Dana Planetary Axles - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 11-13-2007, 11:11 AM   #1 (permalink)
Member # 61635
I found these axles for a good price but can't decide if I want these or rockwells. The gear ratio is roughly 1:12 with a track width of 65 inches. They weigh 800lbs so they are not tooooo heavy.
Any one use this type of axle (besides HappyThrottle and Randy)?
77 Wagoneer | 6.0 | th400 | NP205 | D60 | Sterling 10.5
ls1toyota is offline   Reply With Quote Quick reply to this message
Old 11-13-2007, 11:15 AM   #2 (permalink)
Big79'Terry's Avatar
Member # 63730
Dana Planetoids????
Specs????? What are they out of ??? Axle shaft dia.???? Locker availability???
Big79'Terry is offline   Reply With Quote Quick reply to this message
Old 11-13-2007, 11:25 AM   #3 (permalink)
Member # 61635
Not sure what they are out of but here are some stats:
inboard wet disc brakes
hydraulic applied locker
20,000 lb load capacity
Not sure on the axle dia. maybe someone colud help on that
Old 11-13-2007, 11:32 AM   #4 (permalink)
thhhpptthh!
sceep's Avatar
Member # 10798
Send a message via AIM to sceep Send a message via MSN to sceep
dew it.. just on cool factor alone.
Originally Posted by USDA forest service website
It is every American's birthright to use the national forests and grasslands in multiple ways, including outdoor recreation in all its forms.
sceep is offline   Reply With Quote Quick reply to this message
Old 11-13-2007, 11:34 AM   #5 (permalink)
Member # 14437
They look like something out of a Gradall or a Skytrak. If it's a good price I would do it. They already have some of the stuff for Full hydro to.
freds40 is offline   Reply With Quote Quick reply to this message
Old 11-13-2007, 11:35 AM   #6 (permalink)
Member # 72504
I am guessing by "happy throttle" you meant me. If you can make these work in your aplication they are far better in almost every way. Gearing is usually in the 20:1 range, shaft diameter is not as important because the planetary takes most of the load (but they are still big), steering is a huge advantange usually in the 60 degree range.
Also those look like they are out of a tug so they are a smaller version and should not be much more weight than a rockwell with more ground clearance.
Jamie
Throttle Happy is offline   Reply With Quote Quick reply to this message
Old 11-13-2007, 11:35 AM   #7 (permalink)
Fl-Krawler's Avatar
Member # 47337
i think it would be cool to build something that doesnt use run of the mill parts (60's rockwells etc.) but on the flip side of that if you manage to break a part on those axles, on the south side of bum fuckt egypt are you gonna be able to get parts for them?
Fl-Krawler is offline   Reply With Quote Quick reply to this message
Old 11-13-2007, 11:37 AM   #8 (permalink)
44Runner's Avatar
Member # 9095
Send a message via AIM to 44Runner
exactly!
Buggy in progress - 22RE on pane, A340, 4.7:1, 8" f/r, 4Ds
Project Straight Pimpin' - 1989 4Runner 3.slow 5spd SAS'd 8" F&R w/4.30 255/85R16
2005 Ram 2500 4x4 CTD 6spd QC SWB
44Runner is offline   Reply With Quote Quick reply to this message
Old 11-13-2007, 11:46 AM   #9 (permalink)
thhhpptthh!
sceep's Avatar
Member # 10798
look ALOT like the 276's but the width is wrong..
http://www.dana.com/offhighway_syste...276HD_axle.pdf
complete list of the dana planet's: http://www.dana.com/offhighway_systems/axles.shtm
Old 11-13-2007, 12:04 PM   #10 (permalink)
Member # 61635
here is the discription: DANA SPICER CLARK HURTH 278 STEERING PLANETARY DRIVE AXLES, WET DIS BRAKES, TRACK WIDTH 1660 MM, ORIGINAL APPLICATION VERMEER TRENCHERS
Old 11-13-2007, 12:08 PM   #11 (permalink)
Member # 61635
Jamie
yeah i meant you. sorry
Old 11-13-2007, 12:12 PM   #12 (permalink)
thhhpptthh!
sceep's Avatar
Member # 10798
no such thing as a 278 as far as i can tell.
Old 11-13-2007, 12:24 PM   #13 (permalink)
Member # 61635
I called Dana and they sent me a pdf of the 278. I have no way to post it on here. If you want to see it I could send it to you.
Old 11-13-2007, 12:28 PM   #14 (permalink)
thhhpptthh!
sceep's Avatar
Member # 10798
send it.. i'll convert and post.
Old 11-13-2007, 12:30 PM   #15 (permalink)
Member # 61635
sent
Old 11-13-2007, 12:36 PM   #16 (permalink)
thhhpptthh!
sceep's Avatar
Member # 10798
Old 11-13-2007, 12:37 PM   #17 (permalink)
Medium-core
ndeepoffroad's Avatar
Member # 79902
The look bad ass...I say go for it.
I would try to buy up another set to have spares when/if you do break something, that way you already have it and you aren't stuck somewhere (like someone else said) waiting to get parts that may take weeks to get.
5th Annual Rally in the Valley
April 28-May 1, 2016
ndeepoffroad is offline   Reply With Quote Quick reply to this message
Old 11-13-2007, 12:38 PM   #18 (permalink)
"All Weeee Drive!"
MochaMike's Avatar
Member # 6450
These are in classifieds:
http://pirate4x4.com/forum/showthread.php?t=629880
62 IH Scout, Built to wheel.
MochaMike is offline   Reply With Quote Quick reply to this message
Old 11-13-2007, 12:39 PM   #19 (permalink)
Member # 8459
Those look pretty cool!!!
I'm curious about a few things:
What exactly are "wet disc" brakes? I assume they are located inside the housing somewhere that lubrication is present - where exactly are they and how do they operate?
Where'd you find 'em?
What is the approx. cost for the two steering axles pictured?
What is the parts availability/support? Where and cost?
Hub diameter and lug pattern?
They would definately bring the cool/unique factor to any rig runnin' them.
Never ending Frankenstein FJ40 project.
ckolloff is offline   Reply With Quote Quick reply to this message
Old 11-13-2007, 12:39 PM   #20 (permalink)
thhhpptthh!
sceep's Avatar
Member # 10798
Originally Posted by MochaMike View Post
bzzt wrong try again.
Old 11-13-2007, 12:57 PM   #21 (permalink)
Pdaddy's Avatar
Member # 8133
Im afraid to know what those are gonna cost
LCQ / KOH 09 Co-Driver #62
Midwestwheeler / Hardline Custom
Pdaddy is offline   Reply With Quote Quick reply to this message
Old 11-13-2007, 01:38 PM   #22 (permalink)
sodaboyYJ's Avatar
Member # 17421
Send a message via Yahoo to sodaboyYJ
Neat idea, and not to rain on your paraide, but; wouldn't 12:1 be a huge pain in the balls if you ever wanted to drive to/from a trail? Top speed would be what? 15-25MPH??
'93 YJ, 5.0/C6/Atlas 4sp/ 38.5 SX's...D60's F&R with ARB's on coils
sodaboyYJ is offline   Reply With Quote Quick reply to this message
Old 11-13-2007, 02:03 PM   #23 (permalink)
Member # 3152
Send a message via AIM to Trango Send a message via Yahoo to Trango
There are a couple sets closeby here, too, but none are in that good condition.
Compulsive vehicle builder
Trango is offline   Reply With Quote Quick reply to this message
Old 11-13-2007, 02:12 PM   #24 (permalink)
Member # 23545
ok have seen those axles in underground service trucks. They put them under fj-45 pickups that are diesel. Super expensive to fix!!! The wet brakes are good and hold great. I have seen these axles break with just a 4cyl diesel pushing them. Alot of places and mines are taking them out and replacing them with something cheaper and more parts options. If ya can get them cheap go for it but it better be cheap cheap cause if ya need parts they are going to get ya. But if ya need parts i can lead ya in some directions. Garrett
crewchief is offline   Reply With Quote Quick reply to this message
Old 11-13-2007, 02:17 PM   #25 (permalink)
Member # 23545
Here this place can help ya. Its in canada but eh! haha. Its called RES equipment sales 1(807)-221-4770 or email them at res@moosenet.net with questions.
