is offline   Reply With Quote Quick reply to this message
Old 11-01-2007, 06:19 PM   #12 (permalink)
under_psi's Avatar
Member # 39348
yeah it is half of a DS....was using it to make sure the exhaust would clear...
$60 is good...i paid $149 for the oil pan and $7 for the 2wd pick-up....
[/B][/COLOR][/FONT]
Old 11-01-2007, 10:51 PM   #13 (permalink)
Member # 85316
thanks for the info guys. i hacked a little over 2" off the bottom of the pan tonight. i figured id make id work either way. anyway, i like the idea of the 2 pans into 1. i may try that.
Old 11-02-2007, 01:21 PM   #14 (permalink)
Top Shelf
Tfab's Avatar
Member # 41032
Make sure you get an pan with trap doors, they will buy you some time when you are at angles or driving on your side.
TRENT FABRICATION
775-358-5337
