Yes I too like the TSLs, but around here we have tons of rock and sharp nasty bitting roots. I have seen many TSL tear on the side walls, even with the 10ply. Most run with the TSL/SX because of the intense side biter tread that not only gets you out of the ruts, or pinching rocks, but also survive being punctured. Same with the Baja Claw. The problem is that the SX only comes in 38.5 and the same with the Claw. The Claw when mounted does measure 39 but the SX only 38. The Boggers would also be OK (actually the are great paddlers in the bog) but the are a little weak on lateral traction, in off camber situations. If I custom cut my own boggers then that would be another option.
So far these pizza cutters have blow every one away off road. At the sand dunes we were rescue vehicle for at least halh a dozen stranded 4x4. Thanks for the input.
