OTC carrier bearing puller - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 10-22-2008, 09:38 PM   #1 (permalink)
Mechanos's Avatar
Member # 6704
Anyone have or use one these? I know it's not the super-bitchin' clamshell type, but I don't have the need to setup axles everyday.... just the occasional axle here and there over the years.
It's
IHeavy
aka TORC
KC0UIC
Nothing is foolproof to a sufficiently talented fool.
Mechanos is offline   Reply With Quote
Old 10-22-2008, 10:38 PM   #2 (permalink)
Racing Ron's Avatar
Member # 21914
Probably pulled over 1000 carrier bearings with that style puller. The only problems are:
1. Getting under the bearing far enough to reach the inner race - sometimes you need to grind the "feet" of the pullers to make it work. Then they tend to break...so buy extras.
2. On tough bearings the puller may spread under pressure - I've used a simple c-clamp to prevent that with good success.
Regards,
Ron
Racing Ron is offline   Reply With Quote
Old 10-23-2008, 03:59 AM   #3 (permalink)
Member # 4140
I have the same basic puller, but a Snap-On. Ron is right on with his assessment.
Tim
There is no accounting for taste
1936, 1937, 1943, 1950, 1952, 1954, 1955, 1997, 1998, 2002, [B][COLOR="Red"]2008[/COLOR][/B].
Black Dog is offline   Reply With Quote
Old 10-23-2008, 07:04 AM   #4 (permalink)
Mechanos's Avatar
Member # 6704
Regards,
Ron
What is both of your experiences with using it on a D60? Were you able to get under the bearing without doing a bunch of grinding on the feet?
It's
IHeavy
aka TORC
KC0UIC
Old 10-23-2008, 07:07 AM   #5 (permalink)
Member # 43184
If you add a splitter to that combo, you can very easily do all your bearings on your 60.
You want a good sized one. Around 6 inch.
bnine is offline   Reply With Quote
Old 10-23-2008, 07:11 AM   #6 (permalink)
Mechanos's Avatar
Member # 6704
Thanks... I already have a splitter and 20 ton press, so the pinion bearings won't be a problem. I just need a puller for the carrier bearings.
It's
IHeavy
aka TORC
KC0UIC
Old 10-23-2008, 08:18 AM   #7 (permalink)
Member # 43184
Nice.
The splitter is usually hand on the carrier as well. Sometimes you have to cut the cage off and catch the top lip of the inner race, but it works well.
Wear glasses and gloves on those. I managed a few stitches from a race lip that blew a chunk off it while pulling
Old 10-23-2008, 08:32 AM   #8 (permalink)
Member # 46175
Thats exactly what I do.
USED and NEW 4x4 PARTS - (716) 984-8715 8-5pm EST
Specializing in Axles and Transfercases
Mh4Runner is offline   Reply With Quote
Old 10-23-2008, 11:28 AM   #9 (permalink)
Got .45?
Chrisjeep7's Avatar
Member # 9274
save up and get the one from randys. it is freaking awesome! + you could pull other guys bearings and charge them a little to pay for it.
94 YJ w/ 5.3L, TH400, Atlas, and 42" Pitbull Rockers
Chrisjeep7 is offline   Reply With Quote
Old 10-23-2008, 11:31 AM   #10 (permalink)
bronco75's Avatar
Member # 8512
Send a message via AIM to bronco75
Thats what I have used for many years. Used just the puller to start and then added the spreader and it works much better. Only difference is all my stuff is snap on.
keep up or get left behind
75 bronco trail buggy
60-9 frt build up thread
OutBack Auto 4WD and Fab
MV4W.com
bronco75 is offline   Reply With Quote
Old 10-23-2008, 12:01 PM   #11 (permalink)
Mechanos's Avatar
Member # 6704
It's not a matter of saving up... I could buy 6 or 7 of them today if I wanted to. It's a matter of spending that amount of coin on something I will seldom use. Now if I was setting up axles for a living or had a line of people around the corner wanting me to set up their axles, it would be a different story. Doing one or two axles every 4 or 5 years just isn't enough for me to justify spending that kind of money on tooling.
It's
IHeavy
aka TORC
KC0UIC
Old 10-23-2008, 01:13 PM   #12 (permalink)
Keith's Avatar
Member # 52
that will work fine with a 60.
Rockzombie Smurf
Keith is offline   Reply With Quote
Old 10-23-2008, 02:37 PM   #13 (permalink)
Member # 43184
I have to disagree there. I don’t think the randy’s puller is worth the money, even if you do a lot of gears. But Im a jeep guy, maybe they work better on larger stuff then do on 30’s, 35’s, 44’s, amc 20’s, or 8.8’s.
Those are the diffs I deal with most, and the randy’s puller wont do the carrier bearings on the majority of them. Specially rubicon 44’s, but those are just fawked anyways.
Because Im Canadian the shipping was a bitch, and I basically paid 700$ for a pinion bearing puller.
That’s my 2 cents. I do use it on pinions, but it was a bit of a waste. Hindsight, I would have bought a better 2 jaw like the one above and continued to use my splitter.
Old 10-23-2008, 02:38 PM   #14 (permalink)
1sicbronconut's Avatar
Member # 37866
If you don't need to save the bearing I've just used a 3" cut off wheel for bearing removal for about 20 years. Cut off the cage, cut about 2/3's into the inner race and smack the cut with a chisel and your done. I work in a Ford shop and thats pretty much how all the flat raters do it
1sicbronconut is offline   Reply With Quote
Old 10-23-2008, 03:20 PM   #15 (permalink)
Member # 25377
Then I assume you use setup bearings when setting the gears?
Billy
Follow my build-up at [URL="http://www.bsfabrication.net"]BSFabrication.net[/URL]
JeepFreak21 is offline   Reply With Quote
Old 10-23-2008, 03:29 PM   #16 (permalink)
Mechanos's Avatar
Member # 6704
Found it online for a little more than half of what the local tool store wants. Ordered it this afternoon.
It's
IHeavy
aka TORC
KC0UIC
Old 10-24-2008, 06:48 AM   #17 (permalink)
GearMan's Avatar
Member # 187
then sir you are a TOOL it works all the way down to little mg and triumph diffs you just have to be smarter then the tool you are useing
GearMan is offline   Reply With Quote
Old 05-26-2010, 11:30 PM   #18 (permalink)
speedo's Avatar
Member # 23262
I have used one like the op showed in the first pic but mine is a Snap-on, it works ok with the noted exceptions. This is what I use most of the time though.
Gus
The ultimate result of shielding men from the effects of folly is to fill the world with fools.
--Herbert Spencer, English Philosopher (1820-1903)
speedo is offline   Reply With Quote
Old 05-27-2010, 05:59 PM   #19 (permalink)
Member # 18433
Dude that tool is awesome!! I bought one to do the bearings when i was building axles for my jeep that i never finished. That thing is worth evrey penny, and ive made my money back on it "renting" it out to people i know that needed it. Way easier than dicking around with jaw pullers and shit like that. I believe my buddy also got it to work on his 14b as well. Def worth it.
2002 Taco TRD, Getting close to pirate worthy, still a ways off!
43 willys G503
Gslander is offline   Reply With Quote
Old 05-27-2010, 06:35 PM   #20 (permalink)
Member # 4878
Send a message via ICQ to Travis Waldher Send a message via MSN to Travis Waldher Send a message via Yahoo to Travis Waldher
Really? I used it without issue on:
AMC20
D30
D44
9.25"
8.25"
I'll gladly take that piece of shit off your hands for the cost of shipping.
Travis Waldher is online now   Reply With Quote
Old 05-27-2010, 06:36 PM   #21 (permalink)
Member # 106845
Send a message via AIM to flatlander757
I know somebody revived an old ass thread... but you can get the dope ass bearing puller kit including the D70HD/D80 clamshells for $250 from Extreme Custom Parts:
http://extremecustomparts.com/i-3611...2-on-sale.html
I ordered mine from them and am very pleased with it, done quite a few axles with them, D30 up to D60 so far... haven't needed to use the big clamshells yet.
-Tony
flatlander757 is offline   Reply With Quote
Old 06-24-2010, 01:41 PM   #22 (permalink)
Member # 43184
AMC20
D30
D44
9.25"
8.25"
You can have it for the 700 I got raped for since I've used it maybe half dozen times in the last hundred re gears I've done.
I find a splitter, press, and a couple jigs work better.
Its an alright unit, but it isnt the be all end all.
And there are a few bearings it doesnt pull. Rubicon 44 diaphram side on the carrier is one that instantly comes to mind.
Whatever, to each their own.
Old 06-24-2010, 06:42 PM   #23 (permalink)
Member # 135453
Totally agree to go clamshell...if you can justify the coin. I went with the uber-expensive ARB version because I can't stand Randy's made in some 3rd world country quality. Absolutely no damage to the bearing (or shims) and the thing works very nice.
trajan is offline   Reply With Quote
