Anyone familiar with 'Heavy Duty' AX15? - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 01-27-2008, 11:09 AM   #1 (permalink)
Member # 96615
I'm looking into a 5spd to use on a 98 5.9 ZJ and trying to decide between the 3550 and the HD AX15.
First off - No NV4500. I don't want the 'almost granny' 1st gear.
Second - I'm not talking about a stock rated AX15. The unit in question is a "Heavy Duty" AX15 built by Aisin to rsgear specs.
On the Jeep forums the 3550 is almost always spoken of as an upgrade from the AX15. Recently I was corresponding with George at Tcaseunlimited about a Tcase for this build and he strongly adivsed against using the 3550 due to both strength and the parts availablity issues.
He said he has new Heavy Duty AX15s that are rated at 420 to 450 ft lbs input torque vs the 3550s 300 to 320 rating. Obviously this higher rating sounds better but it seems like almost no one has any actual experience with this HD box.
I'd appreciate any feedback on this HD box if anyone has one or knows anyone that uses one.
Z88Z is offline   Reply With Quote Quick reply to this message
Old 01-27-2008, 11:11 AM   #2 (permalink)
Paying for others
jeepcrazie's Avatar
Member # 38032
Nice cross post.
I like the 3550
Shady Lady VIP #13
jeepcrazie is offline   Reply With Quote Quick reply to this message
Old 01-27-2008, 11:20 AM   #3 (permalink)
the freeak's Avatar
Member # 41185
Why don't you just step up to an NV4500 if you are worried about the strength...?
Thats what I would do.
It only about 100 pounds heavier.
the freeak is offline   Reply With Quote Quick reply to this message
Old 01-27-2008, 11:46 AM   #4 (permalink)
Member # 96615
No, that's the whole point. I'm looking for more street friendly gearing. The NV4500 is the best box for offroading for sure and the "almost granny" 1st gear would be an asset there but it's not really useable for my application.
Originally Posted by jeepcrazie View Post
Nice cross post. I like the 3550
Hope that's not a big no-no here. The issue is driving me nuts. I've been posting this question in the various Jeep forums for about two months and so far absolutely no one with any familiarity with this new and improved AX15 has responded. Def sounds better than the 3550 if it's true but it seems like I'm entering uncharted territory!
Thanks for any input folks.
Old 01-27-2008, 12:55 PM   #5 (permalink)
2manyprojects's Avatar
Member # 39901
So, you're building a pavement pounding jeep?
"]my 90 project [/URL]
Save a tree, eat a beaver.
There are two keys to life, leverage and lubrication. Sometimes you need both.
Because there is no 2nd chances on Pirate!
2manyprojects is offline   Reply With Quote Quick reply to this message
Old 01-27-2008, 01:16 PM   #6 (permalink)
Member # 96615
Umm, ya... and yes, I'm familiar with just how popular that idea is on the forums but considering this HD box sounds like a viable option for 3550 or stock AX15 replacement I think it is an appropriate place to ask about it.
For the record, no dubs or alteezas. Just engine, drivetrain and suspension mods for better DDing.
Old 01-27-2008, 01:36 PM   #7 (permalink)
Keith's Avatar
Member # 52
Your kinda loosing me on the "almost granny" of the 4500. You dont use that gear for normal driving. You are excluding a trans that is miles ahead of the other two because it has a granny gear?
Keith is offline   Reply With Quote Quick reply to this message
Old 01-27-2008, 01:51 PM   #8 (permalink)
jeepfamily's Avatar
Member # 19879
ax-15
I am quite familiar with ax-15s but have never heard of an H.D what is it out of ?a dakota?Its still an aluminum housing correct?If it is I highly dont think it can handle that kind of load as you stated.There is a guy in florida that is a guru on these I will try to find his #,he sells his own type of H.D on ebay.Is the tranny purple painted because if it is I bet its one of his.
2016 jk chromo 37s daily, 06 dodge 351/480 efi on meth, 2011 sxor u4 buggy and yes your mom rode in it
jeepfamily is online now   Reply With Quote Quick reply to this message
Old 01-27-2008, 02:15 PM   #9 (permalink)
Member # 96615
Why install something that weighs that much more that I'd have to use as a 4spd? I don't plan on abusing the 5 spd but I'd rather start with the stronger box.
Not sure which housing it uses. These are Aisin built units - supposedly brand new and built to RS gear specs (rsgear.com) and sold by tcasesunlimited in New York. George there is known for building good Tcases including hybrids like a 249/247 cross so I'm assuming he knows what he's talking about.
But of course he is trying to sell his product too.
Let me know if you find that link to that ebay site. Meanwhile I'll try to find it.
Old 01-27-2008, 02:58 PM   #10 (permalink)
GRMhick's Avatar
Member # 87
Send a message via AIM to GRMhick
Id run the 3550 for sheer simplicity since it came behind the 318 (same motor, but balanced externally (or is it internally... one is balanced one way, the other the other way) in the dakota, and Ram. Although the same logic could be used regarding all the mounting/fit because the ax15 came stock in '93 6 cyl grand cherokees.
I personally prefer the 3550 over the ax15, although, I would want some sort of short throw shifter for it.
If you do an AX15, I would call marlin crawler, as he sells rebuilt ax15's.
. Diamonds. 35's.
. RestoMod.
GRMhick is offline   Reply With Quote Quick reply to this message
Old 01-27-2008, 03:01 PM   #11 (permalink)
the freeak's Avatar
Member # 41185
You aren't making any sense:
Either you want a HD trans so you can beat on it, or you don't.
Take a moment and figure that out.
I DID see a thread in the for sale section where some one said that their 3550 was a 3/4Ton "HD" model...but I have NEVER heard of an AX15 being "HD".
EDIT: Here is the thread!
/forum/engines-trannys-t-cases-sale/617603-complete-4-3-vortec-nv3500-package.html
The 3550 is used to REPLACE the AX15 quite often.
EDIT:
Sounds like "George" doesnt HAVE any 3550's and wants to make a sale.
And I SERIOUSLY doubt either trans would survive for long with 420 ft lbs of torque being put through it.
Hell, the 4500 doesnt even see that amount of torque STOCK! (well, maybe with a Diesel)
HOW ARE YOU GOING TO USE THIS GRAND CHEROKEE???
Old 01-27-2008, 03:22 PM   #12 (permalink)
Member # 99513
Never heard of an HD AX-15. I have also searched for any aftermarket improvements on this tranny and have found none. your getting smoke blown up your butt.
But anyone can prove me wrong. Hell, if there is an upgrade out there, I am game because that is what Im running now.
And my tranny is startin to fuss up as it is. I feel this thing will puke out in about a year, then Im going 3550 route.
And if your going with a pavement pounder, why not go t56 or something like that. remove the front axle assembly, t-case, convert the the front to IFS, run 24 inch blingys with xxx/25 ZR 24 road tires while your at it.
All the "cool" people doo it where I currently live
Swapping Front ends:
Motorcycle stuff.
[SIZE="5"][COLOR="Red"][B]NEW BEGINNINGS:[/B][/COLOR][/SIZE]
jpfrk2001 is offline   Reply With Quote Quick reply to this message
Old 01-27-2008, 03:33 PM   #13 (permalink)
jeepfamily's Avatar
Member # 19879
man-trans 877-626-8726 he builds them to your specs.with dyno results and blueprints .He is kinda of expesive but I have only heard good things about them.I have heard of people using the ax-15 in v-8 applications but they usually only last a little while.
Old 01-28-2008, 09:18 PM   #14 (permalink)
Member # 96615
Well maybe I didn't explain it well but here goes. I guess there are two ways to describe "heavy Duty". One being a strong box with low gearing for pulling heavy loads, the other meaning made with more durable parts.
I don't really want to get involved in debating what I use my Jeep for.
This ZJ will be getting used as a DD but it will see some "spirited driving" once in a while and I'd like to improve to ability to hold in corners. (If that doesn't make sense to you - forget I said it)
I don't "beat on" anything. Some types of builds (offroad, drag etc) are going to get extremely hard usage but that isn't really what a lot of people build for unless they're trying to beat the other guy. Either you know how to drive or you don't. I bought an 86 5.0 5spd Mustang brand new and got it to 215K miles on the original clutch. Did I baby it? Not really but I didn't beat on it either.
Of course by the time I got rid of it the synchros were going and I was the only one that was able to drive it.
George is known on most of the Jeep forums as a builder of quality Tcases and has a good reputation. Besides, the lack of available 3550 parts is a known issue judging by what I read on the forums.
So the bottom line is, assuming he's not trying to BS anyone and destroy his reputation among his main clientele - a box capable of handling 420 ftlbs should be a lot more durable than a box that is rated at about 315.
The 3550 has about the same rating as the 3500 and, as I read on the Dodge forums - "the 3500 can hold up to clutch drops behind a built motor or it can crap out behind a stock motor, It all depends on what kind of day they were having at New Venture when it was built"
I'm not planning a mega horsepower build but when I know the choices are either boxes that barely hold up to stock motors or boxes like the 4500 that are overkill and not geared for my usage, then ya, I'm going to look for something in the middle.
Old 01-28-2008, 09:39 PM   #15 (permalink)
Member # 96615
Aw come on, now who's blowin smoke up my butt! Pardon the chop job but it was easier to answer that way.
Never heard of an HD AX-15. I have also searched for any aftermarket improvements on this tranny and have found none.... But anyone can prove me wrong.
Umm, I think I'm about to - finally heard from someone in the know on another forum... (Talking about RSGear)
Originally Posted by Paoluchi
I bought one for my TJ to replace my NV3550 when I installed a Golan stroker and an Atlas II. Price was right around $1,500 out the door. So far I'm impressed with it and it's a bolt in replacement, you can even use your current shifter (NV3550). The folks there were top notch and good to talk with.
Just checked my invoice, it was $1,350 plus tax.
The Terminator - I believe this is the box and I believe George's are built to these specs too: http://www.rsgear.com/terminator.asp
I'll check with man-Trans too and check prices/specs etc.
Is there a website or number for him?
Old 01-29-2008, 12:34 AM   #16 (permalink)
jeepfamily's Avatar
Member # 19879
way to man up newbie
Old 01-29-2008, 06:17 AM   #17 (permalink)
Member # 22301
is there a short throw shifter for an AX15? I know there is for an NV3550 and it's nice to use.
I agree on not using the NV4500, it's just a 4 speed transmission unless you are crawling/towing/hauling.
If you've got money, why not a ZF6 or a T56 like mentioned? I'm sure it could be made to work and 6 gears are better than 5.
phillyzj is offline   Reply With Quote Quick reply to this message
Old 01-30-2008, 10:33 PM   #18 (permalink)
GRMhick's Avatar
Member # 87
www.marlincrawler.com
. Diamonds. 35's.
. RestoMod.
Old 01-31-2008, 08:32 AM   #19 (permalink)
Mr. Personality
Azzy2000's Avatar
Member # 11869
Hurst makes one for the AX-15. At least they used to, I had one on my AX-15 before I swapped to an NP-435. It was a big improvement over the stock shifter.
Azzy2000 is offline   Reply With Quote Quick reply to this message
Old 01-31-2008, 09:35 AM   #20 (permalink)
abrogate's Avatar
Member # 31552
I can see it now, the new Pirate banner...
Pirate4x4.com - The largest "spirited driving" website in the world.
DMTFAB.COM
abrogate is offline   Reply With Quote Quick reply to this message
Old 02-09-2008, 07:48 PM   #21 (permalink)
Member # 96615
Thanks GRMhick.
Works for me!
Old 02-09-2008, 08:07 PM   #22 (permalink)
Beat95YJ's Avatar
Member # 22176
Is it possible to get a 4wd tailshaft on a tremec? I believe that the tremec (or even a world class t5) should be fine with the torque from a stock 5.9.
Well he's a PR genius like you're a Camarogenius
Old 02-09-2008, 09:56 PM   #23 (permalink)
Haggar's Avatar
Member # 11570
Whats interesting is that the AX-15 is a variant of the R150 series used in the Toyotas. The turbo toyota transmissions used a lower 4.something first gear, and Marlin also will rebuild them with a 5.15 first gear gearset.
I wonder if that gearset fits into a Jeep AX15 case.....
Swamp Stompers 4x4 Club
Haggar is offline   Reply With Quote Quick reply to this message
Old 02-10-2008, 07:16 AM   #24 (permalink)
Member # 96615
When I first started researching these boxes someone mentioned checking the Toyota forums for that reason. I still plan on checking Marlin's site too.
BTW - As for the term "spirited driving" - I should explain that one. That's a holdover from my days as a Jaguar mechanic.
It's a typically British reserved and understated way of saying "let's fly around like a S. O. B. and test the very limits of the vehicles performance".... as in "Say Nigel, what say we take the Jag down to Lyme Rock for a bit of spirited driving"... so, whether it's a road course, a mud bog or creeping over a pile of rocks, enjoying your vehicle and pushing it to it's limits falls under the category of "spirited driving".
