Don't think they will work in the rear without somehow mounting front spindles back there? It would take alot of work, even the axles would have to be custom made.
Just a thought for you. 14 bolt FF and 60 fronts use the same bearings inner and outer. The spacing on the 14 bolt bearings are a little wider than a 60 but it looks like the spindle could be turned down a little and the threads run it deeper to get the same spacing as the 60. The 14 bolt hubs have a different offset than the 60 front hubs. I don't remember the difference it's been 5 years since I converted my HP60 to a hybrid 60/14 bolt.
I have a 70rear and 60 front
the hubs just slide on same as any hub
to run them I would imagine there is a some of work
caliper mounting bracket
custom shafts
are you gonna run Hummer rims?
custom shafts
yes i plan to run hummer rims. why custom shafts and caliper brackets? couldnt i run drums?
