What is DOM tube? - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 02-20-2008, 07:05 PM   #1 (permalink)
Member # 68562
What is DOM tube?
I know that the 4x4 world uses DOM tubing for its rigs. DOM I think means drawn over manderal but what is it exacatly, as in a number? I want to be able to go to the steel supplier and get the right stuff. Thank You
Old Blue is offline   Reply With Quote Quick reply to this message
Old 02-20-2008, 08:24 PM   #2 (permalink)
Member # 13786
What are you buying the tubing for?
KWTMECH is online now   Reply With Quote Quick reply to this message
Old 02-20-2008, 08:28 PM   #3 (permalink)
Member # 99302
There isn't a special language to ordering DOM. Tell them the diameter, which is the O.D. and the wall thickness. Most common IMO is 1 3/4" OD with .120 wall thickness.
My Truggy build thread:
85' Toy based 4 Seat Buggy 22re, W-56, dual cases with 4.7's in rear, 5.29's, Detroit/Welded, poofields, marlin hy-steer, hydro assist, linked with 18" Air Shox, RUF, front range x-member, 38" TSL's, and some tube
travisford83 is offline   Reply With Quote Quick reply to this message
Old 02-20-2008, 08:45 PM   #4 (permalink)
Member # 68562
Roll cage, bumpers, rock sliders, under armour.
Old 02-20-2008, 08:47 PM   #5 (permalink)
Member # 68562
So cold rolled or hot rolled works? I thought it was different?
Old 02-20-2008, 09:06 PM   #6 (permalink)
Member # 99302
Here is a post from BillaVista, I am NOT taking credit for this wealth of knowledge-
Steel Tubing
It is impossible to go into details about every type and shape and grade of steel product available or that we might be interested in. There are far too many, and availability will vary greatly depending on location and manufacturer/supplier.
That said, one of the most often used, most often asked about, and most often misunderstood products we use is the venerable round steel tubing.
Round steel tube is commonly available in a number of industry standard sizes. For an idea of the common industry sizes (inside diameter (ID), outside diameter (OD), and wall thickness) browse the supply catalogue of your local supplier or check the Pirate4x4.com tech database HERE and especially HERE.
Note that round steel mechanical tubing is NORMALLY ordered and supplied based on a specified OD and wall thickness. The ID is the result of these former 2 specs. There are however some exceptions to this - most notably in true seamless tubing.
Here are some Flash™ graphics of the different steel tube forming processes that I snagged from the excellent Steel Tube Institute of North America website.
Contnuous (butt welded) pipe process.
The continuous process produces a full range of pipe sizes from only a few different widths of skelp. The coils of skelp, or strip, are fed into the mill and their ends welded together to provide a continuous flow. The strip passes through a pre-heater and into a furnace. The heated strip is shaped into an arc of about 270° in a forming stand before passing into the welding stand. There a nozzle applies oxygen to the edges to further heat them as they are pressed and welded together. The pipe's OD and wall thickness are reduced in a stretch-reducing mill. Pipe is then cut to length, reduced to the required size in a sizing mill and water-cooled before being straightened. It is then ready for finishing
Typical Electric Resistance Welded tube process
Steel strip is unwound from coils and side-trimmed to control width and condition the edges for welding. The strip then passes through a series of contoured rolls which progressively cold-form it into a circular shape. The edges are forced together under pressure and welded by heating the steel to temperatures between 2200° F and 2600° F using copper contacts or coil induction. Weld flash is removed from the the inside and outside surfaces of the newly-formed pipe, and the weld zone is heat treated to ensure homogeneity between the base metal and weld. The weld is subjected to in-line nondestructive testing, and the tube then passes through a series of sizing rolls to attain its precise finished diameter. It is then straightened and cut to the desired finished length.
DOM tube being constructed, starting as ERW and then being drawn over a mandrel.
The manufacturing process for DOM tubing begins with coils of steel, which are slit to the proper width for the desired tube size. The strip is cold formed and passed through an electric resistance welder which joins the edges together, under pressure, to complete the tubular shape. After testing the weld's integrity, the tubing is cut to length for further processing
Seamless tube construction
The production process for seamless tube begins by heating a steel billet to about 2250° F. The red-hot billet is rotated and drawn by rolls over a piercing rod, or mandrel. The action of the rolls causes the metal to flow over and about the mandrel to create a hollow tube shell. After reheating, the shell is moved forward over a support bar and is hot-rolled in several reducing/sizing stands to the desired wall thickness and diameter. The tube, which has grown significantly in length during the piercing and sizing processes, is then cut into sections and conveyed across a cooling bed to cool slowly in the air. It then receives whatever finishing processes are needed to meet customer requirements.
Steel tubing is usually supplied in one of the following forms:
Seamless Tube.
This is expensive and specialized stuff. It IS NOT the commonly used (and misreferenced) DOM tubing, as DOM tubing does indeed have a seam (albeit, almost invisible - more details below). True seamless tubing is uncommon in 4x4 and automotive use. It is seamless because it is manufactured by a process know as "extrusion" where a solid bar of steel is pierced down the center with a die, at unthinkable pressures, to form a tube. The process looks similar to how hollow pasta (macaroni etc) is made. There are 2 sub-types of seamless tube:
Cold Drawn Seamless (CDS) Tube is normally drawn to O.D. and I.D. dimensions and produced to standard dimensional tolerances (this differs from most other types of tubing except DOM) . It is normally made from SAE 1018 and is considered good quality.
Hot Finished Seamless (HFS) Tube is lower in cost than cold drawn and most applicable where precise dimensions and surface quality are of secondary importance. It is manufactured to O.D. and wall dimensions from SAE 1026 steel and is scaly, less dependable and not as strong as cold drawn tube.
Electric Resistance Welded (ERW) Tube
ERW is the most economical and readily available type of mechanical tuning. It is produced by taking a flat bar of steel and rolling it into a tube shape (picture rolling up a newspaper - but without any overlap) and then welding the seam - by, you guessed it - electric resistance - hence the name. Electric resistance welding is somewhat like a long, continuous spot weld. It's often computer controlled and extremely consistent. ERW is normally SAE 1010 (for wall thickness < 16 ga) or SAE 1020. ERW tube comes in 2 flavours:
Hot Rolled ERW (HREW)
HREW is rolled into a tube at elevated temperatures, usually way above room temperature. This produces a tubing that is more malleable and therefore easier to form but that is also not as strong, is supplied covered with scale, and not as uniform in dimension as cold rolled. It is also quite a bit cheaper than cold rolled.
Cold Rolled ERW (CREW)
CREW is manufactured by a process in which a steel bar is rolled into a tube and the seam welded, usually at room temperature. Compared to hot rolled, CREW is stronger - (greater yield strength) - because of the improvement in the crystal lattice structure from improved grain size, shape, and orientation imparted by being worked at cold (room) temperatures), straighter, has a much smoother and more uniform surface finish, and is made to much tighter, more consistent dimensions. It is the best economical choice for tube work, and because of the better surface finish and tighter dimensional tolerances it is much nicer to work with than HREW.
Drawn Over Mandrel (DOM)
Strong and well-finished DOM is an electric resistance welded tube tested for soundness of weld and drawn through a die and over a mandrel. This process imparts significantly improved mechanical properties to the tube, due to the cold working process. It is considered a high quality tube, and is normally constructed from SAE 1020 or 1026 steel. Note that, technically DOM refers to the process by which the tube is finished after having started as an ERW tube. Technically, DOM is not a type of steel tube, but rather a process. As so often happen though - in common use the term has become accepted to mean a specific type of tubing rather than a process. In this case, when people say "DOM" they normally mean an ERW tube drawn over a mandrel at (close to) room temperature and made from SAE 1020 steel. It is normally drawn to O.D. and I.D. dimensions. Here is what the Steel Tube Institute of North America has to say about DOM:
The DOM Manufacturing Process
The manufacturing process for DOM tubing begins with coils of steel, which are slit to the proper width for the desired tube size. The strip is cold formed and passed through an electric resistance welder which joins the edges together, under pressure, to complete the tubular shape. After testing the weld's integrity, the tubing is cut to length for further processing.
The cold-drawing process creates a uniform, precision product with substantially improved tolerances, surface finish and tensile strength, increased hardness and good machinability. In this process, the tube is cleaned and annealed, and one end of each length is squeezed to a point so it can be gripped by the drawing mechanism. The tube is then drawn through one or more dies and over mandrels. This reduces the diameter of the tube and thins its walls to the required dimensions in a controlled fashion to provide the qualities desired in the finished product. Metallurgically, drawing improves the tube's concentricity, tensile strength, hardness and machinability. Close dimensional accuracy is achieved through tight control of both outside and inside diameters.[10]
Alloy Steel Tubing
Is not really a different type of tubing, as it will be manufactured by one of the above described methods, usually by extrusion, but from alloy steel instead of mild steel. It is generally available in either the normalized or the annealed condition. Commonly referred to as chrom-moly tube - it has very strict welding process and post-welding heat treatment and stress relieving requirements. It is my opinion that it can (should) only be TIG or Oxy-Acetylene welded, and then only if proper stress relieving will be done post welding. Sure people MIG weld it all the time, and you can safely do so - BUT - what you have in the end is a superior tube with an inferior weld joint which reduces the overall strength of whatever you fabricated to the weakest link (the weld in this case) and so you have a very expensive structure that is no better overall than one made from 1020 DOM.
Exact chemical content, heat treatment, physical properties, production method and therefore mechanical properties will vary from one supplier to the next, even for seemingly similarly named products - the wise fabricator double-checks all assumptions carefully before building anything. Different suppliers will also have available different products. For example, Ryerson-Tull, one of North America's largest suppliers list in their catalogue of steel tubing between 1" and 2' OD, the following types (not all available in all sizes):
CDS, HFS, DOM, ERW, and a proprietary product they call "Ry-Star 512 Extra".
Many suppliers will have such special proprietary products - you will have to check with your supplier for its proprietary product properties and specs.
One thing that has to be watched out for is that the industry bends a lot of carbon steel tubing to make lots of things and so most carbon steel tubing is available in the annealed condition—woe to him who does not detect it before he builds the part. I have a very good friend who once got an entire roll cage cut, bent, fitted and tacked before he realized that his merry men were working with annealed boiler tube. The other thing that we don't want is "free machining tubing." I currently use round carbon steel DOM mechanical tubing for most things other than suspension links (there I use E4130N and stress relieve and heat treat after welding). For roll cages I use either 4130 or DOM 1020. I do not want to know about hot-finished tubing because I do not want to clean it. I am old enough to remember the days when English ERW tubing was liable to split along the weld seam. As a matter of principle (or, possibly, stubbornness) I do not use ERW or butt welded tube on the race car; although, since it is a lot cheaper, I use it all over the trailer and the shop.[11]
My personal mantra on the subject of steel tubing choice for 4x4s and rock crawler's is:
"You can't go wrong with 1020 DOM!"
BillaVista
Old 02-21-2008, 06:07 AM   #7 (permalink)
Member # 68562
Thank You that is what I wanted and more. Time to go shopping
Old 02-21-2008, 08:03 AM   #8 (permalink)
Member # 99302
No problem
Old 02-21-2008, 07:48 PM   #9 (permalink)
Member # 108955
Send a message via AIM to Phynix Fyre Send a message via Yahoo to Phynix Fyre
I usually use Sch. 40 or Sch. 80 Galvanized pipe that is typically used in fire sprinkler systems (sch. 40, but sch. 80 is available). It wont rust, and the heavy wall thickness lends to great strength, just dont try to bend it. I have fabbed bumpers from this pipe with all treaded fittings even and exhaust system one time...
Bought, Paid for and MINE!!! (too bad my wife likes driving it)
Phynix Fyre is offline   Reply With Quote Quick reply to this message
Old 02-21-2008, 08:37 PM   #10 (permalink)
Gear Geeks
Action Fab's Avatar
Member # 77386
wow pipe fittings....
Action Fab is offline   Reply With Quote Quick reply to this message
Old 02-21-2008, 09:53 PM   #11 (permalink)
Member # 68562
I am a commercial electrician. Yes a pro pipe bender in that field. sch 40 and sch 80 for rigs.... SHIT!!! Threaded fittings for strength? We break them all the time at work, couplings are not for strength they are for joining. The support rack is what is used to keep things from moving. This from an engineer?
Old 07-16-2009, 02:21 PM   #12 (permalink)
The Piratenite
camo's Avatar
Member # 4
Send a message via Yahoo to camo
anybody have a link to the different grades of tubing commonly available ?
Millennials, making hippies look tough since 1980
camo is offline   Reply With Quote Quick reply to this message
Old 07-16-2009, 03:13 PM   #13 (permalink)
SpineTx's Avatar
Member # 1499
These guys show a pretty good selection that they keep in stock. And they offer a decent price:
www.teamtube.com
Pain is your Mind Failing you;
Body Damage is your driving ability failing you
SpineTx is offline   Reply With Quote Quick reply to this message
Old 07-16-2009, 03:21 PM   #14 (permalink)
The Piratenite
camo's Avatar
Member # 4
www.teamtube.com
looking for a list of HREW AND DOM materials that shows yield strength in PSI.
that said yes I agree Team tube is a great source
Old 07-16-2009, 03:32 PM   #15 (permalink)
Member # 929
http://www.amcastle.com/pdfs/carbonandalloytubing.pdf
here is a good one.
Most of the DOM you find is 1026 but you see 1020 from some of the suppliers. Most of the ERW you see at the local place is 1010 but you see 1020 sometimes from the big companies that deliver on their own trucks. The real strength difference is from the alloy more than the process as you can see from the chart.
Gordon is offline   Reply With Quote Quick reply to this message
Old 07-16-2009, 03:41 PM   #16 (permalink)
SpineTx's Avatar
Member # 1499
here is a good one.
Thanks, that will be useful.
Old 07-16-2009, 03:41 PM   #17 (permalink)
The Piratenite
camo's Avatar
Member # 4
here is a good one.
am I missing it or do they not show any grades in DOM ?
also from Billavistas tech
http://www.pirate4x4.com/tech/billavista/Links/
Old 07-16-2009, 03:51 PM   #18 (permalink)
Member # 929
in the second section down where it says welded mechanical. the first ones that say ERW are different grades of ERW and the and the third one that says DOM in the third and fourth column is DOM. the fourth one is a surprise that you might get if you order DOM from a sleazy vendor. 4130 is also there a page down.
Old 07-16-2009, 04:08 PM   #19 (permalink)
Member # 113460
http://www.rorty-design.com/content/...._strength.htm
Another useful length for tube strength...
COYFC is offline   Reply With Quote Quick reply to this message
Old 07-16-2009, 04:56 PM   #20 (permalink)
Member # 84593
So 1.75" .095 wall is 36% stronger then 1.5" .120 wall? and 1.75" .120 wall is 64% stronger...
I'm guessing this strength it's referring to is the amount of force required to kink, or squish the round tube structure...
HardcorewannabeXJ is offline   Reply With Quote Quick reply to this message
Old 07-16-2009, 05:25 PM   #21 (permalink)
Union Fab Works
carwash's Avatar
Member # 21939
Send a message via AIM to carwash Send a message via Yahoo to carwash
so, i've always know the process BV talks about for making DOM... and that it starts as ERW, etc... If this is true for all sizes, i'm truly amazed at tubing like 2" .500 wall etc... that's a serious piece of ERW, then drawn to make it look seemless and without weld... You can't buy 2" .500 wall ERW, not that i have ever seen, and i have dabble in a bit of tube for a while.
there has to be a different process for the thicker stuff....
carwash is offline   Reply With Quote Quick reply to this message
Old 07-16-2009, 06:00 PM   #22 (permalink)
Member # 55549
Sorry, I dont have a scaner but here is a picture from the EMJ tube book.
1969 EB, 88 Speed density EFI 302, HP D44 front w/ARB, Radius arm long arm, NP435, D20, D60 w/power lock rear, 4link rear in progress.
Its not a Jeep, and dont even think of calling it a Scout!
SonicDonkey is offline   Reply With Quote Quick reply to this message
Old 07-16-2009, 06:12 PM   #23 (permalink)
The Piratenite
camo's Avatar
Member # 4
BINGO !!!
http://www.emjmetals.com/products/technical.asp
a fantastic find.
you can get yeild, tensile and even rockwell data for all grades of Tubing
Old 07-16-2009, 06:21 PM   #24 (permalink)
Member # 929
In most catalogs and distributor inventories, DOM means complies with ASTM A513 type 5. The general description of that process is what BV has in there, but then there are a bunch of caveats at the end that allow the manufacturers to make it different ways and even dual certify the tube. If you ordered the 2".5 wall DOM tube when you got it it would probably have ASTM A513 T5 and ASTM A519 printed on it. A519 means cold drawn seamless. So yes the different process to make thicker stuff is just making seamless tube.
Old 07-16-2009, 06:27 PM   #25 (permalink)
Union Fab Works
carwash's Avatar
Member # 21939
i guess i assumed that.
