broken 2" ouverson shaft? - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 07-04-2008, 10:21 AM   #1 (permalink)
Member # 96321
Has anybody broken one yet?
Slayer84 is offline   Reply With Quote
Old 07-04-2008, 10:54 AM   #2 (permalink)
Mine!
rfr002's Avatar
Member # 63664
The only one I've heard of is on Tim Cameron's rig and it only broke because the spindle broke off.
Rob
Originally Posted by Dieselmh View Post
You won't find a larger gathering of generous and caring mouth breathing, ego smashing, mother railing fucktards anywhere on the 'net.
rfr002 is offline   Reply With Quote
Old 07-04-2008, 11:26 AM   #3 (permalink)
NOCTURNL's Avatar
Member # 25532
The joint failed not the shafts. he could have thrown a joint in and been fine. to my knowledge, i have yet to see a failure on the 2" stuff for the 2 1/2's. they are overkill as far as i am concerned, either the chunk will fail or some hard part in the t-case or tranny will give up. we are working on new stronger gearsets with the stock 6:72 ratio and a 4:89 ratio.
[FONT=Times New Roman]OEM-ITS NOT JUST STOCK ANYMORE[/FONT]
RANDY OUVERSON
320-983-3030
TRYING TO SAVE THE WORLD ONE SHAFT AT A TIME.
VISIT US AT [url]WWW.OUVERSONENGINEERING.COM[/url]
NOCTURNL is offline   Reply With Quote
Old 07-04-2008, 11:36 AM   #4 (permalink)
Member # 66854
I seem to remember a few TGW guys breaking some 2" OEM's
doing Tug Of War on Hot top with 48"+ tires
Trailers Are For Boats.......... Just Drive It!!!
Sniper W / 2.5 Rocks in the works
Gun Man is offline   Reply With Quote
Old 07-04-2008, 11:49 AM   #5 (permalink)
Member # 15354
Send a message via AIM to iniviate
There's a mud guy that's broken overson 5 ton rear shafts. (stock size, so i hear)
he's on 66" tires though.
02 S10 - LS1, 4L80, 2.5 tons, 14.9-24 R1's - In Progress.
88 YJ - 350, 1 tons, 40's
iniviate is offline   Reply With Quote
Old 07-04-2008, 02:22 PM   #6 (permalink)
MC
MC's Avatar
Member # 21997
Send a message via Yahoo to MC
Randy I have gotten two emails about making a nice 4340+ joint for your shafts. Since we are both local to MN maybe we should come together on this project. I can dedicate some CNC time to a chromo joint but dont really want to do it from a solid. Do you have a forge nearby?
Industrial Quality CNC machines at a Hobby Price!
USA Quality is job #1
We build CNC plasma tables, click me
American Motors Engine HERE!!
1-651-257-7917
MC is offline   Reply With Quote
Old 07-04-2008, 02:32 PM   #7 (permalink)
Mopars 4 Life's Avatar
Member # 108404
If ya watch TGW 5 you will see how Randy tests his parts....IMO you would have to be doing some crazy sheet to break one if he doesn't...
Mopars 4 Life is offline   Reply With Quote
Old 07-04-2008, 03:30 PM   #8 (permalink)
Member # 41097
Nothing is ever truely idiot proof . . . . . .
As there are people in here that could break a steel ball in a rubber room . . . .
that said i haven't seen or heard of anyone breaking a 2" shaft yet, but i have seen 2" shafts break in other axles (i think it was 2", it was out of a way overloaded gravel truck/pup trailer combo in a soft/sticky river bottom)
90' C350 AKA 4 door 1 ton Bronco
96' Ranger: kings, EMF parts, 800hp SBF
mustange70 is offline   Reply With Quote
Old 07-04-2008, 08:21 PM   #9 (permalink)
Member # 10736
Wow that is cool.
masonmachines is offline   Reply With Quote
Old 07-04-2008, 09:44 PM   #10 (permalink)
Member # 108404
Originally Posted by masonmachines View Post
Wow that is cool.
Definitely..that has been one of the major setbacks....some regions require wheel speed!!!
Old 07-04-2008, 10:35 PM   #11 (permalink)
dobsogj's Avatar
Member # 16561
Some 4.89s would be sweet. I have always thought it would be cool to run a rock rear, and a 60 front. You could get the driveshaft clearance and strength in the rear, but not have to worry about clearance around the chunk in the front. When do you plan on having these out? What will be the price range? An aluminum center section would be cool too.
4 seat FJ40 buggy. Alum 5.3 - Th400 - Atlas 4 speed - 60/14 - 42" stickies...etc...[url]http://www.pirate4x4.com/forum/showthread.php?t=660786[/url]
Gone but not forgotten: 81 toyota truggy - LT1 - Th400+203+atlas3.0 - 60 / 14 - 42s. [url]http://www.pirate4x4.com/forum/showthread.php?t=520948[/url].
dobsogj is offline   Reply With Quote
Old 07-05-2008, 08:36 AM   #12 (permalink)
Vertical Limits
blacksheep10's Avatar
Member # 26443
rear steer thats actually strong enough, right on
Kelly Kaiser
Vertical Limits Inc
913.731.3040
Atomic Fabworks (my new full time shop) www.atomicfabworks.com
913.839.8450
Your ORI struts, Solid and Rod End Supply dealer!
team Nasty co dog. FINISHED KOH
blacksheep10 is offline   Reply With Quote
Old 07-05-2008, 04:16 PM   #13 (permalink)
Member # 87868
All it broke was the joint and the c-clip area off the shaft. The shaft was Good but you would have to weld in the caps
[COLOR="Red"][SIZE="6"]VOTE #20 & #7 TTC 08[/SIZE][/COLOR]
Tim Cameron is offline   Reply With Quote
Old 07-07-2008, 04:46 PM   #14 (permalink)
Fool-Injected's Avatar
Member # 78978
Whats the time line on that 4.89 gear set?
Fool-Injected is offline   Reply With Quote
Old 07-07-2008, 07:48 PM   #15 (permalink)
NOCTURNL's Avatar
Member # 25532
We are working on them as we speak. depending on all the empty promises that i keep getting, i am hoping to have some proto's in less than 8 weeks. it seems to be getting harder and harder to get a straight answer out of the steel companies, the forging company and the gear cutters. As far as price, that is something i am working out as i go. i allways try to make this stuff affordable for all, but in reality, some parts just cost to damn much to make.
RANDY OUVERSON
320-983-3030
Old 07-07-2008, 08:56 PM   #16 (permalink)
Member # 108404
Awesome..hang in there Randy..you da man!!
Brian
Old 07-07-2008, 09:32 PM   #17 (permalink)
Member # 96321
Is the rumor true that you are working on a lighter rockwell axle or custom axle?
Old 07-07-2008, 10:22 PM   #18 (permalink)
Damn you chuckie...
svt150j49's Avatar
Member # 85316
Send a message via AIM to svt150j49
4.89s would be wicked for rocks! im sure if they sold a full line up of gear sets for them, dana 60s would be a thing of the past....
1996 F150 - Supercharged 5.8L, E4OD, Vortech S-trim, PSD Intercooler, 15 psi , 1356, Dana 60, 10.25, 5.13 gears, welded rear diff, 14" Air/Coilovers. Check it out:
Build thread:
Here
The un-named buggy - 2.3L, lotsa tube, and FJ80s.
svt150j49 is offline   Reply With Quote
Old 07-07-2008, 11:11 PM   #19 (permalink)
XJ_ranger's Avatar
Member # 31848
Send a message via AIM to XJ_ranger
something about uptravel makes me think otherwise...
Bryan 'Opie' Bennett
JV Rally Post #175 Tellico Rally post #531
Originally Posted by asp87 View Post
I think our friend GreatWhiteXJ is forgetting a zero in his pulled-from-rectume tolerance. That's the only way it could possibly make sense. If that's the case, a refresher of 4th grade math is in order.
XJ_ranger is offline   Reply With Quote
Old 07-07-2008, 11:41 PM   #20 (permalink)
Member # 36187
You would have to go on one helluva diet opie.
ramsey is offline   Reply With Quote
Old 07-08-2008, 07:36 AM   #21 (permalink)
NOCTURNL's Avatar
Member # 25532
Yeah, thats what i am workin on now. should have a few protos of the housings and gearsets soon. i try to keep things quiet because i never seem to get stuff made as quick as i need it. never enough time in the day. i will post up some picts asap.
RANDY OUVERSON
320-983-3030
Old 07-08-2008, 07:55 AM   #22 (permalink)
bigsilly's Avatar
Member # 77779
That comment makes me chuckle...
Retired Driver #4447
Bench racing with a keyboard
bigsilly is offline   Reply With Quote
Old 07-08-2008, 08:02 AM   #23 (permalink)
Member # 36399
PSSSSS Adam, go look under your truck. Now HTF would you fit a rockwell under there and keep it out of the oil pan?
I wanted to swap my 60's for rocks in the hulk, but I could barely do it.
94 F-150 Stepside. BGTL 12" lift, 1-tons, 39" 'roks
95 F-150 6" of lift, SAS 35" BFG's
94stepsideford is offline   Reply With Quote
Old 08-10-2008, 11:38 AM   #24 (permalink)
dobsogj's Avatar
Member # 16561
Randy, any updates on the 4.89s, or the other rocks stuff your working on?
Old 08-10-2008, 06:57 PM   #25 (permalink)
Member # 33536
he was allegedly working on an aluminum housing as well??
85blue4runner is offline   Reply With Quote
