www.patparts.com
Member # 4821
12-volt power unit for hydraulic steering?
My PSC pump has been on its last leg since the day I bought it and this weekend I overstrained it and I think it blew a seal or something because its still working but its whinning like a stuck pig even at idle. (Worse than it whined ever since I bought it, mind you.) My intent is to buy a POS pump at some point but apparently there are supply line issues at Delco and they can not commit to a delivery time and, unfortunately, I don't think this PSC pump will last another trip. That gets me to thinking about other options.
I'm not sure that the link I am about to post is even the right product. To be honest, I don't even know what the link is exactly. But I know I've seen about 5 rigs out on the trails that are using something that looks like this for their rear steer and they are able to get full power steering with it even with the engine not running. http://www2.northerntool.com/product/200329768.htm Obviously, I'm not concerned about street manners. But it looks to me like this unit has its own tank, a retun port, and a pressure port, which is about all a PS pump needs. In terms of voluume I don't even know what that unit is rated at. Again, I'm just using it as an example. So is anyone using these for front and rear steering applications? Why do I only see people using them for rear steer? Is there any advantages or disadvantages to them? What would be considered a superior voluume rating? At this point, I'm just trying to explore options and think maybe a little outside the box. That, and I think it'd be pretty cool to be able to steer without the engine running. J. J.
Member # 24314
Just my experience/ take with a grain of salt.
I have it for the rear. Positives 1. I don't need to run hoses from the front to the rear. 2. I have broke and used the rear to stear back to camp. 3. Easy instalation and cheep overall. 4. I have a electric small switch on my dash to run it. cons 1. weighs more. 2. My system drifts as i drive across the lake bed. 3. finding a place to mount it. Large. 4. Mine is freeking fast. not recomended to use at speeds. If i could find a way to keep it from drifting i'd recomend it for shure but i get tired of having to center the rear sometimes. I don't belive it is realistic at all for front. Last edited by tjmark; 11-12-2007 at 09:08 AM. |
Member # 92313
![]() I use one for rear steer, it works great. Lots of power. The only problem I had with it was the vent on the tank. On steep angles the fluid would block the vent and pressurize it so I put another tank on it and vented it properly and no more probs. I'm pretty sure you couldn't use it for the front because it's on a toggle, not sure how you could get it to work with a orbital valve. |
Member # 4197
I use something similiar made by Fenner STone , aka SPX. It is a different part number and has an integrated solenoid pack on top to divert the fluid and hold the fluid against pressure. I will see if I can post you the part number and a link to purchasing it. I know that Bailey hydrostatics in Knoxville can get them as I have bought parts for mine over the years..
Wouldn't use it for the front because it requires a hand held control to puch.. If your looking for another power steering pump and Station can't get you one have consider a HOWE...Very expensive, but, might be worth it to run front and rear steering with Stations uber bling rear steer valve.. |
www.patparts.com
Member # 4821
What do you mean it's on a toggle? Do these things also control flow? As in, you don't have a seperate rear-steer valve? If so, I didn't know that. Fast is great for me though.
Basically, I need sopemthing to be a pump and nothign more. I have everything else in my system set up and working. I don't really trust any pump besides Station's but have never had any experience with Howe. If I do go with just a regular old belt-driven pump again, it would probably be Station's. But I'm not sure that I have the time to wait for it. J. J.
Member # 53741
Try calling JR with Mason Dynamics at 800-653-1382 (www.masondynamics.com) They are a large reseller of monarch hydraulics that we purchase our 12 volt powerpacks from. JR has been extremely knowledgeable and helpful for my business. He should be able to figure out the drift, etc that TJMark has experienced. I do not know how affodable he is with buying just one or if he will even sell just one, but he definitely knows his sh*t
2006 Frankie's Offroad ASM4 build in process F/R steering Rock's OEM Violater Shafts Vortec 496 8.1 Turbo400 with reverse manual valve body Stak 3 speed POS steering 49" IROK's mounted on Stazworks 20"x12"'s |
Member # 14113
we have 12 volt pump for front steering in formula offroad rig.
it`s 1500w so it will takes 125 amps when it operates. but in reality it takes more amps because voltage will drop and it will eat more amps. some issues: eats shit loads of amps you need big alternator efi cars might have issues from voltage drop. it heats very hot if you run it too long time. it doesnt have power like belt driven ones |
#8 (permalink) | |
Member # 4197
http://www.grainger.com/Grainger/wwg...ryString=4Z339 or go to grainger.com.. Search grainger number 4Z339E .However, Bailey Hydraulics in Knoxville can get them and get parts..Their website is www.Bailey.net or 18008001810.. The part number is as follows: SPX fenner stone : serial number 1405 , part number 4Z339E, Model umber DB-1082..DC-60. It is heavier than Stations unit....honestly if you want to keep a pump and you will have limited to mount your better off sticking with what you have or going to Station nice rear steer set-up. When my dies I will convert to stations set-up.. couple of pics and if you have questions e-mail me |
www.patparts.com
Member # 4821
I have Station's rear-steer setup. The only thing that isn't his is the pump and only because I had one but fucked it up. (My fault, not his.) I was in a hurry for a pump at the time and PSC's was cheaper and in-stock, so I did what I had to do. I guess I see why theirs are cheaper now though.
I guess I just need to wait on one of Station's pumps and hope it gets here before my current pump dies. I just can't believe that there's not a 12-volt option in this day and age though. I mean, we have 12-volt water pumps, oil pumps, TV's, DVD's, backup cams, proximity sensors, hell, we even have an 12-volt BUGGY now! But no one can design a friggen hydro pump that works right??? J. J.
#10 (permalink) | ||
Addicted to Gear Oil
Member # 56050
Here's one: http://www.pirate4x4.com/forum/showt...power+steering Another has some good info/links http://www.pirate4x4.com/forum/showt...power+steering
1965 Scout 80 7.3PSD/ZF/203/205 D60F/14BFF Member: 4 Jackstand Wheeler's Association Quote:
David H. Petraeus for President 2016Last edited by guidolyons; 11-12-2007 at 08:24 PM. |
Member # 33536
what about some type of linear actuator instead of hydro? or what about a beefy air cylinder (i know air compresses and fluid doesnt)
i am agreeing the above post that it seems strange there are no other options for this. found some linear actuators on Mcmaster that push and pulll 1500 pounds, but they are a grand each. you eliminate tanks and pumps and hoses, etc though, so it maybe worth it.. just a thought.. |
#12 (permalink) | |
Member # 17950
For example, a 2" dia hydr ram used in conjunction with the pump shown in the original post (1600 psi) will be able to exert over 5000 lbs of thrust (extending). You answered your own question about pneumatics.
03' TJ Pile of DOM, 6.0 vortec, TH400, stak 3 spd, two steering rocks, 44" TSL's. |
#14 (permalink) |
Member # 4197
Why don't you ask Sean to refer you to "Lee" who used to make pumps for him.. If the guy is still alive ( Lee Steering systems..no website) his would probably be a good choice. Sean used to use his pumps and last time I spoke with Sean he had nothing but good things to say about "Lee's" pumps...Good Luck.
