best epoxy or glue to patch hole in gas tank - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 02-12-2008, 01:06 PM   #1 (permalink)
Member # 73066
like the title says, i have a hole to patch on my plastic gastank. i will be putting a steel plate and glueing it to the tank. i already used jb weld on it and it lasted about two weeks before the leak came back. any other ideas before i shell out money for a new tank>?
bbwag is offline   Reply With Quote Quick reply to this message
Old 02-12-2008, 01:13 PM   #2 (permalink)
thhhpptthh!
sceep's Avatar
Member # 10798
Send a message via AIM to sceep Send a message via MSN to sceep
weld a plastic patch on. then coat the weld with por15 tank sealant to kill any pinholes you missed.
Originally Posted by USDA forest service website
It is every American's birthright to use the national forests and grasslands in multiple ways, including outdoor recreation in all its forms.
sceep is offline   Reply With Quote Quick reply to this message
Old 02-12-2008, 01:19 PM   #3 (permalink)
Member # 49901
Send a message via AIM to affende
if it is an actual hole, plastiweld will be th eonly way ....
if its a tear / pinhole, rub it good with ivory soap .... you think im being a smart ass, but ivory soap works well for trailfixing a small leak ... i did it on a lawnmower tank a few years back and it hasnt leaked yet.
affende is offline   Reply With Quote Quick reply to this message
Old 02-12-2008, 01:24 PM   #4 (permalink)
Addicted to Gear Oil
guidolyons's Avatar
Member # 56050
Get a plastic welder. Probably would need to drain the gas...it's kinda like a big soldering iron.
There's a guy on here that welded and entire plastic gas tank back together after stretching the wheel base on his heep.
http://www.harborfreight.com/cpi/cta...emnumber=41592
guidolyons is offline   Reply With Quote Quick reply to this message
Old 02-12-2008, 01:45 PM   #5 (permalink)
Member # 27349
Send a message via Yahoo to Hoxviii
I've fixed holes in tanks by drilling the hole out and putting a bolt with a toggle nut through it. at the head of the bolt have a washer and under it a neoprene washer. squeeze some fuel tank repair putty up around the hole and the threads and tighten that thing down.
I've been running it on the rear tank in my truck for about 4 years now with no issues. infact it lasted 3 1/2 years on one truck, truck got majorly wrecked, and then i swapped the tank into the truck I have now. still holds.
Justin
Hoxviii is offline   Reply With Quote Quick reply to this message
Old 02-12-2008, 01:55 PM   #6 (permalink)
Well Done Man!
welndmn's Avatar
Member # 398
Out here, they sell Plastic Gas Tank repair kits at the auto parts store.
I'd just use that.
Mark
Old 02-12-2008, 02:05 PM   #7 (permalink)
believe nothing i sa
blue p.o.s.'s Avatar
Member # 17121
i've used JB weld on a few cracks and pinhole leaks in my old YJ's tanks. not sure if it's a good idea, but it worked fine. hell i put another 150,000 on it after one of the seams split and i jb welded the shit out of that one.
if you can't make it, get red labels.
blue p.o.s. is offline   Reply With Quote Quick reply to this message
Old 02-12-2008, 03:19 PM   #8 (permalink)
Member # 73066
the jb weld i used became soft and brittle by the end of two weeks.
Old 02-12-2008, 03:39 PM   #9 (permalink)
Member # 90393
JB WELD didn't stop a leak in my aluminium cell BUT SEAL-ALL did work on my plastic tank.
rockrknockr is offline   Reply With Quote Quick reply to this message
Old 02-12-2008, 05:29 PM   #10 (permalink)
piratebuggy's Avatar
Member # 53597
There is some polyethylene glue called Gorilla Glue that is available in hardware stores around here that worked on some water tanks I have where nothing else would stick for very long. Don't have the bottle anymore to check for applications but it does stick to poly tanks like nobodies business. Might be worth a try-cheaper than plastic welding equipment.
78 Jeep CJ-5 304 ---setting off car alarms with extreme prejudice.......
out cali style!!!!!!
piratebuggy is offline   Reply With Quote Quick reply to this message
Old 06-26-2010, 03:43 PM   #11 (permalink)
Member # 151432
I used tire plugs to seal a 2 inch gash in a tj plastic tank to get a friend out of the rubicon, it held for days and is still not leaking weeks later..
faziom is offline   Reply With Quote Quick reply to this message
Old 06-26-2010, 05:31 PM   #12 (permalink)
bowtie44s's Avatar
Member # 116039
I welded my steel one with a mig. Ran a radiator hose from my truck exhaust in the tank and let it idle for 15 minutes. So if you do any heat or flame on the plastic make sure to get rid of the O2 with exhaust.
bowtie44s is offline   Reply With Quote Quick reply to this message
Old 06-26-2010, 07:01 PM   #13 (permalink)
Member # 63268
Fiberglass!
Icelandic snow rig. '87 YJ, 6.0 Vortec, 44" DC's, Dana 44 F&R, 2.0 Fox 14" Travel, 106" WB, 5" lift
Doublehead is offline   Reply With Quote Quick reply to this message
Old 06-26-2010, 08:58 PM   #14 (permalink)
Member # 161233
Had a humvee come in the shop in Iraq with a spent 50. Cal casing hammered. In and it had held for months. Good luck finding one stateside though...
Ive come to realize that growing up is a great waste of time.
Sandmonkey is offline   Reply With Quote Quick reply to this message
Old 06-26-2010, 09:28 PM   #15 (permalink)
Member # 142180
if you use fiberglass stay away from ethonal it will make the patch soft.there is a 3 m epoxy that you get at the bodyshop supply house cant remember the part no. will work even better with the plate if you can put presure on it while it cures i think its called riged parts repair formula i have even used it on batterys
sidrocks is offline   Reply With Quote Quick reply to this message
Old 06-27-2010, 06:38 AM   #16 (permalink)
Member # 157046
This stuff kicks ass, it's dirt cheap and it sticks like snot to gasoline wet plastic.
I tore off the exhaust before my cat on a 1990 pontiac tempest, so obviously I just stuck a cherry bomb on where the cat was. Problem was the exhaust was pointing right at my plastic gas tank. Eventually it melted about twenty small holes in the tank. I used that seal all shit just to try and hold temporary, it hardened up like epoxy (did my fix in winter too -25 C) and I ended up leaving it like that.
Eventually my heat shield (that I neglected to remove) was rubbing the gas tank and sliced a hole about 11 inches wide in the tank above where the pin holes were. You guessed it, seal all, I used two tubes this time (about $5 each) and worked again.
xmptsunami is offline   Reply With Quote Quick reply to this message
